No Sound After New Headunit, 850R
Posted 19 August 2012 - 06:09 PM
Is using this cable the only way to do it?
http://item.mobilewe...Id=200484953400
Or is there another way around it?
Posted 19 August 2012 - 06:34 PM
If you want to use the Kenwood amp,
you can unplug the factory cables that
run between the HU, out to the amp and
back to the regular speaker plug, no problem.
You just wire up a regular harness adapter kit
and it all plugs together and goes. Easy peasy.
Then you're just going direct to the speaker
harness like a factory non amped car.
More here:
http://www.matthewsv...php?f=1&t=30204
Posted 19 August 2012 - 10:59 PM
If you want to use the factory amp, yes.
More here:
Hrm...
So, I don't care about the factory amp (unless someone tells me I probably should care about it).
I used the metra wiring harness already, and hooked everything up. I'm not too sure what you're suggesting to do, so I'm going to go pull the side panels and look at the amp and see if I can't figure it out.
Posted 19 August 2012 - 11:15 PM
You should have plenty of white, gray, green and violet wires.
On the car side of that connection, I'm gonna wager less...
If that's the case, you need to find the REAL car side speaker connector.
Right now, it's probably buried behind the radio wrapped in foam tape
and plugged into the output connector of the OEM amp.
Posted 19 August 2012 - 11:42 PM
Does that make sense?
Posted 19 August 2012 - 11:56 PM
Did the pics in the MVS link help?
Posted 20 August 2012 - 12:45 AM
Posted 20 August 2012 - 01:27 AM
Posted 20 August 2012 - 04:58 AM
Now break out the Barry White
and take that girl for a drive.
