Aftermarket Hu Harness Has Leftover Wires
attention stereo gurus!
19 replies to this topic
#1 TaskMule
TaskMule
  • 1,341 posts
  • Interests:Interesting things.
Posted 03 August 2012 - 06:18 PM
I'm wiring up an new double din HU to my 98 V70R. I have the Metra harness adapter. I've got 3 wires unmatched after connecting the rest. I've got solid orange, solid navy blue from one connector, and orange/white stripe from the small connector, with no where to go.
The blue with white stripe is labelled for remote output, so that's fine. But where do these other 3 misfits go?
98 V70R AWD
128k miles, 18T, 3" DP, ABM's, SAS delete, Samco's, K&N panel, white's, 18" Pegs/RE760's
#2 Aequitas_Veritas
Aequitas_Veritas
    Blue Calipers&Balls
  • 8,130 posts
Posted 03 August 2012 - 06:21 PM
what does the radio pinout description in the install manual say the orange/white wire is for?
#3 TaskMule
TaskMule
  • 1,341 posts
Posted 03 August 2012 - 06:36 PM
If it came with a pin out diagram, I could tell you... :unsure: Google here I come.
98 V70R AWD
#4 Aequitas_Veritas
Aequitas_Veritas
    Blue Calipers&Balls
  • 8,130 posts
Posted 03 August 2012 - 06:46 PM
So you just attached all the colors that were the same? :blink:
#5 TaskMule
TaskMule
  • 1,341 posts
Posted 03 August 2012 - 06:52 PM
Yes, all colors present that had a place to go, went there. Soldered and shrink wrapped.
Orange with white = car light control switch. Where would that one get connected?
This is the harness I bought; http://www.amazon.co...Car=1&carId=002
update; I just found one of those ebay adapters for adding an aftermarket HU to stock amp in my box o' wires. I'll use that to complete the install, thanks for the help.
98 V70R AWD
#6 Aequitas_Veritas
Aequitas_Veritas
    Blue Calipers&Balls
  • 8,130 posts
Posted 03 August 2012 - 08:08 PM
Nope, that means you have a Dolby processor. Means you also need
http://www.ebay.com/...=item2573040568
And there is no standard wire colors for audio, So I would look up the pinouts of both the volvo radio and aftermarket radio and make sure you have it hooked up correctly, you cant assume like wires go together. In fact, im 90% sure you hooked them up wrong and might fry something if you were to try it.
And Car light control switch doesnt need to be attached
#7 TaskMule
TaskMule
  • 1,341 posts
Posted 03 August 2012 - 08:28 PM
Thanks for the info.
UPDATE
Hooked up the unit, using the Metra harness and this
http://cgi.ebay.ca/w...#ht_2223wt_1293
Works like a charm, all radio features in action.
BTW a JVC XR810 is what I installed.
http://support.jvc.c...elId=MODL028629
With the sub zero temps 4 months + a year, I couldn't see a touch screen being practical. Interior moisture every morning and all that.
98 V70R AWD
#8 BEJinFBK
BEJinFBK
  • 1,930 posts
  • Gender:Not Telling
  • Interests:Lottsa stuff!
    The world is a big place...
Posted 04 August 2012 - 03:28 AM
Actually, it means he has an external OEM amp. And the kit he referred to should include a DIN to RCA adapter.
The OEM Dolby surround has nothing to do with this. Dolby may or may not be included with the original stereo.
Not all R's came equipped with it. But that doesn't really matter because virtually no aftermarket HU's support
the OEM center channel speaker anyway, and none would interface with the OEM Dolby module itself.
There's been an EIA/TIA color standard for car audio for more than 25 years.
It's used by every reputable car stereo and harness company on the planet.
Here ya go:
http://www.the12volt...st/request2.asp
There are two orange leads commonly found in car audio wiring:
Orange - "Illumination" control. This is the variable voltage
supplied by the dash lighting dimmer control.
Orange/White - "Dimmer" signal. This is usually a 12 volt
signal (sometimes a ground) that's tied to the parking lights.
It tells the HU to dim the display when your lights are on.
