Raebird 0 Posted May 15, 2017 Report Share Posted May 15, 2017 I know it is frowned upon, but does anyone have a N/A bin so I can have a go at tuning my N/A S70? Quote Link to post Share on other sites
gmsgltr 1,948 Posted May 15, 2017 Report Share Posted May 15, 2017 OK... another noob question... I am having the same problem as this guy: https://www.tapatalk.com/topic/365873-17438 "NO HARDWARE FOUND" Using the same laptop, same cable, I have loaded tunes and logged before... (Two years ago) and was just able to get VOL-FCR to work and now I can't log anything on TP - any advice? Quote Link to post Share on other sites
Simply Volvo 846 Posted May 15, 2017 Report Share Posted May 15, 2017 54 minutes ago, gmsgltr said: OK... another noob question... I am having the same problem as this guy: https://www.tapatalk.com/topic/365873-17438 "NO HARDWARE FOUND" Using the same laptop, same cable, I have loaded tunes and logged before... (Two years ago) and was just able to get VOL-FCR to work and now I can't log anything on TP - any advice? Hardware not found means tunerpro hasn't found any emulation hardware such as the ostrich 2.0. You can safely ignore that. As for the logging not working, as long as you get connecting... after hitting the data acquisition button, logging should work fine. Quote Link to post Share on other sites
gmsgltr 1,948 Posted May 15, 2017 Report Share Posted May 15, 2017 OK, I still cannot get connected anymore though... When I hit the two arrows facing each other nothing initiates... I never get the 'salmon colored box' that Aaron explains on his PDF directions... (Sorry I don't have those available at the moment and the link on his site is currently down" I can take some screen shots this evening and post them up to make things more clear. - Thank you for the response Matt Quote Link to post Share on other sites
Simply Volvo 846 Posted May 15, 2017 Report Share Posted May 15, 2017 Sounds like the older 2.10 drivers got overwritten with the newer 2.12 drivers for the VAGCOM cable. This could be from windows updates or plugging in a different device that has a rt232 chipset which could've caused the latest Ftdi drivers to install. The 2.12 drivers will brick any non genuine FTDI rt232 chip by setting the PID to 0000. You can either reflash the chip with a different PID or use modified drivers. I would contact Aaron I believe he has a patched version that accepts devices with the PID 0000. 1 Quote Link to post Share on other sites
gmsgltr 1,948 Posted May 15, 2017 Report Share Posted May 15, 2017 Will do - thank you! Quote Link to post Share on other sites
Raebird 0 Posted May 15, 2017 Report Share Posted May 15, 2017 11 hours ago, Raebird said: I know it is frowned upon, but does anyone have a N/A bin so I can have a go at tuning my N/A S70? Nothing? Is there such thing as an N/A bin? I really would like to try tuning my S70, any help is much appreciated... Quote Link to post Share on other sites
Simply Volvo 846 Posted May 16, 2017 Report Share Posted May 16, 2017 1 hour ago, Raebird said: Nothing? Is there such thing as an N/A bin? I really would like to try tuning my S70, any help is much appreciated... This should be a V70 NA file and damos http://droid.arm.ee/volvo/DAMOS/0261204570_1037358289.bin http://droid.arm.ee/volvo/DAMOS/0261204570_1037358289.dam The damos will have to be converted from dot codepage to ansi to be usable. Quote Link to post Share on other sites
Raebird 0 Posted May 16, 2017 Report Share Posted May 16, 2017 10 hours ago, Simply Volvo said: This should be a V70 NA file and damos http://droid.arm.ee/volvo/DAMOS/0261204570_1037358289.bin http://droid.arm.ee/volvo/DAMOS/0261204570_1037358289.dam The damos will have to be converted from dot codepage to ansi to be usable. Am I doing something wrong? all the links do is take me to the host site to tell me that the domain is available... Quote Link to post Share on other sites
Avinitlarge 81 Posted May 16, 2017 Report Share Posted May 16, 2017 Mercuric's droid expired ages ago. I think someone has a back up of it though Quote Link to post Share on other sites
Avinitlarge 81 Posted May 16, 2017 Report Share Posted May 16, 2017 9 hours ago, Raebird said: Am I doing something wrong? all the links do is take me to the host site to tell me that the domain is available... Try thishttp://volvov70r.co.uk/Volvo/Mercuric's droid/volvo/DAMOS/0261204570_1037358289.zip Quote Link to post Share on other sites
Raebird 0 Posted May 20, 2017 Report Share Posted May 20, 2017 On 17/05/2017 at 5:48 AM, Avinitlarge said: Try thishttp://volvov70r.co.uk/Volvo/Mercuric's droid/volvo/DAMOS/0261204570_1037358289.zip Thanks avinitlarge, it needs to be converted to an xdf right? Quote Link to post Share on other sites
Raebird 0 Posted May 20, 2017 Report Share Posted May 20, 2017 On 16/05/2017 at 10:21 AM, Simply Volvo said: This should be a V70 NA file and damos http://droid.arm.ee/volvo/DAMOS/0261204570_1037358289.bin http://droid.arm.ee/volvo/DAMOS/0261204570_1037358289.dam The damos will have to be converted from dot codepage to ansi to be usable. Simply Volvo, how do I convert from dot to ansi? Quote Link to post Share on other sites
Simply Volvo 846 Posted May 22, 2017 Report Share Posted May 22, 2017 On 5/20/2017 at 5:16 AM, Raebird said: Simply Volvo, how do I convert from dot to ansi? http://www.webutils.pl/index.php?idx=conv&charset=cp437 This should work. Select cp437 to ANSI. Quote Link to post Share on other sites
Varney 1 Posted May 25, 2017 Report Share Posted May 25, 2017 This is beautiful, I wish I had found this when I still had my '98 xc, Is there something like this for ME7 tuning? Quote Link to post Share on other sites
