Missfire In Boost
Posted 09 June 2012 - 11:47 PM
Any ideas?
1998 v70xc with 16T, whites, ard green tune 14psi, 3" catless exhaust, FCP Hoses, Boost Gauge, afr gauge
Posted 09 June 2012 - 11:55 PM
I have a 98 v70 xc with a 16t, white injectors, t5 ecu I changed the front oxygen sensor today and on the way home, under full throttle I get a p0302 code, only in boost
Any ideas?
1969 Dodge Super Bee - 440 Six Pack
Posted 10 June 2012 - 01:08 AM
They are bosch platinum
Posted 10 June 2012 - 01:32 AM
That could be your problem right there. My car ran like shit on platinum plugs.
Just go with coppers.
Posted 10 June 2012 - 02:16 AM
Posted 10 June 2012 - 04:20 AM
Posted 10 June 2012 - 05:10 AM
1998 V70 R AWD - M66 & 2.5T RN swapped
2007 Dodge Ram 1500 QC (Daily)
Posted 10 June 2012 - 03:34 PM
Either Volvo plugs or cheap coppers. You'll be shocked how much better the cheap aftermarket copper plugs will perform over the expensive aftermarket platinums.
Posted 10 June 2012 - 03:48 PM
Yea, I run either the Bosch Super Plus copper plugs for my T5, or NGK BKR7E or 6E plugs depending on what heat range I want.
Could you go into more detail with the heat range thing? Are you talking about combustion temps? how does it affect performace and gas mileage?
Thanks!
Posted 10 June 2012 - 04:59 PM
Posted 10 June 2012 - 05:08 PM
However, if you are running stock boost levels (I'm not), then the OEM heat range plug should be fine. I experimented with the heat ranges and found my car works pretty well with a colder plug in the summer time. I gave a set of the colder plugs to my buddy (Korruption) who is running a 98 V70R and he too benefited from the colder plugs, or at least no longer gets misfire codes (he has been plagued with them).
http://www.ngksparkp...p2.asp?mode=nml
Thanks!
Posted 10 June 2012 - 05:44 PM
That could be your problem right there. My car ran like stuff on platinum plugs.
What he said..Or go with OEM
IPD Strut Brace, IPD Boost Guage, EST Intake, TME Catback Exhaust, Bilstein Struts/Shocks, TME Lowering Springs, Wastegate adjust to 6psi, European Side Markers...just new, black jewels and ECU upgrade....next : finally a downpipe!
Posted 10 June 2012 - 05:45 PM
----PERFORMANCE VOLVO PARTS----
#14
Posted 10 June 2012 - 06:48 PM
Follow this link for a good discussion. In summary, I run the colder NGK plug (7E) in the summer time when the temps are higher just to prevent an additional source of heat that might pre-ignite the fuel mixture. The NGK 6E is the factory heat range plug and I run the factory heat range plug when the temps are colder. It shouldn't affect gas mileage, but like I said, with a colder plug it should prevent being a cause of a misfire with the mixture pre-igniting, so overall performance should go up since the engine is not misfiring and timing then being pulled.
I'm not running anywhere close to stock. Thanks for the info, in hot california, i should get a gain out of these. (Also im gapped to .023 soooooo)
#15
Posted 10 June 2012 - 06:58 PM
#16
Posted 10 June 2012 - 07:12 PM
What boost level you running on the 16T? 15psi is about the effective limit for a 16T. And .0023??? don't need to go that small. I think the smallest most people run is .0026.
17 psi on ard green. And i know, but on the crap gapper i had it was the best choice. I'll try it differently with my new plugs. And i thought .0026 was too big for 17psi?
BTW, i'm assuming spark plug gap has a direct influence on mileage and performance? So running wider gaps would help me with both?
#17
#18
Posted 10 June 2012 - 08:33 PM
Lee, that gap seems awful small! ( too many zeros..) I run champions at .026 on a 16t @~15-16psi and my car doesn't disapoint...but I get misfires as the plugs wear(@15k the gap gets to ~.031+) so I re-gap every oil change and change them at every 3rd.What boost level you running on the 16T? 15psi is about the effective limit for a 16T. And .0023??? don't need to go that small. I think the smallest most people run is .0026.
Edited by scumcity14, 10 June 2012 - 08:35 PM.
Ziptied together S70 with a bitchin shift knob. Wanna buy it?
"Having a fast Saab is like coming out of the closet..sure you might surprise some people, but you're still gay."
#19
Posted 10 June 2012 - 09:15 PM
#20
Posted 10 June 2012 - 11:45 PM
Anyway, i'll get new plugs and gap them correctly. Thanks. Sorry for thread jacking
