http://www.fcpeuro.c...ft-seal-6843112
On the side facing up in the picture it is rubber and looks like it would face out of the trans. On the backside it has a metal face and looks like it would go inwards. But what gets me is that the spring that keeps tension around the axle (silver in the picture) would be on the outside if installed in the way that looks correct (side facing up in the picture being outwards).
Which way does this seal go in the trans? With the spring ring exposed, or with it inside the trans?
There was a cheap aftermarket seal in it before so I have nothing to compare to.
Thanks.
