Aftermarket Headgasket For 400Hp Project?
11 replies to this topic
#1 Boxman
Boxman
  • 125 posts
Posted 01 June 2012 - 11:19 AM
For my 400HP engine build I got an aftermarket head gasket from the machine shop, I think it's this one: http://www.joetlc.co...opttt4eebpja137
At least it looks the same.
Anyway, I mounted my cylinder head and tightened it to spec, but then noticed I forgot to put in two bushings that align the head properly. So I took it off, inserted the bushings, and tightened again plus an additional 10 degrees, using the same head bolts and head gasket.
My question: is this still a correct way of mounting it? Should I have replaced the head gasket, and should I have gone for an original Volvo one? Same for the head bolts, they were Payen brand (or something like that). They need replacement, or can I just reuse them? The engine has not been used yet.
#2 lookforjoe
lookforjoe
  • 9,790 posts
Posted 01 June 2012 - 12:23 PM
Since the engine wasn't run, and therefore subjected to any heat cycling, it should be fine. When I built my motor the first time, back in '08, I didn't buy new head bolts, and one snapped on the reinstall. I didn't replace the gasket, just the head bolts and it was fine. Not sure why you went an extra 10º, though. You did oil all the bolts, correct?
That said, without knowing what brand that gasket actually is, who knows how it will hold up. I used Victor Reinz gaskets previous to my current build, and they held up fine on my 350WHP+ setup. I switched to Volvo branded for the MLS style I'm using for the current build.
#3 B Mac
B Mac
    Ginger Beater
  • 4,562 posts
Posted 01 June 2012 - 02:27 PM
Volvo '04+ MLS gasket is what I'm using. No reason to go elsewhere, I've never heard of one going.
The name's Ben: '95 850, m56 w/ gripper lsd, Sachs 707 pressure plate w/ organic disc, built '02 RN 2.3L, worked '04 R head, Enem Y21 cams, Precision 5857B, ARD tune, blah blah blah
#4 854TGA+
854TGA+
    Old Man Crew Border Guard
  • 2,309 posts
Posted 01 June 2012 - 04:53 PM
Get a new head gasket! Much easier to do it now than later.
I lost track where I was when I was tightening down my head / opted for new gasket & bolts. Just my 2 cents
#5 Boxman
Boxman
  • 125 posts
Posted 19 June 2012 - 11:52 AM
Was gone for a while.. The brand for the head gasket is Glaser (part of Dana company). Are they any good, or is that a budget brand?
#6 Jardim
Posted 19 June 2012 - 11:47 PM
If its the same DANA that makes axles for HD trucks, then they are a good company....for their axles, i couldnt tell you anything about their gaskets though.
#7 Rsterns
Rsterns
  • 1,225 posts
Posted 20 June 2012 - 12:48 AM
My only concern with reusing a head gasket after torque is that the metallization of the gasket that covers the expansion joints in the block between cylinders, extrudes into it. Your original concern was correct placement, if the re-installation shifts, that particular interface could be compromised.
'98 V70 T5 (Auto) At 280,000 fresh rebuild with port and polish ;Cryo treated everything, ARD Blue tune w/ IPD Intercooler and TME cat back exhaust,Koni FSD/ Eibach springs, IPD sways F/R, IPD HDEndlinks, IPD BBK Currently 407K miles... '99 V70 T5M (Was JRLs)
#8 Volvo5.0
Volvo5.0
  • 1,106 posts
Posted 20 June 2012 - 02:13 AM
Agree, get a new gasket AND bolts.
It's easy to lose track. Seems like when I'm torquing head bolts, the phone always rings or someone stops by to watch/talk. The way I keep track is using a Sharpie to make a mark on the head next to each bolt as I angle torque them. If I have to stop for any reason, I know where I left off.
1998 S70T5M, 2000 Built B5244T2 RN Engine, K24 turbo, 550cc injectors, Turbo-Tuner, Coolingmist Progressive WMI, Precision FMIC, 311whp 363wtrq
#9 Boxman
Boxman
  • 125 posts
Posted 20 June 2012 - 08:49 AM
Okay so I will get a new headgasket, an original volvo one this time. But why the new bolts? The engine hasn't run yet. Are those bolts now prone to breaking? (They were new)
#10 lookforjoe
lookforjoe
  • 9,790 posts
Posted 20 June 2012 - 10:42 AM
The bolts have already been stretched, they are designed as single-use bolts. Doesn't matter whether you ran the motor or not. You've already used them twice, and (over) torqued them the 2nd time. It makes no sense to risk premature failure by trying to use them over again.
#11 Boxman
Boxman
  • 125 posts
Posted 20 June 2012 - 11:09 AM
Okay thanks for the info.
#12 98FORCED5
98FORCED5
  • 23 posts
Posted 20 June 2012 - 03:06 PM
I don't know about everyone else, but I don't torque down, remove, and then re-torque head bolts.
They are tork to yield. This means, to attain correct values, single use only.
Probably slip by, but if you want to do it right, should get new bolts or the gasket will be least of your worries.
Just a friendly notice.
