Solenoid Purge Valve
Posted 15 August 2012 - 03:25 PM
midessa7
Posted 15 August 2012 - 06:54 PM
It looks like this
http://www.fcpeuro.c...CFQ-c7QodjTgAyg
Posted 15 August 2012 - 08:14 PM
midessa7
Posted 16 August 2012 - 08:22 PM
Posted 16 August 2012 - 11:55 PM
Posted 17 August 2012 - 07:50 PM
Odd question to, I need to change the thermostat and sensor, now would that make it not start because it's getting a false reading.
Also should I go ahead and change the turbo control valve ?
Posted 18 August 2012 - 12:17 AM
'00 V70R-Parted and Junked : (
'01 C70 Coupe - Stock
05 XC90 T6-coming soon
Posted 18 August 2012 - 01:58 AM
Could it be the fuel filter ?
How would i test for the fuel pump ?
Posted 18 August 2012 - 05:45 PM
Are you randomly trying to fix things or does your car have codes that say your EVAP purge valve and coolant temp sensor are bad?
'99 S70 AWD + FWD Trans // 161K
2.4+15g/Rmani/Snabb Pipe/EST DP/ARD Green/4300k Bi-Xenon Retrofit/Rear Heated Seats
Posted 19 August 2012 - 10:25 AM
I did get some codes.
2000 temp sensor / fixed
4308 leak diagnostic ???
4801 three way CAT converter efficiency bank 1 / I guessing it's an O2 sensor ???
9150 throttle unit malfunction ???
Posted 19 August 2012 - 12:30 PM
You need a throttle body (ETM) before you do anything else.
Cat efficiency code means nothing at this point. That code can come up and nothing could be wrong.
Your hard strting is probably because you need a new fuel pump check valve.
With this you go aftermarket, mount one behind the fuel filter.
If nothing else is wrong it will solve your starting issue.... but you have other issues
Posted 19 August 2012 - 11:59 PM
Posted 20 August 2012 - 03:24 PM
Or, get a yellow label one from a turbo car at the junkyard. 40 bucks and it might work for a few more years.
Edited by burnout8488, 20 August 2012 - 03:25 PM.
#14
Posted 20 August 2012 - 08:22 PM
midessa7
#15
Posted 21 August 2012 - 06:11 AM
