94-2000 Engine 2001+ S60/v70
11 replies to this topic
#1 optimus prime
optimus prime
  • 1,378 posts
Posted 02 June 2012 - 08:51 PM
Can it be done? I read a little about some of you dropping rn blocks in 94-2000 cars.so i was wonderig if the reverse was possible . Not saying im goig to attempt this or anything even remotely like that just wondering if its been done or could be done.
1998 S70 NA
1997 850 GLT
#2 Commander Riker
Commander Riker
  • 2,806 posts
Posted 02 June 2012 - 10:39 PM
Only as an NA. :-/
1998 V70 R AWD - M66 & 2.5T RN swapped - Stage 2
2007 Dodge Ram 1500 QC (Daily)
#3 optimus prime
optimus prime
  • 1,378 posts
Posted 03 June 2012 - 12:30 AM
Why only as an NA?
1998 S70 NA
1997 850 GLT
#4 SlapShot
SlapShot
  • 321 posts
Posted 03 June 2012 - 12:51 AM
Shooting in the dark here but you could probably use an older bottom end mated with an 01+ head and run that in a P2 S60/V70. Would probably need to fiddle with the accessory rack bracket and switch to the 99-00 oil pan w/cooler and other minor things though.
1998 S70 T5m - Nautic Blue
Koni FSD, Eibach ProKit, Meteors, Bosch H3 Projector Fogs, Single Mass Fly, 850R Clutch, Samcos, Rebuilt 16T, Hartford Whalers Plate Frame
#5 Commander Riker
Commander Riker
  • 2,806 posts
Posted 03 June 2012 - 12:52 AM
Why only as an NA?
Was kidding, bro.
#6 lookforjoe
lookforjoe
  • 9,786 posts
Posted 03 June 2012 - 12:55 AM
Like most things, it is possible, but pointless. Certainly not a performance modification :lol:
#7 RedStar
RedStar
  • 60 posts
Posted 03 June 2012 - 07:45 AM
Only as an NA. :-/
Why comment if you are going to say something dumb and completely irrelevant
96 850turbo - Daily: Exhaust, intake, ARD green
01 Viper RT/10 - Mildly modded
#8 SKI-R
SKI-R
  • 118 posts
Posted 03 June 2012 - 02:38 PM
Please tell me you intended that to be ironic (not moronic) in THIS thread!
#9 mdlimy
mdlimy
  • 3,381 posts
Posted 03 June 2012 - 05:56 PM
#10 optimus prime
optimus prime
  • 1,378 posts
Posted 03 June 2012 - 08:09 PM
Im sure its possibe to put any engine that fits in the engine bay. I should have been more clear with my question. What issues would one run into most likely if one were to attempt this. For example would use an ecu from the older engine or one that matched the car.
Would the engine harness need to be matched to the car or the engine or modified to be a combination of the two? Or would you have to use something completely different.
would the engine mount right up or would something need to fabricated?
1998 S70 NA
1997 850 GLT
#11 lookforjoe
lookforjoe
  • 9,786 posts
Posted 04 June 2012 - 02:21 AM
You would only use the long block (excluding oil pan), not any EMS components, all those would need to be retained from the vehicle. Immediate serious issue would be lack of VVT on older head.
Older torque mount & bracket would have to be used, front engine mount bracket, basically all engine side brackets would be needed. Depending on the year, the oil cooler (metal) return line would have to be sourced from yet another year to make it work.
Anyway, basically the inverse of any of the documented RN into 850 swaps, so you'd probably want to look at those for guidance.
I would say the VVT issue would be a deal breaker since the CEL's from that would send the system into hysterics.
#12 optimus prime
optimus prime
  • 1,378 posts
Posted 04 June 2012 - 03:11 AM
wow. haha that was an awesome answer.
1998 S70 NA
1997 850 GLT
