Porsche Bbk
Posted 11 August 2012 - 05:59 PM
Any info from you guys (and or gals with a BBK set up) would be sweet!
96 854R Black IPDStage III, Winter (M56, 99T5 motor, 18T) 19psi, Whites, OBX, Eibach springs, SSQV, Exhaust Cutout, Aem UGO, 17" Peggs etc..
87 Nissian Hard Body with a sweet clutch
98 V70R Saffon AWD, Fresh 18T, RICA Stg II, Porsche BBK Sconeman intake pipe, Mufflers Delete,IPD springs, CX Racing FMIC, Hillman MBC @ 18psi, VR Charcoal Swap, Cai, HKS SSQV, Projectors, 18" Peggs, XC90 Wood steering wheel, Front Lip, Full A/C Delete, Slow and Heavy
Posted 11 August 2012 - 06:39 PM
http://www.tirerack....&cat=BrakeFluid
And you should flush the whole system with the new fluid by pouring it in the resevior and pumping the brakes while opening each caliper and letting it bleed out until it turns blue.
Posted 11 August 2012 - 09:29 PM
honestly i felt like the stock length SS lines were too short. Hanks and I had custom lines made for these brakes, seem to be holding up way better. The rubber on the crimped end usually goes bad over time because the lines were not long enough.
Alex
2013 C30 T5 R-Design - Rebel Blue - Polestar Tuned
Old/Parting: '98 V70R AWD FWD - M56L - 19T - TT - RICA - 17" Team Dynamics Motorsport - Pro Race 1.2 - 18" Pegs - CJ Porsche 993TT BBK - CarPc - Parts For Sale - Click Me!
Posted 11 August 2012 - 09:50 PM
Posted 12 August 2012 - 12:41 AM
-Kevin-
2004 V70R: 3 angle valve job, Phuzzy FMIC, IPD Neutral rear sway
White '96 850 T5M:Black '94 850 T5
Posted 12 August 2012 - 01:35 AM
79 242 GT*84 F150*96 854R*98 S70 GLT-M*98 V70 AWD*00 V70R
72Chevy K10 Cheyenne*78 242 GT*89 740 TIC*96 855R *97 855R*98 V70 NA*98 V70 XC*98 S70 T5
98 C70 T5m*98 V70R*98 V70R*99 S70 AWD*99 V70R*99 V70R*00 V70R*00 V70 XC*04 V70R
Posted 12 August 2012 - 08:38 PM
Posted 13 August 2012 - 12:02 AM
Edited by WayAway, 13 August 2012 - 12:03 AM.
Posted 15 August 2012 - 08:44 PM
yeah you should use SS lines with this fluid
I'd pass on the ATE super Blue. The Blue stains the inside of the lines and it will turn amber fluid blue... I just flushed out the Super Blue for Typ 200 Amber and 2 months later it's blue again. The worst part is that it's harder to see the air bubbles in the blue then amber. And all my bleeding hoses that were clear are stained blue now...
Laser Blue 2000 V70R
Speedtuning St2 @18psi/19T w/Forge CBV/IPD drop-in intercooler/R mani/CJ 3"DP/dual 3"Magnaflow/EST intake w/K&N/Samco & Snabb hoses/Delco TCV/Bosch Super Plus/IPD HD COP/UR lite pulley/CJ delrin subframe mounts/TME AWD springs/TME strutbrace/IPD sways w/adjustable endlinks/Koni Sport strut/18" OZ Ultraleggera
Posted 15 August 2012 - 09:39 PM
What would you recommend?
Posted 15 August 2012 - 11:23 PM
Posted 16 August 2012 - 01:30 AM
#14
Posted 16 August 2012 - 04:40 AM
none of those reasons are important to me, I dont care if my lines are stained blue, I like blue haha. All your reasons are only if you want to get rid of the blue later. The bubbles thing I guess is a point, but once they are all out I have never needed to look for bubbles so why care? I like that the brake fluid match my hoses and my coolant. I guess its the small things. haha
#15
Posted 16 August 2012 - 12:48 PM
I think most of us are less concerned about color matching brake fluid and coolant hoses and more about making the job easy every 3 years when you have to flush it (thats why I originally got the blue to make it easier to flush from amber). Hey whatever floats your boat.
But like I said once you go blue, you are blue forever!
#16
Posted 17 August 2012 - 01:43 PM
When yang and I had ours done at a local place it was ~40$ out the door per pair.
What "local" place? Hydraulic hose shop?
#17
Posted 20 August 2012 - 03:26 PM
-Kevin-
#18
Posted 23 August 2012 - 02:27 PM
#19
Posted 23 August 2012 - 05:05 PM
-Kevin-
#20
Posted 23 August 2012 - 07:43 PM
Cheap pads squeal like a pig. It'll annoy the hell out of you.
