Propus C Replacement Parts?
bbs part inner outer bolt
4 replies to this topic
#1 JasonC
JasonC
  • 62 posts
Posted 24 May 2012 - 02:48 PM
Just picked up a set of Propus C wheel for cheap off of craigslist, but two have slight inner rim dings which I figured would be no problem to have repaired when they are being refinished.
My parts manager is telling me that I can get replacement parts for BBS wheels for cheap, probably cheaper than having them repaired, and I should just go that route instead.
Skeptical, as Id never heard this for the 2 piece wheels, I did some searching and came up empty handed. All I found were parts for the high end 3 piece wheels. The outer rim(barrel) sells for $300 ea. for the 3 piece, so I dont see how itd be cheaper but whatever.
Posting this to see if anyone knows about parts for these, otherwise Im calling I'm dumb and will just have them refinished ($95 per) like I originally planned.
1997 854 T5 :: M56, ipd SR5-T, SNABB Turbo Inlet Pipe, SNABB Poly manifold spacer, NA Cams, OBX exhaust, Turbosmart Dual Stage MBC, 4 bar FPR, MSD Digital 6 Plus, Blaster SS Coil, Bilstein HD's, ipd Blues
2005 Chevrolet Uplander LT(The Man Van!!)
#2 mune237
mune237
  • 1,295 posts
Posted 24 May 2012 - 09:05 PM
BBS and cheap? They didn't think they mix well together
Did you google? I found lots of sites stating they can get replacement parts!
But at $95 (wow!) I'd just get them repaired.
Edited by mune237, 24 May 2012 - 09:12 PM.
1995 960 TOTALLED 1997 850R SOLD
2000 C70 HPT Convertible Auto
#3 s_moneh
s_moneh
  • 1,583 posts
Posted 25 May 2012 - 04:14 AM
u will not find a thing. trust me i've looked. savage wat u can otherwise u have to buy used off somebody who may have some
#4 JasonC
JasonC
  • 62 posts
Posted 25 May 2012 - 04:21 AM
That was my first thought! Did some more searching and I only came up with replacement bolts. There are plenty of parts for the high end 3 piece wheels, yes.
These wheels were specifically made for Volvo, as can be seen on the back of the spokes. They are stamped with "Volvo" and the size "7.5 x 17" along with other numbers and "Germany". I couldnt see a company like BBS making parts for 1 OEM wheel.
Pretty sure my parts manager just didnt want to admit he assumed wrong.
Regular pricing is $150 per, but they cut us a break since we send them so much business.
#5 mune237
mune237
  • 1,295 posts
Posted 30 May 2012 - 07:46 PM
I'm sure IF you found parts, they'd be well over $95 a wheel. I'd go with the repair(s)
