Drop In Speakers For Doors On My 855R... Opinions?
28 replies to this topic
#1 gmsgltr
gmsgltr
  • 5,499 posts
Posted 25 June 2012 - 08:11 PM
looking for drop in speaker options for my 96 855r
currently running the stock ones and they bottem out under heavy bass and pop. mostly when the speed sensitive audio kicks in but also just when they are load and heavy mid bass
i remember looking into this once before and reading something about
8ohm vs 4ohm stock speakers etc.
enlighten me...
thanks in advance,
greg
- Greg - '96 Red/Tan 855 R - M - 104k miles - '98 Blue/Charcoal V70 T5 - M - 170k miles -
#2 Kevin.
    I'm 22 and I love anal
  • 7,536 posts
Posted 25 June 2012 - 08:17 PM
pretty sure the stockers are 8 ohm.
door speakers are 5 1/4" I believe
FOR SALE THREAD $1900
#3 papariccardo
papariccardo
  • 41 posts
Posted 25 June 2012 - 10:30 PM
8ohm? That's an issue for replacement head units/ amps, and explains why my car sounded sh!t with a new head unit.
I sure hope the size is 6.5", I've just bought 4ohm components to replace the stockers, as well as amps, subs & another new head unit.
Old Brick fan down under in New Zealand. 1994 850 T5 wagon, 120k miles, bought US$1.2k
#4 bergmjs
bergmjs
  • 2,062 posts
Posted 25 June 2012 - 11:42 PM
Front doors are 5.25", rear doors are 6"
I should say those are for an 850, 70 series are larger.
'95 854 T5M 195k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue - DEAD - To be parted out
'04 S60R - 125k
#5 papariccardo
papariccardo
  • 41 posts
Posted 26 June 2012 - 01:44 AM
Bugger! The kit I bought is suitable for the 70 then, not the T5.
What are the rear doors in the 850? 6"? Odd size. Will 6.5" fit?
#6 optimus prime
optimus prime
  • 1,507 posts
Posted 26 June 2012 - 02:00 AM
http://volvospeed.co...stereo-threads/ this is stickied at the top of the audio forum papariccardo
1998 S70 NA
1997 850 GLT
#7 Platinum850Wagon
Platinum850Wagon
  • 258 posts
Posted 26 June 2012 - 02:33 AM
Most 5.25" will fit the front doors. Some better than others. I just changed mine out. The Volvo speakers in the front doors are 4 ohm. Says so on the back of the speaker. The back doors carry 8 ohms. Tried to put some 6.5" in there but they didn't fit. On my last 855 I put some 4 ohm 6" coaxials in the back door and they sounded crappy. I've found a few 6" 8 ohm and a couple of cheap 5.25" 8 ohm. Not sure which I am going to try this time.
1996 855 Platinum Edition/2nd owner/Stainless Steel Brake Lines/Red Calipers/OBX V2 Strut Bar/Silicone Plug Wires/850R ECU/AC Delco BCS/V70 Tail Lights/Memphis, TN
#8 gmsgltr
gmsgltr
  • 5,499 posts
Posted 26 June 2012 - 04:47 PM
ugh
that speaker sticky is useless... nobody was specific enough and its old lol
i just didnt want to buy any 5.25" speaker then have it not fit without major modification
i will keep searching :(
#9 bergmjs
bergmjs
  • 2,062 posts
Posted 26 June 2012 - 10:24 PM
Everyone in there says the rear doors are 5.25", which I found to be very incorrect when I bought a set and tried to put them in my rear doors. The stock speaker measures ~5-7/8" and is slightly ovaled to fit a wave-guide that clips onto the back of it.
I just bought these for what I thought was the rear doors, but they fit perfectly into the front doors and sound pretty good for ~$50 for the set.
http://www.amazon.co...ils_o02_s00_i00
'04 S60R - 125k
#10 BEJinFBK
BEJinFBK
  • 1,931 posts
Posted 27 June 2012 - 12:32 AM
Easy fix - Add a sub and quit hammering the door speakers.
#11 gmsgltr
gmsgltr
  • 5,499 posts
Posted 27 June 2012 - 06:16 PM
i have a sub :)
thanks, and yea, everyone says "oh youll be fine they will fit" lol
#12 andyb5
  • 3,291 posts
Posted 27 June 2012 - 07:21 PM
Since you have a sub, you should look at adding either a high pass filter or in-line "bass blockers" to cut out the lowest frequencies from heading to the door speakers.
#13 BEJinFBK
BEJinFBK
  • 1,931 posts
Posted 28 June 2012 - 03:53 AM
+1
Balance your system.
#14 gmsgltr
gmsgltr
  • 5,499 posts
Posted 28 June 2012 - 02:14 PM
hmm thanks guys i will look into that.
either way, i still need to replace the door speakers. they pop and bottom out under bass in general
was hoping to get a "i used these speakers XXXXXX and they dropped in fine" lol
#15 Tommy.
Tommy.
  • 5,746 posts
Posted 28 June 2012 - 04:50 PM
That would be too easy Greg :lol:
#16 gmsgltr
gmsgltr
  • 5,499 posts
Posted 28 June 2012 - 06:40 PM
yea nobody is ever that specific on vs :(
#17 bergmjs
bergmjs
  • 2,062 posts
Posted 29 June 2012 - 12:00 AM
I'll let you know next week when my second attempt for the rear doors arrives.
'04 S60R - 125k
#18 gmsgltr
gmsgltr
  • 5,499 posts
Posted 29 June 2012 - 12:01 AM
ooooo alright thanks!
#19 TaskMule
TaskMule
  • 1,342 posts
Posted 29 June 2012 - 02:06 AM
MB QUART EKA113 5.25
DIRECT FIT IN MY 855R FRONT DOORS.
98 V70R AWD
128k miles, 18T, 3" DP, ABM's, SAS delete, Samco's, K&N panel, white's, 18" Pegs/RE760's
#20 BEJinFBK
BEJinFBK
  • 1,931 posts
Posted 29 June 2012 - 02:33 AM
Just be sure to avoid heavy bass making it to your door speakers, new or old. They just aren't made for it.
