Rear Door Size - I Know There's A Sticky
Posted 20 June 2012 - 12:53 AM
Mind you, the 5.25" speakers fit perfectly into the front doors. So are the rears some funky size between 5.25" and 6" or would 6" fit without cutting the hole bigger?
'95 854 T5M 195k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue - DEAD - To be parted out
'04 S60R - 125k
Posted 20 June 2012 - 11:13 PM
Posted 21 June 2012 - 01:55 AM
'04 S60R - 125k
Posted 21 June 2012 - 02:25 AM
All the threads on here say you have to cut metal to fit 6.5" in there though. I really just want a drop in unit if I can. I'm wondering if a standard 6" would fit it correctly.
Unless there is a big difference in doors from an 850 to a V70, Mine, a V70; I didn't have to cut any metal, the Polk DB651s 6.5 fit nicely in the factory bracket once the OEM speaker is removed from it, That's about as drop in as your going to get.
Posted 21 June 2012 - 10:16 AM
I'm pretty sure the stock 70 series speakers actually were larger than the 850's.Unless there is a big difference in doors from an 850 to a V70, Mine, a V70; I didn't have to cut any metal, the Polk DB651s 6.5 fit nicely in the factory bracket once the OEM speaker is removed from it, That's about as drop in as your going to get.
'04 S60R - 125k
Posted 24 June 2012 - 07:35 AM
Yes, they are.
1999 S70 Base w/ Manual - "5 BANGER" - IPD Springs and Sways, HD Endlinks, Bilstein TC Struts, HD Shocks, OBX Strut Brace, Lots of Poly, Custom Exhaust, Amaltheas, Pioneer Double DIN
Posted 29 June 2012 - 04:04 AM
98' S70GLT 237K miles ... still on original Turbo..yes it's leaking like a sieve.
