I have cleaned the ignition switch plug with contact cleaner and have unplugged it and there is still constant voltage at the blower motor plug. I've also disconnect the one temp sensor on the passenger side duct and also disconnected the control unit with the same results. I have pulled the blower unit plastic backer off... The brushes and armature is done, so the blower motor will need to be replaced. I've also scanned for codes and there isn't any.
If anyone could help me out, it would be greatly appreciated
