B5254S(Na) Exhaust Back Pressure, Exhaust Pipe Sizes
Posted 30 July 2012 - 04:32 PM
Well im not really sure if this belongs, in cosmetic, Maintenance or here, but i decided here would be my best bet.
So im looking to maybe do an exhaust on my NA. I am by no means looking for performance. Let me say that again, i am not looking for performance. I know i cant gain 10000hp with an exhaust on an NA. Basically im just looking for a better sound. Instead of gaining performance id like to maintain the power i currently have but achieve a nice tone.
So lets start off with back pressure. What is the hype with back pressure and these NA engines. Ive read all over the forums that these engines love back pressure and require it to make torque. All over the web i've read that back pressure is a hype and a myth and it is better to have less back pressure. Does anyone have any first person experience with back pressure and these engines? Hoping i can get a little more info.
Basically I was thinking of just taking out the muffler and replacing it with regular old pipe. This will definitely get me that 5 cyl NA sound, but it might be obnoxiously too loud. Aftermarket muffler suggestions? It will also free up the exhaust and decrease back pressure. How will this affect my engine? This is how i think of it. Basically the less backpressure, the more free flowing exhaust. If i were to purchase a cam timing tool and set a little more overlap, the intake and exhaust would be open at the same time and this would effectively charge the cylinder. Less resistance in exhaust, more cylinder charging. Correct me if i am wrong. So hmm performance and sound? Somethings sound a little fishy. What have other people done? Hopefully Johann can chip in.
Next, i am looking for exhaust pipe sizes.
I have been able to figure out that the pipe going from the cat all the way back is 1.75in. What is the size going into to cat? Is the whole system 1.75?
Hope i can get some help here or some ideas.
Many thanks!
~Simply
1996 Volvo 850 NA. 960 Plate, CAI, Phenolic Spacer. Paddle Shifters. 170K. Went from car seat to drivers seat.
1995 Volvo 850 T-5R (Black). 208K and counting. Getting There. Manual Swap, M4.4, Ta Technix Coilovers.
Posted 30 July 2012 - 06:56 PM
1999 S70 Base w/ Manual - "5 BANGER" - IPD Springs and Sways, HD Endlinks, Bilstein TC Struts, HD Shocks, OBX Strut Brace, Lots of Poly, Custom Exhaust, Amaltheas, Pioneer Double DIN
Posted 30 July 2012 - 07:53 PM
Posted 30 July 2012 - 08:00 PM
Did you cut the weird ball joint clamp off the cat? Also what size pipe is the pipe coming out of the cat?
I didn't touch any up to the cat, and have 2 1/4" from the cat to the back.
And yes, it's welded to the cat, I cut off that silly thing.
Posted 30 July 2012 - 08:03 PM
Still a little confused, so you kept the stock cat in place.. but what did you do with the weird ball joint that connects the end of the cat to the rest of the exhaust? Did you cut it off(the ball joint) and weld 2.25" pipe?
Ok nevermind you answered my question in your edit.
Thanks!
Is the pipe coming from the cat 2.25in?
Posted 30 July 2012 - 09:42 PM
Posted 30 July 2012 - 09:58 PM
http://www.carforum....k-pressure.html
And yes, I have a 2.25" pipe from the cat to the muffler.
The N/A is ridiculously load with a straight pipe.
Posted 30 July 2012 - 10:20 PM
This explains it rather well...
So is the stock exhaust 1.75in? Or 2.25in? Just want to clear this up. Is the cat pipe 2.25in or 1.75in
Posted 30 July 2012 - 10:52 PM
Posted 31 July 2012 - 12:03 AM
'98 S70 N/A 147k- OBX header, 2.5" SS header back, Bilsteins, 960 TBP, K&N, H&R camber, OMP brace
Posted 31 July 2012 - 12:19 AM
Posted 31 July 2012 - 08:03 AM
I made an ss exhaust for my NA. I did 2-1/2" from the header back. Im running the obx ss header. Originally I used a Magnaflow highflow cat, a 14" oval body Magnaflow in the stock spot and a pypes m80 by the fuel tank. I adjusted my cam timing with the ipd tool. Now running a dynomax vt in place in of the magnaflow. Quieted it dow n a bit and reduced the drone on the highway. I think if you have an auto you'll find you have to slam the throttle to have decent acceleration from a stop. If you have a manual you can have a one tire fire anytime you want. I've been buying exhaust parts from jegs and have been happy. They also have those ball swivel joints if you need it. I can get part numbers for what I used if you need.
Needs moar LSD
Posted 31 July 2012 - 11:12 AM
#555-30695 is Jegs part number for 2-1/2. I don't think they have smaller than that. The tube on mine was 2-1/2" on the header side of the cat and 2-1/4" on the swivel side of the cat. I think your going to have to measure the tube where you plan to cut.Yes it would be great if you could get me a part number for the ball swivel joint thing. And what is the size of the pipe coming out? i believe its 1.75in.
I've done a couple exhausts for P80 cars and the tube sizes have been different based on Turbo/NA or if it had the stock muffler or cat replaced with certain OEM/aftermarket direct fit replacements.
I would love one. It's on the short list for the next time I have to pull the transmission.Needs moar LSD
#14
Posted 31 July 2012 - 12:14 PM
http://www.ebay.com/...80f2737&vxp=mtr
and
http://www.ebay.com/...941587a&vxp=mtr
I might get one in the coming months just to see if I notice any differences
'95 850 GLT 228k M56H ARD 850R/T5-R STUFF
#15
Posted 31 July 2012 - 01:27 PM
It's well made and fit well. The tubing is mandrel bent and slightly larger than the stock manifold.
The stock tubing was bent on a regular tube bender and had some cross section change in the bends.
Mine does not have mounts for the heat shield and has a bung you'll have to plug if you don't have EGR.
Forgot to mention to get new OEM gaskets and bolts. The ones that come with the OBX are garbage.
Edited by Eliotg, 31 July 2012 - 01:28 PM.
#16
Posted 31 July 2012 - 01:30 PM
#17
Posted 31 July 2012 - 01:36 PM
Sounds good to me, thanks! I always thought the pipe coming out of the cat was 1.75in but i must be wrong! Ill do some measuring.
#18
Posted 31 July 2012 - 02:11 PM
$140 is a good deal for 304 stainless. I think i paid $175 shipped for mine.The EGR bung looks a little longer, it has the heat shield bracket and the collector looks shorter and less contoured than the OBX but they look the same otherwise.what about the other brand exhaust manifold? it looks to be of comparable quality and it comes with a plug for the EGR port. $140 is a good deal IMO
#19
Posted 31 July 2012 - 03:11 PM
#20
Posted 31 July 2012 - 07:27 PM
Then again, I've got the silly Denso engine, I probably won't bother.
