Pita Removing Turbo Exhaust Housing
8 replies to this topic
#1 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,994 posts
Posted 21 May 2012 - 03:06 PM
I'm pulling an angled exhaust housing from a car that is getting parted. Got the vband clamp off and 3 of the 4 nuts to the engine, but I can't seem to reach that lower nut towards the driver's side? What's the trick or favorite tool here? I was trying a flexible ratcheting box wrench.
Worked on it for about 1/2 hour and decided to just give it a rest and attack it another day. I just don't seem to have any room back there to get a wrench on it and room to move. It's on a 99 AWD so technically wrong forum, but shouldn't be much different than any other. Mods can move if needed.
99 V70R
98 V70 GLT
#2 Keep Calm Chive On
Keep Calm Chive On
    I Love To Pound Ash
  • 2,913 posts
Posted 21 May 2012 - 03:48 PM
I cut a 13mm wrench in half... its a bitch plain & simple.
Beiber: kurt i got with a cougar last weekend
Dr.PorkenheimersBonerJuice: no you didnt kev, you jacked it to pictures of teen mom. that isnt cougar
SHIT IM SELLIN ; SHIT YOU BUYIN. DONT BE A BITCH ; CLICK IT
#3 bergmjs
bergmjs
  • 2,060 posts
Posted 21 May 2012 - 04:30 PM
I wiggled a standard open-ended wrench in there and got it off and on. Took lots of patience and a few swears, but it's possible.
'95 854 T5M 195k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue - DEAD - To be parted out
'04 S60R - 125k
#4 Dan A
Dan A
  • 1,994 posts
Posted 21 May 2012 - 04:48 PM
I think I have a stubby 13mm wrench. Maybe I'll give that a try. I think walking away from it for the day was probably for the best and I just need to go at it fresh another day. Thanks.
99 V70R
98 V70 GLT
#5 Rsterns
Rsterns
  • 1,224 posts
Posted 21 May 2012 - 08:37 PM
Try a ratcheting box wrench
'98 V70 T5 (Auto) At 280,000 fresh rebuild with port and polish ;Cryo treated everything, ARD Blue tune w/ IPD Intercooler and TME cat back exhaust,Koni FSD/ Eibach springs, IPD sways F/R, IPD HDEndlinks, IPD BBK Currently 407K miles... '99 V70 T5M (Was JRLs)
#6 bergmjs
bergmjs
  • 2,060 posts
Posted 22 May 2012 - 02:11 PM
'04 S60R - 125k
#7 Dan A
Dan A
  • 1,994 posts
Posted 24 May 2012 - 03:28 AM
LOL. I wasn't going to point it out. :)
Well, if the rain let's up, I'll go after it again this weekend.
99 V70R
98 V70 GLT
#8 db130
db130
  • 771 posts
Posted 24 May 2012 - 06:03 PM
i went through this myself recently. that nut is facing the front of the car and the issue for me was leverage. by the time i contorted my arm to reach the ratchet and/or wrench i just could not turn it loose
i ended up using a gearwrench x-beam wrench which is the longest wrench i had by far
2000 V70XC SE, 162k '00 R Duals/Angled 15G/15 psi ST T5 tune/Delco TCV/UK 302s/180°F Stant Superstat/Samco hoses/IPD HD CBV/Sconeman intake
1998 S70 T5, 233k '00R 302s DIY AEM BCS/IPD Stage 1 ECU/IPD 3" Turboback
Check out the Delco BCS/TCV
#9 ande0549
ande0549
  • 77 posts
Posted 27 May 2012 - 04:05 PM
Use a crow foot wrench or better yet, a flare-nut crow foot!
98 S70 T5M, 157k
Upsolute ECU (ARD Blue next), Samco intercooler/Radiator hoses, R-manifold, Angle-flange 16T, EST 3" downpipe & 2.5" catback, Koni FSD, Eibach Pro-kit, IPD sway bars, QBM shift kit, R-bumper, 98 XC grille, Air pump delete
