Wilwood Dynalites & Spacers?
wilwood dynalite spacers
29 replies to this topic
#1 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 21 July 2012 - 09:02 PM
Does anyone know if I need to run spacers with Wilwood Dynalites and Nebulas?
#2 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 22 July 2012 - 05:01 AM
Also, does anyone know of a rotor that will fit a an 850 with the dimensions of 13" by 1"?
#3 P0RTER
P0RTER
  • 31 posts
Posted 22 July 2012 - 08:54 AM
S60R Front Rotors are 13".
Edited by P0RTER, 22 July 2012 - 08:56 AM.
Black 98 V70 T5 M56 (Hauls Ass)
Saffron 98 V70 R AWD (Hauls Groceries)
#4 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 22 July 2012 - 03:20 PM
Yes but what about the width?
#5 B Mac
B Mac
    Ginger Beater
  • 4,554 posts
Posted 22 July 2012 - 08:34 PM
Not sure if you're interested but these are still in the works....
http://volvospeed.co...bbk-for-850x70/
The name's Ben: '95 850, m56 w/ gripper lsd, Sachs 707 pressure plate w/ organic disc, built '02 RN 2.3L, worked '04 R head, Enem Y21 cams, Precision 5857B, ARD tune, blah blah blah
#6 survolvo
survolvo
  • 2,904 posts
Posted 22 July 2012 - 08:47 PM
:tup:
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, 16t w/ Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo Strut Tower Brace, Konis, IPD springs, few more things to come...
#7 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 22 July 2012 - 10:27 PM
Bought these: http://auctions.volv...type,ad_details
I take it the only thing I need is rotors, but I dunno if I need a spacer or not.
#8 Yellow95
Yellow95
    Grandpa G
  • 6,745 posts
Posted 23 July 2012 - 12:00 AM
you def wont need spacers/.
#9 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 23 July 2012 - 12:19 AM
And s60r rotors will work with it?
#10 lookforjoe
lookforjoe
  • 9,778 posts
Posted 23 July 2012 - 12:42 AM
Why wouldn't you ask the seller of the calipers? If they're selling them to fit a Volvo, they should know what rotor to use. If not, that's pretty lame.
#11 brad850
brad850
  • 1,104 posts
Posted 23 July 2012 - 12:57 AM
I'm the seller. I had problems with the guy I bought them off of... he accidentally got me the wrong caliper for the rotor he sold me.
I told him that I wasn't positive what rotor they would fit although he payed me before he asked the question.
I'm not too knowledgeable when it comes to brakes.
IF for some other reason they don't fit a volvo that I did not know about i'll be willing to give you a full refund.
I was under the impression that it there wouldn't be any problems other than getting the right rotor size.
Was planning on shipping them monday so I still have them.
96 850R red/beige
18t, R manifold, ARD, lot more
Infinity speakers / Kappa perfect 12"
#12 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 23 July 2012 - 01:02 AM
I still want them, I just want to find out what rotors to get that will fit. If you don't mind, can you measure how wide the rotors you have are? I'm assuming that is why they don't work right?
#13 brad850
brad850
  • 1,104 posts
Posted 23 July 2012 - 01:11 AM
Of course. The rotors I have are 1 1/8" wide.
96 850R red/beige
#14 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 23 July 2012 - 01:47 AM
#15 brad850
brad850
  • 1,104 posts
Posted 23 July 2012 - 01:57 AM
Any other problems pm me. I should of been clearer about my lack of knowledge.
96 850R red/beige
#16 ErikS
ErikS
    99.9%
  • 5,408 posts
Posted 23 July 2012 - 02:12 AM
From a guy who's had Willwood's ... save up the extra few hundred dollars and get the Porsche/brembo caliper that take full advantage of the S60R rotor sweep area.
1995 854 T5M Click for Mods
2005 S60 2.5 T
2013 MB GLK 350
#17 lookforjoe
lookforjoe
  • 9,778 posts
Posted 23 July 2012 - 02:22 AM
I would have to agree with Erik - having seen how much of the rotor is unused with Wilwood's, I would not use them.
#18 fischmama
fischmama
  • 4,948 posts
Posted 23 July 2012 - 02:33 AM
Joe's got the Porsche big blacks and I am not impressed with the pad size. I feel that the Wilwoods have a bigger surface area (not the ones Ben showed). My S4 has bigger pads with a single piston caliber (super sized ;) ).
Website: JJFab.net
#19 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 23 July 2012 - 02:45 AM
I'm on a budget. These will cost me half of what it would cost to get the porsche's.
#20 Yellow95
Yellow95
    Grandpa G
  • 6,745 posts
Posted 23 July 2012 - 12:48 PM
But what your not understanding is that there isnt exactly a huge assortment of rotor sizes for the 5x108. If you have to go custom rotors you are going to have WAY more in your set up then had you gone with a porsche BBK. There is more involved then just rotor size involved. You need to know how thick the rotor needs to be for those calipers. I am not saying its not do-able. Just saying it might get more involved and expensive then you think.
Gary
