Avinitlarge 81 Posted March 3, 2017 Report Share Posted March 3, 2017 2 hours ago, bomb192uk said: The links for the mil flash update don't work for me, anyone else having this issue? I managed to download the x64 versions before the link went downhttps://www.dropbox.com/s/rbrdivnuh5lxtwh/MIL Flash - 608 - x64.exe?dl=0 1 Quote Link to post Share on other sites
Dangerous Dave 23 Posted March 3, 2017 Report Share Posted March 3, 2017 2 hours ago, Avinitlarge said: I managed to download the x64 versions before the link went downhttps://www.dropbox.com/s/rbrdivnuh5lxtwh/MIL Flash - 608 - x64.exe?dl=0 Thanks for that bud There is a copy in the downloads section here, but it doesn't work. Quote Link to post Share on other sites
Tightmopedman9 1,020 Posted March 5, 2017 Author Report Share Posted March 5, 2017 I recently discovered an error in the code, I need to update the file, and I'll reupload it when I make the correction Quote Link to post Share on other sites
Dangerous Dave 23 Posted March 12, 2017 Report Share Posted March 12, 2017 Ah ok. Thanks for the update Quote Link to post Share on other sites
German850R 81 Posted April 2, 2017 Report Share Posted April 2, 2017 I have some doubts regarding the 1600 kg/h the BMW 3,25". I currently max the 1600 kg/h out at 5500 rpm with my EFR7064 at only ~1,6 bar of boost. Problem is, the compressor map suggests that the max flow of the turbo is at around 1500 kg/h. Has anyone else noticed something similar? Quote Link to post Share on other sites
venderbroeck 296 Posted April 2, 2017 Report Share Posted April 2, 2017 (edited) The higher voltage parts of the graph are very steep. So small errors in de model will be amplified. So really high kg/h numbers like that (almost twice the stock ceiling) can potentially be off quite a bit. It doesn't matter much tuning wise ofc, but it can throw off rough hp guesses. Edited April 2, 2017 by venderbroeck Quote Link to post Share on other sites
German850R 81 Posted April 3, 2017 Report Share Posted April 3, 2017 Yeah that makes sense. I think the 1600kg are more like 1400ish in reality. I have access to a flow bench through a friend so I might try that. 2 Quote Link to post Share on other sites
Avinitlarge 81 Posted April 6, 2017 Report Share Posted April 6, 2017 (edited) Nice easy one, In the ADX, Which do I use to log the TCV/BCS? Is it TVMBEG or XTV_VS? Edited April 6, 2017 by Avinitlarge Quote Link to post Share on other sites
German850R 81 Posted April 6, 2017 Report Share Posted April 6, 2017 1 hour ago, Avinitlarge said: Nice easy one, In the ADX, Which do I use to log the TCV/BCS? Is it TVMBEG or XTV_VS? VTVMBEG Quote Link to post Share on other sites
Turboforslund 26 Posted April 6, 2017 Report Share Posted April 6, 2017 (edited) Hi, I'm in search of a m4.4 non-turbo (naturally aspirated) binary from a b5254s (20v 170hp). Specific boschnumber is 0261204293. My aim is to create a xdf for it in order to tweak a few things. Is the only option to unsolder and make a readout of the bin? All motronic suite bins are turbo bins I asume..? Anyone who have a m4.4 N/A bin for me to play with in order to learn differences in between turbo an N/A bins? If someone have hade a look into them it would be super helpful if they are willing to share some knowledge. What to expext? Will the checksum plug-in work for non-turbo bins? Best regards turboforslund Edited April 6, 2017 by Turboforslund 1 Quote Link to post Share on other sites
rkam 39 Posted April 7, 2017 Report Share Posted April 7, 2017 0261204570-1037358289 is N/A B5254S I believe and has a damos file. I don't know if I have a copy of 0261204293, but I'll check if I can find the right disk drive this evening. Checksum is the same in all M4.4 as far as I know. Unsoldering is the safest known method to get the file from the chip I believe. Normal KWP reading will only read last 64kB. Quote Link to post Share on other sites
matmom42 0 Posted April 18, 2017 Report Share Posted April 18, 2017 Hello guys. I'm really amazed how you could do so many things using the stock volvo ECU. I am from Brazil and I have a Volvo 850 t5. Thanks to you guys I managed to get my car running with the m4.4 and E100 (lucky me I have plenty of this fuel here). I am still reading all this topic, but I found something here that can be useful to me. I use right now a wideband sensor just to log, but as I saw that we can use it as a closed loop lambda control. Am I right? How can that be done? Thank you for the support :) Quote Link to post Share on other sites
gdog 161 Posted April 19, 2017 Report Share Posted April 19, 2017 5 hours ago, matmom42 said: Hello guys. I'm really amazed how you could do so many things using the stock volvo ECU. I am from Brazil and I have a Volvo 850 t5. Thanks to you guys I managed to get my car running with the m4.4 and E100 (lucky me I have plenty of this fuel here). I am still reading all this topic, but I found something here that can be useful to me. I use right now a wideband sensor just to log, but as I saw that we can use it as a closed loop lambda control. Am I right? How can that be done? Thank you for the support :) 1 Quote Link to post Share on other sites
matmom42 0 Posted April 19, 2017 Report Share Posted April 19, 2017 18 hours ago, gdog said: Thank you, I will contact venderbroeck inbox Quote Link to post Share on other sites
Avinitlarge 81 Posted April 21, 2017 Report Share Posted April 21, 2017 Does anyone know the offset to add the baro/ambient pressure sensor to the ADX? Quote Link to post Share on other sites
