Rn Motor Install
72 replies to this topic
#1 laird
laird
  • 1,549 posts
Posted 17 May 2012 - 08:37 PM
I am putting an 01 LPT motor in the R, using the 19T for now with the 20G waiting on me to weld some pipe.
I had to bore (ok drill out) the cams to accomodate the distributor plate and Cam position sensor. I sourced a new(er) AC compressor and Alternator and PS pump and am using the new accesory bracket which I feel is a huge inmprovement alone.
For now the engine is bone stock internally but I may put my forged rods in once the current motor is on the bench.
I will use the existing intake manifold and open up the ports as much as possible to mate better with the RN head.Posted Image Posted ImagePosted ImagePosted Image
#2 Commander Riker
Commander Riker
  • 2,855 posts
Posted 17 May 2012 - 10:43 PM
Good job! I love my RN motor. If you have any questions on install, feel free to drop a PM and I'll answer what I can.
1998 V70 R AWD - M66 & 2.5T RN swapped
2007 Dodge Ram 1500 QC (Daily)
#3 laird
laird
  • 1,549 posts
Posted 17 May 2012 - 11:01 PM
I'm a little iffy on the VVT. I have a solenoid bolted up but I'm not sure what's going to happen without any control. I can pick up an exhaust cam from a 99 NA motor that isn't VVT, that may be a good idea. I think I have the timing belt installed correctly, first time on a newer motor but I got some good info from another member. Need a rear cam seal for the intake , there wasn't one behind the distributor plug.??? Should be ready to install the engine in the morning.
#4 Matty Moo
Matty Moo
  • 1,941 posts
Posted 17 May 2012 - 11:44 PM
<p>
<br />
I&#39;m a little iffy on the VVT. I have a solenoid bolted up but I&#39;m not sure what&#39;s going to happen without any control. I can pick up an exhaust cam from a 99 NA motor that isn&#39;t VVT, that may be a good idea.  I think I have the timing belt installed correctly, first time on a newer motor but I got some good info from another member. Need a rear cam seal for the intake , there wasn&#39;t one behind the distributor plug.??? Should be ready to install the engine in the morning.<br />
<br />
<br />
Correct..you will have to put in a rear cam seal on the intake cam. The rn block doesn't have it, just the plastic plug where the distributor would be. Easy stuff though, it installs just like it would normally, just tap it in.
</p>
#5 98glt-5
98glt-5
  • 203 posts
Posted 18 May 2012 - 12:14 AM
Just did a rn swap a few weeks ago. Just line up the timing marks, throw the belt on and leave the VVT solenoid on there, nothing happens, cam stays where you put it and everyones happy!
1998 GLT Auto -> 06' 2.5T Revision N, N/A Throttle body/manifold port matched with IPD poly spacer, M56H, 16T @ 18psi, T5 ECM -Stevo tuned - with no lift to shift and launch control, MSD Blaster Coil and MSD-6AL with two step, IPD Springs and Bilstein HD's,
1999 S70 AWD - daily with a tune
#6 Simply Volvo
Simply Volvo
  • 796 posts
Posted 18 May 2012 - 12:29 AM
looking great! Ill be following this!
1996 Volvo 850 NA. 960 Plate, CAI, Phenolic Spacer. Paddle Shifters. 170K. Went from car seat to drivers seat.
1995 Volvo 850 T-5R (Black). 208K and counting. Getting There. Manual Swap, M4.4, Ta Technix Coilovers.
#7 Commander Riker
Commander Riker
  • 2,855 posts
Posted 18 May 2012 - 12:57 PM
It is my understanding that the proper procedure is to bring everything to TDC, one quarter turn forward and then one quarter turn back to release any tension in the VVT.
Do not worry about running with the VVT unplug. It works beautifully. You'll see. Good luck!
#8 lookforjoe
lookforjoe
  • 9,886 posts
  • Interests:Making Stuff
Posted 18 May 2012 - 03:07 PM
Looks Great!
You can always weld the hub like Volvo5.0.
Hard to fit the fuel lines over the head with the VVT solenoid in place.
Check to see if the later block has the boss on the water pump / casting used for the fuel line support bracket. I wouldn't leave that off - I braised the bracket to the water pipe on mine.
1998 V70 XR M66 Quaife 14J PTE6262 BB Built '04 2.3l Block Wiseco Pistons 147mm H-Beams '03 Ported Head EnemY21Cams TurboTuner 710cc Inj, DW300, 3" DP back Dual Magnaflow 14834's Apr 2013 408WHP AWD (@7925rpm) 347WTq(@4400rpm)@18psi LGSpeed Header Custom Intake Manifold 30x12.5x3.5"Treadstone FMIC AP Racing Clutch KU SM Billet Flywheel Kaplhenke CoilOvers
#9 NEU
NEU
    Old Man Crew Photographer
  • PipPipPipPip
  • 3,692 posts
  • Interests:Formula 1
Posted 18 May 2012 - 03:53 PM
I'm sure you just want to replace the VVT hub, but the best cam for the exhaust is the turbo @9.05 lift, '99 NA exhaust cam is 8.80 lift. For the intake the NA cam would be a better choice to swap, 8.65 lift vs the turbo 8.40 or 8.40 depending on the motor.
