Thanks in advance
left side
and right side
Posted 11 June 2012 - 03:30 PM
Posted 11 June 2012 - 04:22 PM
20G, ARD Black, 342whp/403bhp
Posted 11 June 2012 - 04:41 PM
Whats it made of? ABS, fiberglass, composite?
Posted 11 June 2012 - 06:48 PM
if you have the broken off pieces you can plastic weld them, or make a FG mold and make a new FG one...ABS
1996 854 T-5 Modded, But who really Cares
1995 Yellow 854 T5-R Bone Stock!
Posted 11 June 2012 - 08:47 PM
Posted 11 June 2012 - 09:36 PM
Unfortinately no pieces left, probably will be trying to repair, if not, I got it cheap anyway, will just get rid of it.if you have the broken off pieces you can plastic weld them, or make a FG mold and make a new FG one...
Or replace it.. for the money that youll be spending to repair it you are probably better off replacing it
Thanks for the tips, will be thinking about that.You can use the black ABS glue from Home Depot or Acetone to join repair pieces to the missing areas and fill the cracks. I used to grind ABS plastic, sweep up the filings and put them in a mason jar with some Acetone. Put the lid on it, let it sit, stir it till it becomes a paste then use the paste to join parts. Then sand the back and add reinforcement of larger ABS parts with a good amount of the ABS glue. Or, you can use the Rubber Bumper Repair from a paint store. Similar to bondo but made for the application. Either way you will have to add material. Then a lot of sanding.
Posted 11 June 2012 - 09:39 PM
Buy a new one.
'95 850 GLT 228k M56H ARD 850R/T5-R STUFF
Posted 12 June 2012 - 03:40 AM
I used to use Dynatron 660 for repairs like this or small fabrication but its not made anymore. Not sure what Bondo/3M is replacing that product with or why they discontinued it.Or, you can use the Rubber Bumper Repair from a paint store. Similar to bondo but made for the application.
99 V70R98 V70 GLT
Posted 12 June 2012 - 06:31 AM
Posted 12 June 2012 - 07:57 AM
Bought it when I was living in Ireland 4 years ago.where did you get the lip from, or do you know where the previous owner got it?
Posted 12 June 2012 - 04:34 PM
I thought you were the only asian Canadian......your like a unicorn that poops Snickerdoodles on santa's tummy tum
Posted 12 June 2012 - 05:30 PM
Posted 13 June 2012 - 06:56 PM
