Suspension Rattle ?
#1 NZRED850R
NZRED850R
  • 74 posts
  • Interests:Cars,Quads,
Posted 08 August 2012 - 10:57 AM
I have a slight rattle/knock when the car travels at low to mid speed could this be(starting to anoy me now I have fixed the dash mounts)
1, the spring mounts
2, the top strut mount
3,sway bar end links
The sway bar bushes seem to be ok any thoughts???
1999 V70 AWD
1995 850 T5R
1996 850R AT, ARD green tune,ARD light weight pulley, Forge CBV, Ipd reverse intercooler piping,IPD HD TCV,Snabb intake and manifold spacer,K&N air filter,16t turbo,MSD blaster coil,,302mm Brakes
#2 erikv11
erikv11
  • 2,871 posts
Posted 08 August 2012 - 02:42 PM
Check the spring seats - does the top nut on the strut spin freely, or is there resistance?
'96 NA 855 - 111 k - daily driver
'95 R 854 - 177 k
#3 atefitty
atefitty
    Manuals tighten my pants
  • 600 posts
Posted 08 August 2012 - 06:16 PM
RF motor mount
1997 850R
IPD Strut Brace, IPD Boost Guage, EST Intake, TME Catback Exhaust, Bilstein Struts/Shocks, TME Lowering Springs, Wastegate adjust to 6psi, European Side Markers...just new, black jewels and ECU upgrade....next : finally a downpipe!
#4 NZRED850R
NZRED850R
  • 74 posts
Posted 20 August 2012 - 09:26 AM
Found the problem. I went to change the spring seats and end links and found the left hand wheel bearing had a lot of play in it.
Replaced and all good now.
thanks for the suggestions
1999 V70 AWD
1995 850 T5R
