Issues with the car: Previous owner said the car was stalling and hard to start. Passenger side windows did not work, busted fog light, torn drivers seat, ABS/TRACS light, fuel gauge not working, several minor dents and the car was dirty dirty.
CEL for the following:
P0300 multiple misfires
P0440 EVAP
P0455 EVAP
P0305 CYL 5 misfire
P0304 CYL 4 misfire
P0116 ECT sensor
P0103 MAF
P0243 WG solenoid A
I swapped the MAF, ECT & cleared the codes and so far so good. Vac lines, vac tree, IC piping all look good. I'm still waiting to see if the EVAP comes back and if so, i'll look more into it. The EVAP lines i have looked at so far look to be in tact.
ABS/TRACS will be fixed once Matty's unit shows up. I swapped out both passenger window switches and the windows now work again. Swapped the fog light, driver door seal, rear license plate holder, pulled and scrubbed all the carpets, vaccumed and wiped down the interior, cleaned the engine compartment, swapped in drivers seat and power passenger seat from my S70 parts car, pulled and scrubbed all the wheels, fixed the finder liner and threw some cross bars on the roof.
A few pics.. still needs a wash.
The only really outstanding issue is the bloody fuel gauge. I couldn't find anything in the paperwork that showed the fuel pump ever being done. If I do end up tackling this, I'm not going to drop the entire rear end, it will be either cutting the access panel or trying to lower/pry the tank and snake it out.
Does anyone have good photos of the fuel pump assembly showing the fuel sending unit? I'm a little confused as to how the system works/goes together. Looking on FCP, you have to select "V70 and XC70" in order to get 1998 to appear. In doing so, you are given the following: http://www.fcpgroton...1464/by_year/48
It doesn't specifically list a 98 XC?
Volvo V70 AWD Turbo 1998-1999 B5254T
Volvo V70 X/C AWD Turbo 1999 B5254T
Volvo V70 X/C AWD Turbo 2000 B5244T
Volvo V70 R AWD Turbo 1999 B5234T8
Volvo V70 R AWD Turbo 2000 B5234T3
It's showing the fuel pump assembly and fuel sending unit as seperate parts, I was under the impression the fuel sending unit is part of the fuel pump assembly? I suppose it doesn't make sense to replace just the sending unit, although I would prefer to keep the cost down as much as possible.
Thoughts?
