Sc-901 Can A Subwoofer Be Added?
Posted 30 May 2012 - 01:28 AM
Posted 30 May 2012 - 02:09 AM
Since your 901 has a factory amp, you can't use the factory amp connection to send a signal to an aftermarket amp. You'll need a line output converter to take a signal from one the speakers and reduce it to an amp-level signal. For your music preferences, I think you'd like a single 8" or 10" subwoofer in a sealed enclosure.
99 V70 R. Silver & charcoal with a few mods.
Posted 30 May 2012 - 02:48 AM
Hi Bob,
Thanks Adam, That's just the information I needed. One last question, as this is not my area, is it appropriate to provide power to an aftermarket amp directly from the battery, and if so for a 10' what size amp and gage wire?
Posted 30 May 2012 - 03:00 AM
Yes, you will need to provide power directly from the battery. For your setup, I'd go with 8AWG power and ground cables. For your needs, look for an amp with ~250 watts of RMS (not peak) power.
Posted 30 May 2012 - 03:06 AM
Can't edit and the answers have been flying real time, I love it and Thanks! Now I just have to go shopping.
Posted 31 May 2012 - 07:35 PM
I used only a single 100W amp to power two 8" Kicker free air subs on my 99 S70T5 and it was quite adequate.
I think you're like me and only need "filler" bass and do not want or need the ground to shake!
BTW, how are these speakers compared to the OEM speakers that were in there?
Jim
Posted 31 May 2012 - 08:44 PM
Bob
Jim
Hi Jim,
The speakers are a real improvement as they don't 'buzz' with a bit of volume. The fade is acting a bit odd, most likely because the rears are now 4 ohm instead of the 8 ohm that came out. One thing I'm considering, as it's a cheap experiment, found some 4 ohm 100W resistors, might try to put it in series to make it an 8 ohm speaker and see if that corrects anything.
Posted 31 May 2012 - 11:56 PM
98 V70R AWD
128k miles, 18T, 3" DP, ABM's, SAS delete, Samco's, K&N panel, white's, 18" Pegs/RE760's
Posted 01 June 2012 - 05:42 AM
Bob--one thing I forgot to ask in my PM was do you still have the D-pillar speakers connected?
Andy, yes I do, they are still OEM, haven't even pulled the grill to look at them yet.
Posted 01 June 2012 - 07:35 AM
I would avoid involving any fixed resistors and adjust the fader to
where it sounds right for you for now, as your modified system sits.
If it's still a problem after you add the sub, there are better tweaks.
Posted 01 June 2012 - 07:50 AM
Resistors are static loads. Speaker voice coils are dynamic loads.
Thanks, I've done further research and agree that was not a sound solution (pun intended). Through Andyb5 however, I did learn about the equalizer I didn't know I had in the 901, (only had the car now for a few months), anyway, I couldn’t wait till morning, so I just finished spending the last 20 minutes or so out in the dark futzing with the equalizer, the rear speakers have now come alive, and I will sleep very well this evening.
#14
Posted 05 June 2012 - 07:56 PM
#15
Posted 05 June 2012 - 10:59 PM
#16
Posted 10 June 2012 - 01:26 AM
Molding removed
Fuse and + cable installed
Adapter harness, Sub Remote and RCA cabling installed
Everything run to the back
Good Ground
All hooked up, sounds fabulous!