http://volvospeed.co...k/#entry1811561
Laser Blue 2000 V70R
Speedtuning St2 @18psi/19T w/Forge CBV/IPD drop-in intercooler/R mani/CJ 3"DP/dual 3"Magnaflow/EST intake w/K&N/Samco & Snabb hoses/Delco TCV/Bosch Super Plus/IPD HD COP/UR lite pulley/CJ delrin subframe mounts/TME AWD springs/TME strutbrace/IPD sways w/adjustable endlinks/Koni Sport strut/18" OZ Ultraleggera
#10 laird
laird
  • 1,549 posts
Posted 18 May 2012 - 11:38 PM
Looks Great!
The fuel lines are a concern, I was looking at that last night but ran out of smarts about midnight.
I thought about getting some braided lines made to run over the top. We'll see.
Ran out of wire for the welder, yet another trip to the store.
I have the 01 turbo motor so the cam is good I guess. Maybe I'll look at grabbing a fixed hub or do as suggested and weld the VVT.
#11 D s50r
D s50r
  • 1,535 posts
Posted 20 May 2012 - 11:01 PM
How do u weld it does anyone have pics?
98 midnight blue s70 glt se
#12 Kevin.
    I'm 22 and I love anal
  • 7,536 posts
Posted 20 May 2012 - 11:18 PM
When I do my RN swap Im going to try to pickup a 99 or 00 V70 so I can keep the coilpacks and VVT. GL with the install OP
FOR SALE THREAD $1900
#13 mdlimy
mdlimy
  • 3,406 posts
  • Interests:Beer, volvos, boost <3
Posted 21 May 2012 - 02:51 AM
http://volvospeed.com/vs_forum/topic/137410-my-ghetto-vvt-delete/page__hl__%2Bweld
#14 Commander Riker
Commander Riker
  • 2,855 posts
Posted 21 May 2012 - 03:29 AM
Ran custom braided fuel lines up and over... highly recommended. With the stock hard lines, you won't be able to get the timing cover off on the passenger side, which covers the first cylinder. PITA.
Mad thanks to Dan for helping knock out this project before my trip. It's been a super solid mod, and the aeromotive FPR is cool!
ALSO... note that I notched the timing cover near the coolant line. If not, it can rub and wear the coolant line quite quickly.
#15 550
550
    someone please talk to me
  • 12,883 posts
  • Interests:My two cars
Posted 22 May 2012 - 01:40 PM
You can keep the stock FPR and run braided as well, but Lucas' setup looks simple enough too. Bad ass!
I'm still running my hard lines with the VVT solenoid, I had no issues to speak of.
#16 sconeman
sconeman
  • 4,396 posts
  • Interests:family, cooking, making stuff, cars
Posted 22 May 2012 - 01:45 PM
easiest way is to remove the solenoind and use a blanking plate, run the fuel lines under the cover. Or I would go with a setup like Korruptions. I think Volvo 5.0 used the newer lines... another alternative.
#17 550
550
  • 12,883 posts
Posted 22 May 2012 - 01:54 PM
And if you do that you need to turn the cam back on the hub... so there is no play.
#18 laird
laird
  • 1,549 posts
Posted 25 May 2012 - 01:29 PM
Well I have been busy with the install and here is where I am.
First, this is how the timing marks look.Posted ImagePosted Image
Next, there were some unforeseen issues with the front motor mount. The P2 mount doesn't work, what? So initially, I took the grinder out and made the old one work. Then on one of my bi-weekly junkyard trips, I found the P80/RN mount and that solved my problem.Posted ImageThe one in the middle is what you want. On the right, not so much.
Next was getting the old manifold to mate up a little better to the larger RN ports. I got pretty close using an old Intake manifold gasket as templatePosted Image
I got things all buttoned up and fired it up and was delighted that she runs. Sounds nice and tight and smoke free.
Then the bad. I obviously Fubared something because my new RMS leaks like a sieve:(Posted Image
I'll just practice that motor in/out/ move like Hussien:)
More to follow.
#19 laird
laird
  • 1,549 posts
Posted 25 May 2012 - 01:37 PM
I just left the cover off for the fuel lines but I think that I will likely put them under the cover when all is said and done.
I also spent some time test fitting the 20G when I had the engine on the floor and did some grinding on the rear mount. I ended up putting the rear mount in without the black steel "shield" which should allow the large compressor to fit without grinding too much on the compressor housing. I pondered for a while the true meaning of that black shroud and couldn't really come up with much so it's s gone. I know it is a major PITA when trying to do a tranny removal. If it turns out my engineering estimating is off, I have a few spares.
I cut out a piece of it that fits between the damper and the bracket to keep all at the proper height.
#20 lookforjoe
lookforjoe
  • 9,886 posts
Posted 26 May 2012 - 03:27 AM
Sorry to hear the rear main is leaking! At least you can just drop the trans to access it - no reason to pull the motor...
