Vr: Both O2 Sensors Before Cat...?
exhaust v70r o2 sensor
10 replies to this topic
#1 sanfelice
sanfelice
  • 8 posts
Posted 10 September 2012 - 05:20 PM
Hi, all. Question: anyone know why my ride (2000 VR) would have both O2 sensors mounted before the cat on a custom system? Car has EST pipes and a CJ converter and custom downpipe, all installed by previous owner. I've had the car for about a year.
why would the second O2 sensor be mounted in front of the cat? is this typical of the smaller CJ-style converters? or, is it a mistake?
#2 mune237
mune237
  • 1,295 posts
Posted 10 September 2012 - 08:08 PM
CJ converter? Never heard of that. How would that work? Both 02s would have the same readings, and with that, you should have a CEL on, cause it would think the cat is not functioning???????????
1995 960 TOTALLED 1997 850R SOLD
2000 C70 HPT Convertible Auto
#3 fischmama
fischmama
  • 4,952 posts
Posted 10 September 2012 - 10:12 PM
You may have a tune that will ignore the rear O2, the only reason it is still there is to not have a check engine light for the heater circuit.
Just a thought.
Website: JJFab.net
#4 Boglin
Boglin
  • 283 posts
Posted 10 September 2012 - 10:35 PM
Sounds like o2 delete and they put a o2 where your AFR or pyro should go? Any CEL's? if not I'd say thats probaly what happened...
1998 S70T5 SE,Full Stage Zero,IPD Boost Gauge Pod Kit, 18T, S60R Mani, EST 3inch DP,Unorthodox Racin UDP, EST Catback, IPD RipKit, IPD SR5T intake,Rica 16T tune, Forge MBC 17psi,HID kit, Urethane engine mounts,Stylin Motors Silicone hoses,Marangoni Verso's,Xenon RetroFit,13.82@101.71 mph
#5 NEU
NEU
    Old Man Crew Photographer
  • PipPipPipPip
  • 3,639 posts
  • Interests:Formula 1
Posted 11 September 2012 - 12:01 AM
I have the original '00 AWD downpipe that CJ did for John Sharp. It sounds like the previous owner installed the cat backwards, it should have the O2 in the cat down stream of it. If they installed it backwards that would be in front of the cat. Undo the clamps and flip it. Should get rid of the CEL you've got too. ;)
Laser Blue 2000 V70R
Speedtuning St2 @18psi/19T w/Forge CBV/IPD drop-in intercooler/R mani/CJ 3"DP/dual 3"Magnaflow/EST intake w/K&N/Samco & Snabb hoses/Delco TCV/Bosch Super Plus/IPD HD COP/UR lite pulley/CJ delrin subframe mounts/TME AWD springs/TME strutbrace/IPD sways w/adjustable endlinks/Koni Sport strut/18" OZ Ultraleggera
#6 P0RTER
P0RTER
  • 31 posts
Posted 11 September 2012 - 03:16 AM
That's what I was thinking, that should work assuming that doesn't put the bung out of reach of the O2 sensor.
Black 98 V70 T5 M56 (Hauls Ass)
Saffron 98 V70 R AWD (Hauls Groceries)
#7 sanfelice
sanfelice
  • 8 posts
Posted 11 September 2012 - 12:50 PM
that's pretty much what will happen... can't figure it out.
I'm going to get the muffler place (custom place) to flip it and see if that cures the problem.
very strangely, I was not getting any CELs until recently, after driving the car for a year.
I mean to add that the muffler shop will have to make a new bung somewhere as I don't see the wires reaching if the cat is flipped with the existing hole.
#8 mune237
mune237
  • 1,295 posts
Posted 11 September 2012 - 01:25 PM
I had to get / use an 02 sensor wire extender
#9 NEU
NEU
  • PipPipPipPip
  • 3,639 posts
Posted 11 September 2012 - 01:52 PM
You have to extend the rear o2 sensor with CJ downpipe. New bung isn't going to solve the problem that the o2 leads need to be extended.
Unclamp the v clamps, flip it and extend the o2 lead and you're done. Anything else is just wasting money.
#10 ByTor
ByTor
  • 9 posts
  • Gender:Not Telling
Posted 08 October 2012 - 02:36 AM
I think you have two options here. The first is, if there is an additional bung after the cat, get an O2 extender wire, plug the 2nd O2 sensor into it, seal the bung it came out of and go merrily down the path of automotive happiness.
The 2nd option, if there is no bung and you are getting a CEL, is to use an extender - it is essentially a piece of pipe threaded to screw into a O2 bung on one end and tapped to accept an O2 sensor on the other - on the O2 sensor to get it out of the path and your CEL will go away. It is the 1st O2 sensor that matters - for adjusting the AF ratio.
Cost of the extender is $10 or less.
Edited by ByTor, 08 October 2012 - 02:41 AM.
Good work is not cheap, cheap work is not good, but paying a high labor rate is no guarantee of quality work. Ask me how I know.....
'01 S40 3"DP, BBTB, center muffler delete, Goodyear Assurance TripleTread rear, Michelin HydroEdge up front , OEM front Strut Brace, BWD OES coil packs, Bilsteins X4, 14T, K&N cone intake OEM 10 Disk CD changer, Leather Leather Leather all in the state of TEJAS!
#11 Tinaphps
Tinaphps
  • 10 posts
Posted 08 October 2012 - 09:10 AM
Hmmmm ... I'm going to have to think about that one
Also tagged with one or more of these keywords: exhaust, v70r, o2 sensor
