Loose Vs. Tight Suspension
9 replies to this topic
#1 blown_volvo850r
blown_volvo850r
  • 2,846 posts
Posted 28 March 2004 - 06:33 AM
Isn't a looser front suspension better for hooking up on a launch? It seems like that to me, I tuned my Konis back up to standard and the tires seem to grip a helluva lot better.
~Lee
1997 850 R sedan...got me a brand new license plate.
My cardomain page
#2 Guest_DougK_*
Guest_DougK_*
Posted 28 March 2004 - 06:59 AM
In RWD you want a suspension that will transfer weight to the rears, so soft front, stiff rear.
Loose in suspension terms means bad bushings ect.. different than soft/hard.
On FWD, I'd imagine you'd want the HARDEST rear and possibly quite stiff front suspension as well
#3 blown_volvo850r
blown_volvo850r
  • 2,846 posts
Posted 28 March 2004 - 07:08 AM
Well when I had my Konis turned down to GT mode, I could launch @3500rpms and spin halfway thru 2nd before I got over 5mph. Tonight and I turned them back to standard and in a slick parking lot I didn't spin near as much. Note my Konis still are pretty stiff even not turned down, but it seemed to help w/ traction.
~Lee
My cardomain page
#4 Guest_DougK_*
Guest_DougK_*
Posted 28 March 2004 - 07:19 AM
what the hell is GT mode?
Soft
Softer
Sporty?
#5 blown_volvo850r
blown_volvo850r
  • 2,846 posts
Posted 28 March 2004 - 07:25 AM
3 modes:
standard - softest setting
cross country - medium setting
GT - hardest setting
~Lee
My cardomain page
#6 freeskier8585
freeskier8585
  • PipPipPipPip
  • 3,825 posts
Posted 28 March 2004 - 02:44 PM
QUOTE
scott sanders
1997 850 T5// RIP 05 V70R 6SPD
#7 blown_volvo850r
blown_volvo850r
  • 2,846 posts
Posted 28 March 2004 - 04:33 PM
They're the same ones that were on it when I got it. biggrin.gif However, I will paying for the new tires when the time comes.
~Lee
My cardomain page
#8 T5Man
T5Man
  • 14 posts
Posted 29 March 2004 - 03:45 AM
QUOTE(dougs242S60 @ Mar 28 2004, 06:59 AM)
I always thought it'd be the opposite....
In RWD you would want weight to transfer to the rear... to accomplish this you would want the car to sag or sit to the rear... hence soft rear springs and stiff front springs so to keep the front from sagging....
and opposite for FWD... stiff rear springs to push the rear up... and soft front to enable more tilt to the front...
am i wrong?
1998 S70 T5 SE
Intrax Springs Lowered 1.75"
user posted image user posted image
#9 rdiedrich
rdiedrich
  • 118 posts
Posted 29 March 2004 - 04:48 AM
As Doug said you want weight transfer on a RWD. But zero on FWD to keep as much weight on the front, which is why FWD drag cars use wheelie bars to keep the front end from lifting.
From the list of mods I'd say you're past the traction of your tires or you're launching too hard. More mods do not aleays mean faster!
Try dropping your stall speed.
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, a good red wine in the other, body well used, tired and screaming "WOO HOO what a ride!"
The latest one is number nine.
96 855T 118000 mi.; dual MBC 14lb, boost guage, filter, Ipd sway bars, strut brace, modified IPD exhaust, adjustable Koni front, KYB gas rear, plus small stuff.[FONT=Optima]
#10 blown_volvo850r
blown_volvo850r
  • 2,846 posts
Posted 30 March 2004 - 12:32 AM
Yeah I usually launch around 2900, give it 50% throttle for about a second, they slam it. I gotta do it fast or else it shifts up into 2nd. I guess using the L would take care of that but I don't like doing that.
~Lee
edit: As far as RWD...a soft front suspension will not only let the car sink down on the tires, but let it rise up away from the tires. This will let the weight transfer to the rear when the front end lifts up. Once u have the weight on the back wheels, the stiffer the suspension, the harder the tires will be pushed into the ground, hence giving u better traction.
Edited by blown_volvo850r, 30 March 2004 - 12:33 AM.
My cardomain page
