Posted 05 August 2012 - 11:55 PM
I recently replaced the spark plugs and have a reuseable air filter. The dealer said they do lots of other things too, most of which I forget, but it cost $1400, which is more than the car is worth.
So I was planning on getting an oil change/fluid check, and have them do a once-over mainly looking for suspension/front end issues, and any leaking (RMS, tranny, etc). I'm writing because I'm wondering what items you guys would look at/want looked at if it were your car. The timing belt will be due for a change at 210k, but it's $700, and I'm really thinking about letting it go for a while, despite the possible consequences. Clutch was replaced at 99k and is still strong, and the thing runs like it's brand new.
Sorry if it sounds like I'm hesitant to spend huge amounts of money, but I'll hopefully be getting another car by New Year's.
Thoughts?
Thanks in advance.
PS I'm in Knoxville, TN if anyone has any tips or has any preferred shops. I've been using Swedish Motor Works in Old North Knox.
960 TB Plate Swap, K&N Panel Filter
Posted 06 August 2012 - 12:05 AM
Posted 06 August 2012 - 01:36 AM
1998 S70 GLT-5 427 / 1998 S70 T5M 019
Posted 06 August 2012 - 02:04 AM
Thanks again.
Posted 06 August 2012 - 04:23 AM
I usually use this independent Volvo specialist mechanic for jobs like timing belt replacement, and he is expensive. Is the timing belt on this '93 850 car typically can be done at the local shop or is it trickier to replace? Car is getting old and didn't want to spend too much more.
205,000 miles
Still original PCV
Posted 06 August 2012 - 05:05 AM
Posted 06 August 2012 - 05:16 AM
The labor is a very straightforward timing belt job, a local shop should be able to do it if they are decent mechanics. But a non-Volvo mechanic will probably use crappy parts, that is the kicker. And if a pulley fails, as mentioned the valves will bend and the head is toast.I usually use this independent Volvo specialist mechanic for jobs like timing belt replacement, and he is expensive. Is the timing belt on this '93 850 car typically can be done at the local shop or is it trickier to replace? Car is getting old and didn't want to spend too much more.
'96 NA 855 - 111 k - daily driver
'95 R 854 - 177 k
Posted 11 October 2012 - 09:49 PM
9180954 - TOOTH BELT
9135036 - BELT TENSIONER
8630590 - IDLER ROLLER
$161.82 New OEM volvo/ 1 year warranty
VS $850 at your Dealer (including labor
Click ---------=\
V
1995 854 T5-R-K&N panel-Whip Game proper
www.Thevolvopartsstore.com <----25% over Cost OEM parts all day
Posted 13 October 2012 - 03:55 AM
Look at the belt and see if it's not in horrible condition. If it isn't you have some breathing space.
And as they mentioned you can save a buttload of cash by doing it your self. Not so hard with the right tools.
Edited by adamdrives, 13 October 2012 - 03:56 AM.
97 civic cx hatch 200k, silver. DD
97 850 glt ~160k, olive on tan. SAS delete. Saving for build.
Posted 14 October 2012 - 03:19 PM
Thanks for all the info! I got a comprehensive kit from FCP Groton with timing belt, tensioner, water pump, and pulleys. I'm going to do it myself here very soon - anal preventative maintenance.
Whole PCV system was replaced a few months ago as it was clogged, etc. I also just changed the fuel filter and distributor cap / rotor too. It's running great right now!
Also tagged with one or more of these keywords: tune-up, 850
Classifieds →
Wanted →
M56 Transmission WantedStarted by maximumbuckeye, 14 May 2013 |
Modifications →
Cosmetic and Detailing →
Poll 850 Nose Protection.Started by optimus prime, 13 May 2013 |
Modifications →
Performance Modifications →
Nivomat Equipped 4Wd Wagon - Suspension Refresh Option?Started by hk20000, 04 May 2013 |
Classifieds →
Wanted →
Wtb- 850 Manual Trans Center Console Upper TrimStarted by tls850r, 05 Apr 2013 |
Classifieds →
Group Buys And For Sale Feed →
16T 100,000Ish $200 OboStarted by Tommy., 02 Mar 2013 |
