Turboforslund Posted April 7, 2015 Report Share Posted April 7, 2015 Uphill = less speed = warmer intake air = more thermal stress = more knock. // Turboforslund Quote Link to comment Share on other sites More sharing options...
S70-R Posted April 7, 2015 Report Share Posted April 7, 2015 (edited) Uphill = less speed = warmer intake air = more thermal stress = more knock. // Turboforslund Yes but that will happen with or without the p-part bin as our ECU's have not any proper IAT sensor and/or EGT sensor. That's also the reason why I talked about an ignition by gear bin for 2 months ago or so because at extended WOT pulls in the higher gears and higher rpms we'll have more thermal stress thus probably the need to reduce timing a bit. Edited April 7, 2015 by S70-R Quote Link to comment Share on other sites More sharing options...
Turboforslund Posted April 7, 2015 Report Share Posted April 7, 2015 Yeah I remember your ideas, it's to bad that the ECU doesn't compensate or torque limit due to intake air temp. Knock control will (hopefully) do whats necessary to save the engine if the hardware and calibration is properly matched. Bad intercoolers and stressed mini-turbos is never a good combo. Your idea makes the system prepared for the worst cenario even if it doesn't appear. I think it's nice to have load-per-gear limits to reduce wheelspinn and thermal stress in one go, it's common practice in modern systems (saves transmission components as well). // Turboforslund Quote Link to comment Share on other sites More sharing options...
Avinitlarge Posted April 7, 2015 Report Share Posted April 7, 2015 What does the "LDR duty cycle correction, intake air temperature" table do exactly? Quote Link to comment Share on other sites More sharing options...
S70-R Posted April 8, 2015 Report Share Posted April 8, 2015 (edited) Paul, that table reduces the tcv table. In other words reduces boost as the ambient temp gets lower. I believe it does it not to reduce exactly load but to reduce torque output in lower temperatures as lower temps result in higher torque. Edited April 8, 2015 by S70-R Quote Link to comment Share on other sites More sharing options...
Stefan Mohammed Posted April 8, 2015 Report Share Posted April 8, 2015 I like that idea. We are tuning Volvo's who cares about MPG, Its never going to be good Sorry, I was tired. Just fit a gauge or even better, log the AFR. I already have a gauge, the Innovate Autotimer, problem is that if I'm going to a Spartan2 I'd no longer have a gauge and I don't like the aesthetics (yeah, seriously... my car is sleeper enough, I hate having a tonne of gauges cluttering the interior) of any of 14point7's gauges. If the instantaneous MPG (or something else) could be repurposed to display AFR then that would be a nice option. Having a wideband display isn't a necessity but sometimes I like having it as a quick reference just for my peace of mind. I'm sure others would agree. Piet, so do you think this could be done? Quote Link to comment Share on other sites More sharing options...
Midnight Caller Posted April 8, 2015 Report Share Posted April 8, 2015 The MPG display updates once per second, and could be too slow to save you from a too lean AFR. Also have that in mind. Quote Link to comment Share on other sites More sharing options...
Stefan Mohammed Posted April 8, 2015 Report Share Posted April 8, 2015 The MPG display updates once per second, and could be too slow to save you from a too lean AFR. Also have that in mind. It would be for a quick reference, i.e. to make sure you're targeting 14.7 at cruising and 11.5-12 under load at a quick glance... this would be for the guys who have everything tuned properly already and would still like some info being displayed. Quote Link to comment Share on other sites More sharing options...
Midnight Caller Posted April 8, 2015 Report Share Posted April 8, 2015 Yes, for that purpose it would be ok. But I don't know if MPG calculation is done in ECU or inside the Trip computer "button" or even in the dashboard, and ECU just sends the injection time and injector constant for consumption display to it, leaving the calculations to the trip computer. Quote Link to comment Share on other sites More sharing options...
Piet Posted April 8, 2015 Report Share Posted April 8, 2015 Razorx is developping small displays with wich you can display loggingvalues from the dataframe by choice, including AFR, through the K-line. Quote Link to comment Share on other sites More sharing options...
German850R Posted April 8, 2015 Report Share Posted April 8, 2015 Razorx is developping small displays with wich you can display loggingvalues from the dataframe by choice, including AFR, through the K-line. That's great. Maybe in time for when my build is finished so I don't have to buy any Zeitronix or other displays for AFR, EGT etc. Quote Link to comment Share on other sites More sharing options...
Piet Posted April 8, 2015 Report Share Posted April 8, 2015 http://www.volvo850forum.nl/index.php/topic,25665.msg1584983.html#msg1584983 1 1 Quote Link to comment Share on other sites More sharing options...
Avinitlarge Posted April 10, 2015 Report Share Posted April 10, 2015 For some reason, I keep on getting a checksum CEL. P0605/EFI-112. I haven't changed a thing in my file system, tried saving the BIN on 2 computers, The checksum updater DLL is in the correct place, TP says checksum updated. Quote Link to comment Share on other sites More sharing options...
MrCain Posted April 10, 2015 Report Share Posted April 10, 2015 For some reason, I keep on getting a checksum CEL. P0605/EFI-112. I haven't changed a thing in my file system, tried saving the BIN on 2 computers, The checksum updater DLL is in the correct place, TP says checksum updated. Try a fresh bin => also had this problem/cel in the beginning and was caused by a corrupted bin. Loaded a fresh new bin and cel never came back, think it was a checksum error or something like that. Quote Link to comment Share on other sites More sharing options...
Turboforslund Posted April 10, 2015 Report Share Posted April 10, 2015 Can it be a eeprom error? Have you reached the maximum numbers of flashing? Have you tried another ecu with the same bin? // Turboforslund Quote Link to comment Share on other sites More sharing options...
