So far I've ran into a weird problem,
If I run the gauge directly from the 12v batter when I turn the car on it reads correctly (vac)
If I run it from the wires that were illuminating my old boost gauge it reads 10 low. (from the light switch)
^ that way worked like this, the gauge's light didn't turn on until you flipped the lights on, either the drl's or the headlights. (old gauge)
Read something about it needing to be on while cranking or some crap, almost like it needs to be running as soon as the key goes in?
"NOTE: The RED wire must have 12 volts while cranking and when key is ON"
Anyone have any experience with this gauge and can shed some light on how to wire it up?
Never had an electronic boost gauge before so yeah.
Old one was analog so the wiring was just for the bulb.
