Whirling Noise 1.5K To 2K Rpm - Cold Start
#1
Posted 16 May 2012 - 03:51 PM
Any ideas?
1 of 1 - '97 427 854R - 111k
#2
Posted 16 May 2012 - 03:55 PM
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, 16t w/ Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo Strut Tower Brace, Konis, IPD springs, few more things to come...
#3
Posted 16 May 2012 - 05:14 PM
#4
Posted 16 May 2012 - 06:10 PM
I will check when I leave work if it makes the noise while my car is in P and started up.
#5
Posted 16 May 2012 - 06:20 PM
1998 C70 HPT M modified S70 T5A Emerald Green on Tan
#6
Posted 16 May 2012 - 10:23 PM
But yea, best guesses are oil pan o-rings or oil thermostat.
#7
Posted 17 May 2012 - 01:50 AM
This comes up soooo much, yet we still don't have a set answer. I have it too. :-(
I remember someone saying something about the PS pump. Has anyone with these symptoms removed their Serp belt yet?
1996 854 T5
#8
Posted 17 May 2012 - 10:18 AM
#9
Posted 17 May 2012 - 11:56 AM
#10
Posted 17 May 2012 - 12:01 PM
1996 855 Platinum - Died1997 850 R - Sold
#11
Posted 17 May 2012 - 12:30 PM
#12
Posted 17 May 2012 - 12:39 PM
1998 S70 GLT-5 427 / 1998 S70 T5M 019
#13
Posted 17 May 2012 - 01:19 PM
It is RPM related. It is not present at idle at all.Whirling noise, turbo not getting enough oil on startup? If its rpm related you should hear it slightly at low rpms, and as it increases you would hear it more. Its not present at idle at all? Could def. be the tensioner, when it warms up the fluid inside the bearing actually lubricates.
#14
Posted 17 May 2012 - 01:30 PM
#15
Posted 17 May 2012 - 02:10 PM
http://www.___.com/f...1110b7c45e4f1bc
http://volvospeed.co...ne-whine-98-t5/
http://volvoforums.c...hine-s70-58242/
http://v70r.com/foru...-on-cold-start/
tl;dr version - Try replacing the oil pan o-rings and then try oil thermostat.
Damn, I hate how VS doesn't like you posting MVS links.
Try this:
http://www.
___
.com/forums/
viewtopic.php?f=1&t=37422&sid=
b1dd155b67843df521110b7c45e4f1bc
Make that one link.
But add in Matthews Volvo Site
#16
Posted 17 May 2012 - 02:33 PM
Sep Tensioner... not Timing Belt TensionerNot tensioner (I think), since I was scared when I first heard it and did a complete timing belt + water pump change.
#17
Posted 17 May 2012 - 02:44 PM
#18
Posted 17 May 2012 - 02:52 PM
#19
Posted 17 May 2012 - 02:57 PM
Exactly what I am going through. Thanks!I got this too. Only does it when the car is cold and the first start of the day. After that it doesn't do it at all, even if the car sits for a few hours. I think it is coming from the PS pump somewhere. That's the EXACT area it's coming from. Happens in the same RPM range you're talking about, only happens for a few blocks of driving, car doesn't even have to be completely warm for it to go away.
When I get situated in the new house I am going to go over my car with a fine toothed comb and get a good look at everything.
#20
Posted 17 May 2012 - 03:04 PM
