Über855R
Level Ten Transmission, A Review And Retrospective.
Okay, here goes. I will attempt to do a realistic review of my level ten transmission.
Let's start with the good:
The level ten trans pulls in a way the regular auto never could. When I had it in the car I would get wheelspin on both wheels equally and a drastic reduction in torque steer. Going in a straight line I could lay down two tracks much like a limited slip or posi-traction setup would yield. In turns it was even better. For example, when I had my regular automatic in the car there is one particular left hand turn on a favorite back road I travel regularly. I would floor it coming out of the stop sign and get a major puff of smoke from one side as I barreled out of the turn with massive torque steer. The wheels would hop and skip and my front end would bounce all over as I tried to manage the torque steer. Now this was sort of fun but not nearly as much as when it handles the turn. Comparing that same turn with the level ten trans, (when it was working) the car would pull straight with no noticeable torque steer and a drastic reduction in smoke as I would just pull out hard and fast with an amazing feeling of control and poise. Leaving two strips of rubber in my wake and having this feeling of "yeah man that was sweet!" I have no doubt that the trans would give better 1/4 mile times than a stock auto, probably by a surprising amount, and I can vouch for the fact that is in a whole different league from the stock transmission.
Now for the bad:
For starters, there is the cost. For the stage three level ten build good for up to 500HP the build is about 5K not including removing from the car and shipping to and from NJ from CA in my case. This gets you new internals, a better torque converter and valve body which seems to be the heart of the basic upgrades on the lower stage builds. After purchasing the stage III trans, I ran an after market oil cooler which I had hoped would be some cheap insurance on this expensive unit. After a couple of months the trans stopped working and I had to remove it from the car again and send it back to level ten. It turns out the valve body was melted out due to heat issues and they replaced it for me only charging for parts and covering the labor no questions asked. That didn't change the fact that I was out of a car for over a month and the had to pay freight twice and removal and installation charges getting the trans in and out. I put it back in the car, fearing my external cooler was not doing the job I switched back to the stock cooler setup routing the lines through the stock radiator. A few months later the trans stopped working with seemingly the same symptoms as before. I thought it was the valve body again and I sent it back anticipating another $500 dollar fix not counting freight. It turns out the internals were completely melted out and the whole thing needed to be rebuilt. Now, Pat was super cool about it, charging me only for materials and striving to make sure this would be the last fix needed. He built this thing himself using all the tools he had available including modifying the casing to accept a fluid pump that would move 3X the fluid of the previous one, and using the internals from a much newer Volvo transmission fitted into my 850 casing. This is the trans I am about to install in my car with a built motor and hoping that it will work long term this time. Pat says the stock cooling ought to be fine this time and I have a transmission temp sensor installed which I hope will let me know if heat is becoming an issue. (I had this before and it didn't help, but I suspect that is because it was always running hot so my baseline temp was never a good judging point.) This second rebuild Pat claims should hold upwards of 700HP and be truly able to handle whatever I can throw at it. We will see...
My impressions on Pat, the owner and founder of level ten is that he is a great guy with some real love for making power get to the road. He has been easy to work with and reasonable about fixing his work. The second rebuild still cost me around 3K putting the total for the trans not including shipping and install costs around $8,500. That is no joke, for that price you could install a 5 or six speed with a limited slip diff and handle all the power you want. Although I would be curious to see which has less torque steer since that problem has been non existent in my level ten trans and I could be wrong but I believe is still a problem on manual 850's.
You might ask yourself why I would do all of this instead of a manual swap. For me manual is not an option since I use hand controls in my car which do not lend themselves to using a clutch. For most of you a manual swap would probably be a better/cheaper option.
I am putting this info out there to hopefully give others the chance to make a well informed decision about their transmission choices. I do firmly believe that the level ten trans has been the best upgrade I have made to the car, and I have made plenty. But at the same time I wish I could use a manual and I know I could have driven my car much more with less trouble if I did.
I will be installing the newly rebuilt level ten transmission and keeping an eye on the temp and checking the fluids almost daily. Also getting a flush very often hoping to make this one last for a long time. Although I am confident that Pat has done it right this time since he really went above and beyond to make sure that is the case.
