Tracs And Abs On
11 replies to this topic
#1 xallenx
xallenx
  • 327 posts
Posted 15 June 2012 - 06:51 PM
Hi,
I noticed this morning when I started the car that the ABS and TRACS lights remained ON. It usually turns off after starting but not today. It is now consistently on and remains on until I turn off the car. No problems with braking, rides fine. Would it be the module or the sensors? Thanks. This is on my 1995 850 GLT
95 850 GLT & 06 XC90 FW 87K+
http://s25.photobuck...lvo 95 850 GLT/
80K+ miles on 2nd motor, got it for $500 bucks!!! Now w 6k HIDs/17" Canistos..
#2 Jardim
Posted 15 June 2012 - 07:30 PM
it could be either the module or the sensors, maybe a fuse for the module too. check the fuses, if none of the ABS related fuses are blown, then its either the module or the sensor.
#3 Jazzy_J
Jazzy_J
  • 309 posts
Posted 15 June 2012 - 07:31 PM
It's the module. Common issue with these cars.
Check out
https://www.midwest-abs.com/
He can hook you up with all the info/service needed.
#4 g00b86
g00b86
  • 58 posts
Posted 16 June 2012 - 01:23 AM
+1 on midwest-abs. Just ordered mine on wednesday. Just PM him. I suggest if you cannot drive without a speedo operational you get the exchange service over the trade in program.
98 S70 T5M // ARD Green (stock 16T @ 17psi) // EST Intake // EST DP + Exhaust // MSD ignition // EST RIP // IPD HD TCV + CBV
#5 Matty Moo
Matty Moo
  • 1,923 posts
Posted 16 June 2012 - 02:34 AM
Has it ever come on and stayed on before?
Usually they go intermittent first. The thing is, if any of the circuits in the system are open, the lights will come on and stay on at startup.
When you start the car, the abs system does two self diagnostic tests.
One at startup. All of the wheel sensor circuits and related abs system circuits are tested for continuity. If all is good, the lights go off like they normally do.
Then another when you hit 8mph for a 96-98. This is when the pump motor gets its split second test.
Or.... Your module just decided to take a dump that particular day. If you've played with anything in the front end recently, check you wiring and plugs where they plug into the wheel sensors.
#6 T5BLACKattack
T5BLACKattack
  • 478 posts
Posted 16 June 2012 - 03:02 PM
If your really worried, ohm out your wheel sensors, or check voltage while spinning the wheel.
1998 S70 GLT-5 427 / 1998 S70 T5M 019
#7 xallenx
xallenx
  • 327 posts
Posted 16 June 2012 - 09:05 PM
UPDATE: I finally was able to inspect the front sensors. Took of the passenger side wheel and there were axle grease all over the place. The CV boot tore so it covered the sensor with grease. I got the axle at O'reillys with lifetime warranty. TIme to change the axle. Has anyone able to remove the axle without having to loosen up the ball joint?
#8 xallenx
xallenx
  • 327 posts
Posted 16 June 2012 - 09:15 PM
I found this:
I remember last time I struggled separating the ball joint so I'll try this route.
#9 xallenx
xallenx
  • 327 posts
Posted 17 June 2012 - 01:18 AM
Done!! This way is a lot easier than the ball joint way. You don't need to loosen the top three strut nuts. The hardest part was pulling the old tranny seal off. Mine was leaking.
#10 98FORCED5
98FORCED5
  • 23 posts
Posted 20 June 2012 - 03:35 PM
Check out
Don't instantly condemn your moudule. They aren't cheap. :glare:
Check the sensors, Check the connector to the module itself. Check fuses, wiring, all in order of cost, like previously stated.
Glad your done, my above post can be for future readers....
#11 MattyXXL
MattyXXL
  • 2,466 posts
Posted 20 June 2012 - 03:50 PM
$35 at Junk Yard, for a used most likely not working module...
But no need for that... just send it off to Mid-West... Done/Fixed/With a warranty
1996 854 T-5 Modded, But who really Cares
1995 Yellow 854 T5-R Bone Stock!
http://www.floridavolvocommunity.com/
#12 JagsT5R
JagsT5R
  • 95 posts
Posted 30 June 2012 - 06:52 PM
No one has mentioned it yet, so I thought I would. Have you wiggled the key to see if the lights go off. One of the issues with the ignition switch wearing out is that it will trip the ABS and Tracs lights on the dash. Just a thought.