These two things vary widely from car to car and HU to HU.
Your meter and the new HU's manual should fill in the blanks.
The lighting option doesn't HAVE to be used, but I usually hook it up.
Heck - It's there and you paid for it. Why not?
#9 TaskMule
TaskMule
  • 1,341 posts
Posted 04 August 2012 - 04:58 AM
My manual says orange is indeed light control. Do I tap that into my dimmer? Which wire on the dimmer?
Sorry for so many noob questions, but this is new to me. Believe it or not, it's the first car stereo I've ever installed out of the box.
98 V70R AWD
#10 BEJinFBK
BEJinFBK
  • 1,930 posts
Posted 04 August 2012 - 05:44 AM
It looks like your JVC is looking for a solid 12 volts.
Tag it into the parking light output from the headlight switch.
This HU has some programming options for the dimming feature,
but out of the box, it should default to the "auto" mode that responds
to 12 volts coming into the HU's orange/white lead by dimming the display.
Refer to page 33 in the JVC manual for the section on that feature.
On pages 36, read up on setting display colors ( for both night AND day ).
and on page 38, you can find out how to set the day/night color/dim switch
up on a timer! This deck does everything. Someplace, you can probably
make it release the sharks with frickin' lasers coming out of their heads...Nice HU. ;)
#11 Ghost Shadow
Ghost Shadow
  • 4,090 posts
  • Interests:testing
Posted 04 August 2012 - 11:48 AM
holy crap batman, i thought the first post would have answered this question. :lol:
orange from your harness is dimmer, connect to orange/white from radio
blue from harness to blue/white from radio antenna.
#12 TaskMule
TaskMule
  • 1,341 posts
Posted 04 August 2012 - 01:54 PM
These sharks with laser beams you speak of...are they ill-tempered...?
Awesome. Thanks so much. :tup:
98 V70R AWD
#13 andyb5
  • 3,191 posts
  • Interests:cars?
Posted 04 August 2012 - 05:20 PM
:lol: :lol: :lol: :lol:
#14 TaskMule
TaskMule
  • 1,341 posts
Posted 07 August 2012 - 11:12 PM
HU and sub installed, with Pioneer mono block. Its pretty nice, thanks for the tips. One more ? I get a slight alternator "whiz|" noise through the speakers on acceleration. Am I needing better grounds or something? Amp output and power run down opposite sides of the car, BTW.
98 V70R AWD
#15 Ghost Shadow
Ghost Shadow
  • 4,090 posts
  • Interests:testing
Posted 07 August 2012 - 11:25 PM
how did you run the RCA? what kind of rca?
#16 TaskMule
TaskMule
  • 1,341 posts
Posted 07 August 2012 - 11:48 PM
Shielded RCA cable, made for automotive. Translucent casing, and the innards looks like they're wrapped in tin foil or something. It runs along the passenger side, tucked under the door/floor trim.
98 V70R AWD
#17 Ghost Shadow
Ghost Shadow
  • 4,090 posts
  • Interests:testing
Posted 08 August 2012 - 12:05 AM
whiz.....thru the door speakers or sub woofer?
#18 TaskMule
TaskMule
  • 1,341 posts
Posted 08 August 2012 - 01:40 AM
Ah..key question. I'll have to check. Thanks a lot for the help.
98 V70R AWD
#19 Ghost Shadow
Ghost Shadow
  • 4,090 posts
  • Interests:testing
Posted 08 August 2012 - 01:23 PM
i suspect POS JVC head, if the noise is coming from door speakers, try running another ground to the radio, new separate ground. touch it to different places on the radio. take off the rca going to the subs and see if the noise goes away. if it does then you need to a: replace the RCA b:amp has open ground loop(defective amp) c:bad ground on amp(need clean metal to metal contact) d:plug back in RCA to head unit and touch ground to the rca shields and see if it goes away.
report back with your findings
#20 TaskMule
TaskMule
  • 1,341 posts
Posted 09 August 2012 - 04:53 PM
Opened the RCA cable near the amp, grounded the shield, problem solved. Thanks for the advice! :tup: :pizza:
98 V70R AWD
