97 850R Ecu
18 replies to this topic
#1 RED 97 855R
RED 97 855R
  • 64 posts
Posted 08 June 2012 - 07:36 PM
I need to find a 97 850r ecu if anyone has one for a good price.
97 855R 206k, CUSTOM FRONT MOUNT INNERCOOLER, Stock air box with K&N filter, JAPAN MANIFOLD, 6K headlight bulbs, 6k fog light bulbs, MSD COIL CUSTOM MADE 8MM SPARK PLUG WIRES, OBX EXHAUST, OBX STRUT BAR. 16T TURBO. LED bulbs inside the car.
#2 volvoguy23
volvoguy23
  • 428 posts
Posted 08 June 2012 - 08:42 PM
You try ebay? Ive seen them on there plenty a times.
'94 850 turbo wagon: GREEN on tan 15g, catless, ARD white, mbc set to 14lbs, custom cold air intake,
'97 850R sedan: RED on black bought as of 11/18/12.
'85 760 turbo sedan
#3 atefitty
atefitty
    Manuals tighten my pants
  • 600 posts
Posted 08 June 2012 - 09:20 PM
I have one, what is your offer?
1997 850R
IPD Strut Brace, IPD Boost Guage, EST Intake, TME Catback Exhaust, Bilstein Struts/Shocks, TME Lowering Springs, Wastegate adjust to 6psi, European Side Markers...just new, black jewels and ECU upgrade....next : finally a downpipe!
#4 MattyXXL
MattyXXL
  • 2,457 posts
For the price you going to spend on an R ecu on eBay why not get a white tune from lucky?
1996 854 T-5 Modded, But who really Cares
1995 Yellow 854 T5-R Bone Stock!
http://www.floridavolvocommunity.com/
#5 SKI-R
SKI-R
  • 118 posts
Posted 08 June 2012 - 11:23 PM
^^ best advice. AND you can switch to Motronic 4.4! :tup:
#6 Platinum850Wagon
Platinum850Wagon
  • 257 posts
Posted 09 June 2012 - 12:47 AM
Got mine at car-parts.com
1996 855 Platinum Edition/2nd owner/Stainless Steel Brake Lines/Red Calipers/OBX V2 Strut Bar/Silicone Plug Wires/850R ECU/AC Delco BCS/V70 Tail Lights/Memphis, TN
#7 68123GT
68123GT
    The Boss
  • 698 posts
Posted 09 June 2012 - 01:56 AM
Have one out of 96 R if you are interested... PM me an offer?
#8 RED 97 855R
RED 97 855R
  • 64 posts
Posted 09 June 2012 - 06:47 PM
If I go that route I'm going to get the GREEN tune from Lucky. That would be much better than a WHITE tune.
quoIf I go that route I'm going to get the GREEN tune from Lucky. That would be much better than a WHITE tune.
#9 Kevin.
    I'm 22 and I love anal
  • 7,285 posts
Posted 09 June 2012 - 06:54 PM
already looks like you have some decent mods on your car, for the money a green tune would be right up your alley considering how much people want for stock ECU's at junkyards and on eBay
#10 MattyXXL
MattyXXL
  • 2,457 posts
Posted 09 June 2012 - 07:27 PM
Yes it would, but if your looking for an R ecu which you stated, just go with the white for now... then Re tune to the green later, or even better do some timing work and a K24 and go BLUE!! :ph34r:
#11 Kevin.
  • 7,285 posts
Posted 09 June 2012 - 07:36 PM
once you go black you never go back?
whoooooops we're talking about ECU's
#12 MattyXXL
MattyXXL
  • 2,457 posts
Posted 09 June 2012 - 07:37 PM
ECU's not doods... :P
#13 Kevin.
  • 7,285 posts
Posted 09 June 2012 - 07:38 PM
that sounded way more gay than I intended
#14 RED 97 855R
RED 97 855R
  • 64 posts
Posted 09 June 2012 - 08:12 PM
I just fixed my ecu. So my car is now running. I think that I will get with Lucky and have him make a GREEN tune ECU. People just want way to much for a stock R ECU. I think with everything that I have done to my car a GREEN tune will work pretty good that is until I build an engine for a BLACK tune.
#15 MattyXXL
MattyXXL
  • 2,457 posts
Posted 09 June 2012 - 08:18 PM
HELL YES!!!
Lucky will take care of you! It will be the best decision you ever made aside from buying the car!
#16 RED 97 855R
RED 97 855R
  • 64 posts
Posted 09 June 2012 - 08:31 PM
HELL YES!!!
How hard is it to install the N/A cams? Do you have to do any mods to make them work? How much better are they than the stock cams?
#17 MattyXXL
MattyXXL
  • 2,457 posts
Posted 09 June 2012 - 09:09 PM
93 N/A's have the highest lift, just put them in like regular cams, set the timing and you can run them just like that....
then to get the biggest bang for your buck, get the cams adjusted... you will be really pleased.
#18 RED 97 855R
RED 97 855R
  • 64 posts
Posted 09 June 2012 - 09:12 PM
What do you mean get the cams adjusted, are you talking about advance or retard the cam sprockets? What else would be good to do? like intake manifold, or throttle body?
#19 Kevin.
  • 7,285 posts
Posted 09 June 2012 - 09:17 PM
for the intake manifold you can use a N/A intake manifold, just make sure to port and you'll be fine. also, you can use a N/A throttle body with a 960 throttle plate to really open everything up.
that or get a racing labs plenum intake for $1300 lol
