Torque Converter
4 replies to this topic
#1 White 850R
White 850R
  • 99 posts
Posted 20 June 2012 - 02:56 AM
Hey everyone quick question is the 850 torque converter and 98 S70 torque converter the same? My S70's trans went out and I had a spare 850r trans but not the torque converter, will the S70's torque converter work with the 850's trans on an 98 s70 engine?
Thanks Greg
96 Black 854R... SOON TO COME
95 Black 854R 225K Ipd/TME exhaust, sways, springs, koni FSD, RIP, CJ strut brace, ipd endlinks, SS brake line, Samco stuff, projectors. I call it the "ipd mobile"
89 Silver 300E 260K Euro lights, 18" AMG monoblock II's, Bilstein Sports, First gear start module, and carbon fiber stickers.
#2 volvoguy23
volvoguy23
  • 428 posts
Posted 20 June 2012 - 03:23 AM
Yep.
'94 850 turbo wagon: GREEN on tan 15g, catless, ARD white, mbc set to 14lbs, custom cold air intake,
'97 850R sedan: RED on black bought as of 11/18/12.
'85 760 turbo sedan
#3 Ghost Shadow
Ghost Shadow
  • 4,090 posts
Posted 20 June 2012 - 06:17 PM
but...there is a buttt.....make 100000000000000% sure there is no junk inside your old converter or else it shall destry your new trans
#4 Matty Moo
Matty Moo
  • 1,919 posts
Posted 21 June 2012 - 02:48 PM
Make sure you install it correctly.  It goes on in two stages.  It will slide on in any position, but it has to go down another notch after that.  Like a 16 year old getting his first piece of tail, you likely won't hit it right the first time.  You'll have to find that spot where it bottoms out all the way.
When I did mine, the torque converter and transmission were both extremely exhausted and satisfied when it was done.
#5 brad850
brad850
  • 1,111 posts
Posted 21 June 2012 - 11:51 PM
Yup ^^
You'll know it's installed correctly into the trans if it rubs a little when you spin it by hand. Just be careful not to get your fingers caught under it when
you're trying to get it in that notch. It might drop in unexpectedly and its preeeeettty heavy.
Then when you bolt up the trans to the engine pull the tc towards the flex plate. Hand crank the engine to get all 5 torx bolts.
This is very important cause if you don't do this your trans is gonna go boom
96 850R red/beige
18t, R manifold, ARD, lot more
Infinity speakers / Kappa perfect 12"
