A few more issues with the $1000 2000 S70 that I am afraid of! I finally registered the S70 today and I dont think I should have. On the way home from registering the car the oil light came on. NOT good was scared made sure to turn the AC off and radio down to listen for strange noises. Drove it home after the light was lit about a half mile. I know I am in need of replacing the oil trap system and am guessing the oil pan O-rings. Does the oil trap have anything to do with the oil light ocming on?
I changed the oil and filter as soon as I got home just hoping that the oil and filter was dirty which it was. After the filter and oil change the lite still lites up after the engine warms up. I will not be driving the car till this is fixed. I have read to check the o rings in the pan, idle the engine for 2 mintues till warm shut the car off and remove the dipstick clean it, pull it again and look for airbubbles. No bubbles.
There was a weird issue with the filter change. It looked like there was some type of copper shavings from the oil filter. After the oil filter sat on the oil drain bucket, I could see shaving that looked of copper. Does anyone have any idea if this could be some type of oil additive of some type like a snake oil or something? What should I do?
Also got anyother code P1672. I have done internet searches and forum searches not leading to much information. Anyone have any idea what this code leads too?
Please post,
Any advice would be appreicated!
Paul
I Really Need Help Now... Poor S70, Oil Lite Lit...
Started by Paul33603, Yesterday, 11:14 PM
oil trap o rings sump o rings engine knock
8 replies to this topic
Posted Yesterday, 11:14 PM
96 850R with 150,000, Tampa Bay Florida EST Rip Kit. IPD boost gauge cluster, K&N filter, Seafoam and scared to switch to Mobile one, no oil leaks as we speak
Also 2002 XC 70 with 49,000 bone stock switched to Mobile One!
Posted Yesterday, 11:51 PM
The first step when the oil light comes on is to turn the engine off, IMMEDIATELY, not turn down your climate control so you can hear if something bad will happen. The copper is from engine bearing material, probably from driving with no oil pressure. That half mile could have been the last straw. Continuing to run this engine with the oil light lit for any amount of time is absolutely insane. STOP, and fix the sump o-rings as a first step, if you haven't already toasted your motor.
Edited by burnout8488, Yesterday, 11:52 PM.
Posted Today, 02:00 AM
Clogged oil pan screen.
Run vehicle untill warm/hot (idle) if the light comes on turn off the vehicle instantly!!!!!!!!!!!!!!
Right after shut down, drain the oil into a very clean container. After strain the oil through a cloth and not how many particles some out. Repeat this unit it comes out clean. Reusing the same oil...
Use 20weight, thinner the better.
Without knowing more that's my first conclusion. Whatever you do dont drive the vehicle. Never let the light stay on!!! When it's lit there is no oil pressure and damage happens fast.
Posted Today, 04:02 AM
Well thanks for your replies even if its something i did not want to hear. Engine to my knowledge is fine. Still runs without knocks or weird noises. i guess you learn something everyday even if it could have been disasterious i thought the oil light meant low pressure, i did not realize it meant NO pressure if i did know that i would not have driven the car from that point.
i dont understand how this could have happend i havent driven the car since purchasng it a week or two ago. i had to drive it from Lakeland to Tampa which is about a 40 mile trip. Why did this happen all of the suddon?
All i have done is Seafoamed the Vac line then changed the spark plugs. Also now the oil and filter. So in warming the car up and draining the oil what should i use to filter the fluid through like a cotton towel or? i will definitly keep my eye on the oil light. While warming. i guess if the light comes on its going to my indie. Double darn it!!
Thanks for you replies!
Posted Today, 04:22 AM
I just use an old white shirt. By warming the oil up for a while and running it you will stir up the particles. You have to drain the oil out right after or they all settle to the bottom of the pan. If you get a l
You can tell how bad it is depending on how many particles you get when drained.
Nothing your mechanic can do about any of this.
Posted Today, 02:09 PM
Well i started the car to put it back in my driveway under the carport. No light thank goodness. What are your thoughts on Seafoam in the engine? Running it for 30 minutes to use as a flush if the light appears turning off the engine right away and starting over. There are signs off cooked on oil on the dipstick so i am sure the engine is caked up. i have never used Seafoam in that way but am pondering tryin it. i have looked for a used engine if needed found a few for under $700 at local parts yards i dont want to go that route but will if i have to. So Seafoam in the engine or not? i do have a spare Auto-rx from using it in the Saab. But i dont think that would work fast enough since i am not giing to be driving the car.
info appreicated!
Thanks again,
Paul
info appreicated!
Thanks again,
Paul
Posted Today, 06:39 PM
you should probably refrain from seafoaming and flush the engine with oil strain and repeat until clear. i think theres a chance seafoam may loosen up more and cause the clogging to get worse. im no expert though so take that with a grain of salt or whatever.
1998 s70 267000 miles
Repairs and replacements: strut mounts, spring seat,pcv,timing belt,power steering pump,sas delete,ectx2.
Tommy., on 14 May 2012 - 11:28 PM, said:
Wait, sandwiches can't help start an engine?!
oh the humanity!
Posted Today, 08:22 PM
Thanks for your reply! So i did hold off of the Seafoam treatmeat today started the car, warmed up without an issue basically no oil light. i revved the engine to 3k no light no weird knocking or signs of engine malfunction went to 5k with no light. i am still scared to take the car out on the road due to the light might come on. i do plan next week on the filtering of the oil thru an old tee shirt i really hope this works. i just dont understand on why this happend while driving but no light today while warming or revving. Someone please enlighten me. Is it the previous owner just did not change the oil and filter and everything was gummed up is that even possible?
thanks in advance
Paul
thanks in advance
Paul
Posted Today, 08:59 PM
Keaton85 i will be using your meathod on Tues or Wed. Also wondering what to do about the oil filter/cassette. Should i remove it and check for particles after draining the oil and filtering it? Or drop the oil filter right after the oil is removed? i am still freaked out about the oil light even though it hasnt lit today after what i post previously.
Thanks again!!
Thanks again!!
