Cruise Control Doesnt Work, Then It Works, Then Doesn't
9 replies to this topic
#1 Doityourselfer
Doityourselfer
  • 453 posts
Posted 28 June 2012 - 09:42 PM
I purchased '96 850Turbo
cruise control wasn't working when I drove the car home on the highway. If I pushed the switch to try to activate it, there was no reply from the car.
today for the heck of it I tried it again while on the highway, and lo and behold it worked perfectly, holding the speed I set, and allowing me to slow down only by pushing the buttons, etc.
later today I tried it again, and nothing doing. back to not working again.
any Ideas?
How many volvos have you owned?
#2 Ghost Shadow
Ghost Shadow
  • 4,093 posts
Posted 29 June 2012 - 01:30 AM
abs module. cruise pump, abs sensors is a start
#3 winterhalo
winterhalo
  • 262 posts
Posted 29 June 2012 - 04:33 AM
Here is a link to a step by step for a 95-96 Euro spec cruise control.
Must be very similar.
http://www.volvoclub...ntrolSystem.pdf
1998 V70R 110K miles
#4 winterhalo
winterhalo
  • 262 posts
Posted 29 June 2012 - 04:39 AM
And then check out the schematic for a '98.
should be able to correlate the two.
edit: Sorry, file did not upload. Too big.
#5 Turbobucket
Turbobucket
  • 47 posts
Posted 29 June 2012 - 02:45 PM
Take your foot and press up on the bottom of your brake pedal.
#6 troyhyde
troyhyde
  • 1,290 posts
Posted 30 June 2012 - 02:14 PM
The above is to check your brake pedal sensor (presumably). If it is failing or intermittent, or even just not correctly adjusted, you will not be able to activate cruise control. The car thinks you are riding the brake, and hence will not turn on cruise...
#7 Doityourselfer
Doityourselfer
  • 453 posts
Posted 02 July 2012 - 09:26 PM
I tried this today.. it seems to have nothing to do with it.
#8 Doityourselfer
Doityourselfer
  • 453 posts
Posted 05 July 2012 - 09:36 PM
this continues to drive me nuts.
today it worked all morning but by afternoon it stopped working...
I'm wondering what could cause an intermittent problem with the cruise control..?
#9 erikv11
erikv11
  • 2,870 posts
Posted 06 July 2012 - 03:27 PM
When the cruise acted this way on my car, there was a vacuum leak. I replaced the line from the firewall to the pump, been working great ever since. If you haven't replaced that line, or at least the rubber elbow right at the pump under the battery tray, I'd start there.
In that pdf that Winterhalo linked, there is a great troubleshoot guide for the vacuum system, pages 9-10. Try it.
'96 NA 855 - 111 k - daily driver
'95 R 854 - 177 k
#10 renns
renns
  • 177 posts
Posted 06 July 2012 - 08:25 PM
Check the vacuum line where it runs under the battery tray. Mine had chafed through at that point on my old 850. A quick splice with some rubber tubing, a bit of re-routing and it was fine for years.
1994 Volvo 855 - >400k km (long gone)
1998 V70 AWD 5-speed - 235k km - 2wd now. Good bevel gearbox and propshaft available!
