Mirzams Help
Posted 07 July 2012 - 09:24 PM
I went to mount the wheels and they leave a gap between the hub and the wheel clear the calipers fine. I stacked on 2, 5mm spacers and it looked good 1, 5mm would leave slop
I remember something about enlarging the bore of the hub portion of the wheel but thought I would be clear with that being this is an s60...
So, pickup 10mm spacers all around (probably going to need extended lugs as well eh?) or look is the problem the wheel it self aka needing machining
I have pics of what I'm talking about but figured this was good enough of a descript
Posted 07 July 2012 - 11:16 PM
Posted 07 July 2012 - 11:45 PM
Posted 07 July 2012 - 11:47 PM
Posted 10 July 2012 - 07:22 PM
Picked up a set of Mirzams 18x8 45et, to replace Eudoras 18x8 et49
Are you really asking this? Travis I have lost faith in you..........forever!
Posted 11 July 2012 - 02:08 PM
Posted 11 July 2012 - 05:24 PM
Posted 11 July 2012 - 06:41 PM
Non hub centric spacers suck, you'll get a rough ride at any speed over 45 mph, no matter how well you center them. Get them bored out ($25/wheel at a machine shop) or run the right hub centric spacers.
Posted 11 July 2012 - 07:02 PM
Posted 11 July 2012 - 09:54 PM
Forget resale value. Think about driveability.
I am going to have to disagree with you here. I have driven on non-hubcentric spacer/adapters at well over 45 and experienced nothing but a smooth ride out of them.
Also, Motorsport Tech can make you adapters with varying centerbores. This is how I am running the Odysseus without them being bored.
Posted 12 July 2012 - 06:34 AM
if you want to turn them over in a year, then get hub and wheelcentric custom adapters made, and you can sell them to some S60 guys later....
I'd personally get the bores machined, because you can still sell them to S60 guys with smaller bore size....all they have to do is get $15 hub rings between their hubs and wheel bore....this is what i have on my Nebs.....my center bore is 65.1, and the bore on the Nebs is 67mm IIRC, so I just bought hubcentric rings for $15 shipped from Discount Tire or something, and they work great....no need for adapters etc....
Posted 12 July 2012 - 04:12 PM
#14
Posted 13 July 2012 - 11:34 AM
Pras that's the other issue, I have R-calipers for the front yet to go on. The calipers on there are actually physically larger than the R's (factory 320's) but I'd like to have a good amt amount of clearance to keep the paint nice. 10-15mm should be plenty. I'm sure there will be more S60's coming around in the coming years
right, but my statement still holds true....if you bore the wheels, you can bolt on standard 850/70 spacers with teh normal 65.1mm bore as long as you have hubrings....
as you might know, i've got 10-15mm spacers up front, and 25mm spacers rear, all standard 850 hub and wheel centric....all i did was get hub rings on all 4 corners and i'm good
I think you're going to end up spending more than $200 on 4 adapters, bolts etc, then just to get the bores machined, and hub centric rings....then, if you sell the wheels, you're going to be SOL on selling those adapters to anyone at that point....
but bored wheels with hub rings....easy sell for 850/70 and S60 guys, and your only cost in it would have been the $100 for boring all 4 wheels....
#15
Posted 13 July 2012 - 06:23 PM
But without spacers, he won't clear the calipers. So add another $100 to your cost, and in that case you're probably better off leaving the wheels intact and having adapters.right, but my statement still holds true....if you bore the wheels, you can bolt on standard 850/70 spacers with teh normal 65.1mm bore as long as you have hubrings....
#16
Posted 13 July 2012 - 07:21 PM
I want to say it can't be more then 10mm?
Edited by Mesoam, 13 July 2012 - 07:21 PM.
#17
Posted 14 July 2012 - 02:34 PM
right, but the spacers will still be for the 850/70 cars, and 85070 wheels, whereas adapters will be for the 850/70 cars with s60 wheels....
spacers will live on, adapters, smaller chance....
#18
Posted 14 July 2012 - 04:30 PM
#19
Posted 16 July 2012 - 07:13 PM
Lip on the hub is 10mm as best can be measured
Jr stated 1wk turnaround on the spacers.
#20
Posted 29 July 2012 - 02:41 PM
http://img.photobuck...am/DSC_0631.jpg
