What Does It Take?
#1
Posted 12 June 2012 - 08:33 AM
I didnt know a s s was a "cuss" word on here i dont know where the hypnotoad thing came from but i think you guys get the idea.
'97 850R sedan: RED on black bought as of 11/18/12.
'85 760 turbo sedan
#2
Posted 12 June 2012 - 10:30 AM
Doesn't mean you can do it more than once,
Double R garage
#3
Posted 12 June 2012 - 01:54 PM
Then of course the new tech is Spray bore technology for blocks like Fords "Plasma Transfer Wire Arc' on the 2013 GT500.
Edited by dublin14, 12 June 2012 - 02:53 PM.
#4
Posted 12 June 2012 - 02:47 PM
#5
Posted 12 June 2012 - 06:43 PM
But I like my hotrod engines to be loud and obnoxious and they should scare people when you start them up, and pin you in your seat when you stomp on it.
#6
Posted 12 June 2012 - 08:06 PM
'85 760 turbo sedan
#7
Posted 12 June 2012 - 09:47 PM
Yea but on a nother note once you get traction the amount of power and tourque these motors makes its almost worth it...idk everyone has a sti, srt4, dsms, and of course hondas but no one ever has a well built volvo....i live des moines iowa and im starting to think im the only one into the 850's ive only seen a few but were owned by grandmas and moms and were completely stock... My goal is to have the fastest volvo in iowa.
The thing is, before you try and figure out what it takes, whats your goal, and whats the purpose of the vehicle? You want the fastest volvo in Iowa? at what? quarter mile? track car?
Also because its a FWD sedan, at some point you have to figure that there are better platforms to deliver 600HP effectively?
Uniqueness of it being a Volvo, will be a charm that wears out eventually. Having a car that can effectively put the power to the ground via RWD, or AWD, with proper LSD, etc... will in the end be more rewarding, less costly and overall a better setup for your expectations.
why 600hp? have you been in a 400HP volvo or a 450hp or a 500hp, to determine that just wasn't gonna cut it?
As anyone here will tell you anythign is possible, just need time and money, and at the end of it have a truly unique 600HP FWD volvo sedan that is no longer practical...
But to attain your goals, i'll answer your question (without using my own questions this time):
- Built block (rods, pistons, sleeved, etc...)
- preferably using newer RN head (and block, but this point is debatable)
- Cams
- Custom Intake manifold
- Custom Exhaust manifold
- Big Turbo
- Free flowing intake (with little to no bends)
- Free flowing exhaust (3" or larger), mandrel bends only
- any reliable standalone, VEMS, MS, civinco, etc...
- proper tune for setup
- upgrading suspension and brake components to cope with added power...
- be prepared as its not an easy process, and if you're really looking at spending the time and money to truly get into a 600HP volvo sedan, realize what kind of budget you are starting with, and then realize that for that kind of money there is so much more out there... that isn't "sti, srt4, dsms, and of course hondas" or Volvo...
2012 Jaguar XFR - 510HP and 461TQ
2012 Acura TSX A-SPEC 6spd1996 Volvo 850 Platinum Edition SOLD!!! "R" Exhaust Manifold, Garrett Stage III 54 Trim T3/T4 Hybrid Turbo, 550cc @ 3bar Injectors, Racelab Intake Manifold, 3" Full SS Exhaust, TurboTuner, CAI, BOV, Custom FMIC Setup, Crane Ignition, 5spd Swap, Walbro Fuel Pump, KONI FSD & Eibach Springs, IPD Sway Bar Kit, IPD BBK, 384WHP & 363WTQ
#8
Posted 13 June 2012 - 01:34 AM
I completely understand what your saying and no ive never been in a 400hp volvo but i have been a 350 hp.srt4 and i would love to see 450 out of my volvo...fastest meaning 1/4 mile since there isnt any tracks in iowa i dont believe and ive always loved drag racing. And i know what you mean by effectively putting down that kind of power i wouldnt want 600hp but more like 450 and that is my goal for my t5. I was just curious like i said on what it takes for these motors to produce that kind of power...and you pretty much answered my question. And are you guy that had the 20g with stock internals??? If so your build really caught my eye and im kinda thinkin about a 20g for now.
'85 760 turbo sedan
#9
Posted 13 June 2012 - 07:46 PM
1998 V70 XR M66 PTE6262 BB Built '04 2.3l Block Wiseco Pistons 147mm H-Beams '03 Ported Head EnemY21Cams TurboTuner 710cc Inj, DW300, 3" DP back Dual Magnaflow 14834's Apr 2013 408WHP AWD (@7925rpm) 347WTq(@4400rpm)@18psi LGSpeed Header Custom Intake Manifold 30x12.5x3.5"Treadstone FMIC Spec Stage III+ SO603FS Kaplhenke CoilOvers
#10
Posted 14 June 2012 - 01:18 AM
'85 760 turbo sedan
#11
Posted 14 June 2012 - 03:22 AM
I know that i said for now until i can build the motor then probably gt30 gt35 not sure.... gotta save up the money hehe. Guy on craigs has a big 16g off a evo, whats diff. Between that and say a 16t??
The shape of some stuff. Do some research?
1999 S70 Base w/ Manual - "5 BANGER" - IPD Springs and Sways, HD Endlinks, Bilstein TC Struts, HD Shocks, OBX Strut Brace, Lots of Poly, Custom Exhaust, Amaltheas, Pioneer Double DIN
#12
Posted 14 June 2012 - 03:56 AM
99 V70 R. Silver & charcoal with a few mods.
#13
Posted 14 June 2012 - 04:21 AM
Edited by dublin14, 14 June 2012 - 04:32 AM.
#14
Posted 14 June 2012 - 11:42 AM
20g is not a 450hp turbo. You need to go larger. Figure 5-6grand, easy.
A Super 20G will push 450hp maybe not 450whp but certainly 425ish whp.
To make that kind of power is extremely simple just parts cost...
1. Cut Valves on stock head and clean up flow. ($500 max)
2. Port Stock Manifold/Machine lip (Free)
3. Install Super 20G (Water/oil feed lines) $700
4. Make a Front mount Intercooler $300
5. Down Pipe to 3" + exhaust $700
6. Big Injectors from Marren $500
7. Connecting Rods from China $400
8. Haltech E11v2 or Platinum 2000 $1500-2300 (could do megasquirt 3 for like $600)
9. Head gasket kit $300
10. Rod Bearings $300
Total $5,000-$6,000
Edited by Fishey, 14 June 2012 - 11:44 AM.
Then again you are quite a douche so who am I to assume you couldn't pull that off...
#15
Posted 14 June 2012 - 12:23 PM