I will be sure to keep you guys posted and if anyone has any questions feel free to ask.
Ben
Nice review, I only know of one other person who was/is running a Level 10. Not sure what level however. I always liked the idea of having a powerful auto, especially for daily driving. I like my auto as well (stock) and as some can attest to I have put it through hell, and she likes me still haha.
Out of curiosity, since I coach wheel chair sports, are you involved in anything? (I have done manual and power sports, mainly however Power Soccer)
^ Good stuff! :tup:
What stall speed did you get on the torque converter? What did they do to the clutch packs? I've also heard you should still run the radiator trans cooler then run it thru a external cooler. Running both together takes more heat out of the trans fluid than just one of them alone
I'm actually going with IPT in NJ when I get my spare rebuilt one day. They have a very good rep with the Nissan guys that run there version of the AW-55 with turbo V6 motors.
You should reach out to lucky and have him adjust your line pressure. When I had my transmiasion rebuilt, one of the first questions he asked me was would we be able to adjust line pressure. At the time lucky was still with IPD and that wasnt an option so my guy adjusted
the valve body accordingly. But even afterwards he commented that he would really have like to fine tune the tcm for added durability.
I did one track day and a few weeks later had a grapefruit sized hole in my transmission casing. So be careful how you treat that stock auto.
As far as WC sports I stick to motorsports. My arms hands and shoulders are too valuable to me to risk injury on sports that I don't really love.
^ Good stuff! :tup:
I like that idea of running both coolers, might go for that setup. Thanks for the tip. Keep me posted on the IPT rebuild I am curious what they do and the cost. And I will get back to you on the exact specs of my torque converter, the other details are probably more accurate from level tens website. I used to get really into doing this stuff but these days I let the pros figure that out and just drive the end resut. I know it's not very Volvo message board traditional but I will stick to mathematics, my profession.
I would like to talk to lucky, or better yet get him talking to CJ who is doing all the work to my car. If he is on the board is that his name? Contact info? PM me. I also think my TCM should have some adjustments made to get the most from the transmission. Who can do that? More info is welcomed...?
Damn and I thought my $2500 invested into my manual swap was crazy. But once you get the swap, buy all new clutch, slave, lines, LSD, suede boot, wood knob it adds up fast. But you just made me feel much better about it haha
When I spoke with IPT back in '09 they'd do a torque converter, better solenoids, stonger clutch packs and more of them vs. the original and other things that I can't remember now... Price was similar to an AW-55 rebuild.
Lucky posted how to mod for adjusting the line pressure on the TCM, unfortunately it won't work for me with ME7 and he's not doing any TCM upgrades
I'm glad my financial pain can help to ease yours.
If you could give me some search terms to find it or a link to the thread I would be grateful. I'm not sure if the search still sucks on VS or just sucks using the iPad. Either way, thanks in advance.
Sorry I can't find the thread either??? :unsure: But his screen name is ARD-Lucky.
Here's the thread:
Page 2 of member announcements.
Patrickw had a never ending nightmare with level ten. Never got it right after numerous attempts and wasn't running strong numbers either
  • Similar Content
    • By lotsofmagnets
      Hey folks,
      Turns out long time lurker 1st time poster. Figured this would be the place to go with a pretty specialised problem as the m4.4 people are here.
