Ca Catalytic Converter Recommendations
13 replies to this topic
#1 Yea-but...
Yea-but...
  • 602 posts
Posted 16 July 2012 - 10:33 PM
So, I need to pass smog.
The magnaflow search option is stuff because i'm looking for 3" (OBX exhaust) and they have the volvo one listed as 2.5.
Basically, anyone know of a catalytic converter that will pass smog, and be 3"?
Many thanks!
PS. Part numbers are stupid and tell you nothing. :glare:
#2 Yea-but...
Yea-but...
  • 602 posts
Posted 16 July 2012 - 11:16 PM
*facepalm* delete this please
:idiot:
eh, what the hell. catalytic thread?
catalytic thread.
It seems that CARB/CA compliment converters only come in 2.5" or smaller from magnaflow
nvm, okay, im just gonna get off VS. Its time to stop posting.
http://www.magnaflow...universal=46009
Planning on using that. Any objections?
#3 CLobsinger
CLobsinger
  • 60 posts
Posted 17 July 2012 - 03:04 AM
http://yother.com/cj...-engine-03.html
CARB/ OBD2 compliant 3" cat I was planning on running with my new OBX setup for smog. They are right out of Alameda, so it should work just fine for you. A bit pricey, but it's high flow and not just direct replacement.
White '96 855 Turbo - Voxx MG3 17x7s, 302mm with E-line slotted rotors, M56H, ARD White Tune, MSD coil, Kingsborne 8mm wires, Hallman Pro mbc @ 15psi, Kinugawa Adj. WG, Short ram w/ Snabb intake pipe, Snabb manifold spacer, Heat wrapping, Silicone and Poly errywhere, Forge CBV, 27x6x3.5 FMIC, R mani, Full OBX w/ Coated DP, Bilsteins with IPDs, Angel eye headlights w/ HID retrofit, E-Z lip, blacked out and debadged. Future mods - '05 B5244T5, 19t w/ ARD billet wheel, Greens, and ARD blue
#4 Yea-but...
Yea-but...
  • 602 posts
Posted 17 July 2012 - 03:26 AM
your pic made me lol.
and thank you, it is pricey. I'm guessing because its high-flow?
I think ill go with that then. Thanks again. You'll have to take a ride when i get the 18t on ;)
It seems the "add to cart" button doesnt work.
#5 GV70T5m
GV70T5m
  • 36 posts
Posted 18 July 2012 - 04:56 AM
It's pricey because it's CARB compliant.
Just call CJ, he'll set you up. His number's on the contact page of that website, along with ordering info...
98 V70 T5m, Speedtuning stg 1, Brola 2.5 muff & ipd tip, K&N drop-in,17 PropusC 2pc(BBS) ipd SS brk lines sways wires & MSD coil,Koni FSD w ipd Blues.
#6 Yea-but...
Yea-but...
  • 602 posts
Posted 19 July 2012 - 12:00 AM
I figured, thanks
#7 prasamin
prasamin
    Bipedal Magnaflux
  • 17,055 posts
Posted 19 July 2012 - 03:24 AM
Weird....i bought a Magnaflow Race cat which is CARB/CA compliant.....and it is 3" diameter in and out......
This was about 7-8 years ago, but it passed smog in CA for about 4 years.....no issues...
#8 survolvo
survolvo
  • 2,932 posts
Posted 19 July 2012 - 03:41 AM
They changed things in '09.
This seems to be all Magnaflow has for CARB compliant.
http://www.magnaflow...layproducts.asp
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, ARD Billet 16t , Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo OEM Strut Tower Brace, Konis, IPD/TME springs, ARD Green Tune
#9 Yea-but...
Yea-but...
  • 602 posts
Posted 20 July 2012 - 03:29 AM
FYI, can't ship cats to CA. So all magnaflow options online are out. I'm going to try the site CLobsinger suggested
#10 survolvo
survolvo
  • 2,932 posts
Posted 20 July 2012 - 08:40 PM
I've got hoes in different area codes, so that's not a problem, but I think I might go with CJs anyhow.
1996 854 T5
#11 Yea-but...
Yea-but...
  • 602 posts
Posted 20 July 2012 - 11:41 PM
He got back to me pretty quick and answered my questions. He said he's been passing smog for a couple years with the same cat. I'm going with his.
#12 washdup
washdup
  • 838 posts
Posted 22 July 2012 - 01:31 PM
CJ's price is not bad for an OBDII CARB-certified 3" cat. The same 3" Magnaflows cost about that much even before the law changed and made them unavailable in CA.
1998 V70 T5m--18t, ARD Blue, SNABB intake, R mani, turboback.
2004 V70R 6m--SOLD 9/29/08
#13 RedStar
RedStar
  • 61 posts
Posted 22 July 2012 - 07:46 PM
I had a exhaust shop spread the inlet and outlet on my stock cat once. It was on a different car but I dont see why it wouldn't work on yours. Wont be as high flow as cj's but will work and cost less.
96 850turbo - Daily: Exhaust, intake, ARD green
01 Viper RT/10 - Mildly modded
#14 survolvo
survolvo
  • 2,932 posts
Posted 22 July 2012 - 07:56 PM
Exhaust shops can get in trouble for modifying a cat at all. They have gotten pretty strict with this stuff. They pay people to narc out shops, so everyone is very weary.
1996 854 T5
