is this safe to do,and will i see any hp performance..thanks.
N/a Cam Swap For A 95 850 Turbo T-5
Started by trophtaker308, Aug 15 2012 07:43 PM
5 replies to this topic
#1
Posted 15 August 2012 - 07:43 PM
1995 850 turbo,autom gold,(gold package)...more to come!!!
187000 miles,runs strong.
18t turbo,obx exhaust,(ard blue tune),ipd MSD Ignition Coil Upgrade,ipd Short Ram Intake,cams retarded,BOV Upgrade,ipd 8mm performance wires.
#2
Posted 15 August 2012 - 07:47 PM
#3
Posted 15 August 2012 - 07:52 PM
Yes, and Yes.
It is also rather simple.
#4
Posted 15 August 2012 - 08:21 PM
so its beter all the way around with the n/a cams...correct???low and bottom end???
dont know what that came out so small like that..sorry,and thanks for anymore info..
so it better all the way around on bottom and top end..thanks again.
#5
Posted 15 August 2012 - 09:41 PM
I heard you loose a little low end... but with my tune and the correct timing set, I didnt notice any loss, just gain.
#6
Posted 18 August 2012 - 01:49 AM
rob you should probably warn him about your confetti show...
after rob did his cams the car started shooting out sheets of carbon, like confetti out his exhaust. because he had no Cat, and an str8 through muffler it was not an issue, but IF you have a Cat. you could clog it.
PS. it did stop after a bit, and its suspected that the higher lift of the cams was causing the valves to scrape the carbon off the walls of the head to produce this effect.