      Backstory:
      This is the car I've owned for 12 years now:
      it's not super sexy but it's mine. i have a 164TE, 1800E, 2 C202s and another almost identical 850 except a wagon (very early production 93 model also)
      It started life as a 2.0 20V auto which is not bad if you're prepared for the tacho to visit 3PM frequently but through circumstance I got a B5254S and an M56 from a 2.0 (4.45 final drive) and that made the car actually faster than I anticipated. I drove it like that for 6 years but the engine was tired and blowing more smoke than I was comfortable with. About 3 years ago a valve chipped so I threw another head on and drove it for another year but then the week before I was scheduled to fly out to Australia for 2 months it chipped another valve and so I decided the time had come. I already had a B5244T3 sitting aside and I had already rebuilt a 16T turbo for it so last summer I finally put the car on blocks in the backyard and ripped the engine out. Over the winter I did a stage zero on the B5244T3 and rebuilt the steering rack while I had the subframe out to fix a leak and also got access to a full 98 xc70 so took everything relevant to the M4.4 setup from it and worked it onto the B5244T3. Finally, this May just gone I had everything ready and started putting the car back together and after working slowly on it the past 2 months On Thursday I was finally ready to turn the key for the 1st time. My 1st actual attempt to start it failed and so I did checks and the 1st thing I found was that the injectors only pulse for about a second  before turning off but then when I release the key an injector or 2 fire once. This happens every time I crank. I tried several very short cranks and the car actually fired up! I ran it for about 20 mins and after about 5 mins the lambda light came on but there's no surprise there as there are no o2 sensors yet as there is still no exhaust and the ecu is an auto one so that might also have thrown the code but the car did run for about 20 mins but then i turned it off and so far haven't been able to get it running again.
      This is how the engine bay looks right now:
      So, I think if you've read this far you can probably figure what my question is but I'll ask anyway: Would anyone have an idea what's going on? To recap, when the car is cranking, the injectors fire for maybe a second then stop but then when I stop cranking an injector or 2 may fire again. I've checked power to the ecu and on cranking I get 10.4V which I guess should be enough and I cleaned all of the contacts between the battery and ecu quite well so I don;t think it's an issue of power. Things I'm about to do are check spark to see if I lose spark too or just injectors and then maybe throw a cam sensor and crank sensor in desperation but I'm hoping someone has either encountered this before or has enough of an idea of how the M4.4 system works to help me figure this out. BTW I do have a video of it happening but not sure how to post it here. But yeah, If you have any questions about converting a 2.0 NA auto car to a turbocharged manual then feel free to ask
    • By AJp80
      I'm gearing up for a manual swap this weekend. In the process of making my list and checking it twice, I've noticed that I'm missing the hose that connects the brake fluid reservoir to the master cylinder. I can't find that part anywhere, and all the part numbers I have for it are discontinued. Has anyone else ran into this problem?
    • By The_Yamsman
      Hello, I am preparing to start an engine swap on my 1998 v70 manual. The donor car is a 18998 v70 T5 awd auto and i was wondering if the ECU from the donor car would work in the manual car. Also any pointers/must do's in the actual swap?
    • By hcaznacnud
      Hey guys and ladies,
      I was wondering if anyone has any information for me regarding putting in an engine from a 96 850 turbo into a 97 850 manual car. Note that the 96 850 turbo has an automatic transmission and a 2.4L engine, and the 97 850 manual has a 2.3L engine. For some background info my turbo model was backed into by a friend and the insurance company claimed it as a loss so the car is now totaled and I am keeping this car and buying the manual version. The reason for this is because since the insurance company is totaling the car it will be more difficult to rebuild this car as opposed to buying another car for real cheap while also upgrading to a manual. I am not going to keep the turbo 850 but I am going to swap the engines and put the turbo onto the manual counterpart. My main question is this, which ECU should I use? To my belief it should be the auto ECU right, because it will have the software to run the engine and turbo but not the manual. Keeping the manual ECU in could damage the engine right, because the it does not know how to run the bigger liter engine along with the turbo which could cause catastrophic damage. I do not really need answers on doing the actual engine swap there is plenty of info on that. I am aware to buy new seals like the rear main seal and oil pan gaskets and what not. I am also going to get a new clutch plate. But any information anyone can give me would be appreciated.
    • By adamvolvos70t5
      I'm looking into swapping my auto to manual in my 99 S70 T5.
      I'm in the process of sourcing parts and came across an M56 gearbox from a 2001 C70 2.4
      My question is would this gearbox work? Are all M56 gearboxes the same regardless of its paired engine?
      I know that there is a M56H and an M56L, but from what I read I gather either will be fine, its just a final drive ratio difference between the 2.
      Ideally I was looking for an M56 from a 1999 or 2000 S70 T5 so I'll know for sure that it'll work, but that's hard to find.
