ejenner Posted February 7, 2018 Report Share Posted February 7, 2018 I quite fancy the idea of making my 2004 C70 2.0t up to high pressure. It is currently low pressure. I don't want to go crazy with this car... just a quick boost tweak is all I'm looking for. Can someone answer the following questions and give me any other help that's necessary to complete the job: 1. Interface cable from eBay, has anyone got a link. 2. Software for laptop. I've seen TunerPro... but is anything else required. 3. Can I load a standard Volvo .bin straight to the ECU to upgrade my car from a lower output model to higher power? If so, has anyone got that .bin file I could use? Quote Link to comment Share on other sites More sharing options...
NB-V70R Posted February 7, 2018 Report Share Posted February 7, 2018 Either read all 460 pages of this thread or head over to http://m44.wikia.com/wiki/M44_Wiki I recommend the second. Many people have put in a lot of work to make that a great resource. Once you get a bit of basic knowledge, you can ask specific questions that haven't been answered previously. Thanks! Quote Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted February 8, 2018 Author Report Share Posted February 8, 2018 @ejenner2004 is ME7. None of this thread pertains to your car. 1 Quote Link to comment Share on other sites More sharing options...
Phillyc2003 Posted February 12, 2018 Report Share Posted February 12, 2018 (edited) Is there access to the boost control mod please or is it a for specific folks? (or boostmod is it meant by part p hack)?? And Piet i recall reference to you saying you have set up methanol injection and a safe guard for it that when runs low map switches? is that correct (any more information regarding this would be greatly appreciated). I have been using the map switching function to aid testing with as don't have an ostrich so 4 maps at a time with logging is working nicely for me . Edited February 12, 2018 by Phillyc2003 Quote Link to comment Share on other sites More sharing options...
oblark Posted February 13, 2018 Report Share Posted February 13, 2018 In tunerpro under idle/start up there's "Start Basic Injection Quantity" does this effect the AFR when the engine is idling ? Quote Link to comment Share on other sites More sharing options...
Piet Posted February 14, 2018 Report Share Posted February 14, 2018 (edited) On 12-2-2018 at 7:44 PM, Phillyc2003 said: Is there access to the boost control mod please or is it a for specific folks? (or boostmod is it meant by part p hack)?? And Piet i recall reference to you saying you have set up methanol injection and a safe guard for it that when runs low map switches? is that correct (any more information regarding this would be greatly appreciated). I have been using the map switching function to aid testing with as don't have an ostrich so 4 maps at a time with logging is working nicely for me . Edited February 14, 2018 by Piet 1 Quote Link to comment Share on other sites More sharing options...
Phillyc2003 Posted February 15, 2018 Report Share Posted February 15, 2018 Cheers Piet Regarding map/ bin for it is there aid you can pount me in dirrection for mod if poss as i hope to get this done in spring . Quote Link to comment Share on other sites More sharing options...
Piet Posted February 16, 2018 Report Share Posted February 16, 2018 You have to contact Venderbroeck for that, he sells our mods. 1 Quote Link to comment Share on other sites More sharing options...
Phillyc2003 Posted February 16, 2018 Report Share Posted February 16, 2018 On 2/13/2018 at 8:46 PM, oblark said: In tunerpro under idle/start up there's "Start Basic Injection Quantity" does this effect the AFR when the engine is idling ? surely that's just regarding warm up as in until a certain temp reached, my wide-band runs rich whilst warm up so i think it in relation to that. Quote Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted February 17, 2018 Author Report Share Posted February 17, 2018 On 2/13/2018 at 1:46 PM, oblark said: In tunerpro under idle/start up there's "Start Basic Injection Quantity" does this effect the AFR when the engine is idling ? That's just for the amount of fuel injected when cranking. Quote Link to comment Share on other sites More sharing options...
Phillyc2003 Posted February 18, 2018 Report Share Posted February 18, 2018 On 2/16/2018 at 4:44 PM, Piet said: You have to contact Venderbroeck for that, he sells our mods. i have pm'd him hopefully he get back to me 1 Quote Link to comment Share on other sites More sharing options...
Acki Posted February 19, 2018 Report Share Posted February 19, 2018 Is it possible to get the IDA file of the bin? I'm working on my older Motronic and from the comments the the datalog add-on I would expect some helpful information for my Motronic. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
German850R Posted March 1, 2018 Report Share Posted March 1, 2018 What would be the easiest way to switch off the LDR for tuning purposes? I'd like to run an engine off TCV for testing and log the achieved load and then put these load values into the target load setpoint map. Just zero the target load map? Quote Link to comment Share on other sites More sharing options...
Jameshufford Posted March 1, 2018 Report Share Posted March 1, 2018 (edited) I’m having trouble getting started with tunerpro I have tunerpro and all of the files from the m4.4 wiki but it won’t recognize my cable I’m using one from amazon that is called obdlinksx it is a obd2 to usb and it came with a license for obdwiz and that program works with my car and everything connects really simple but tunerpro rt wont ev recognize my cable Edited March 1, 2018 by Jameshufford Quote Link to comment Share on other sites More sharing options...
Piet Posted March 2, 2018 Report Share Posted March 2, 2018 (edited) In car Flashing without a stepupconverter: Remove this chip: and replace it with a 330 ohm resistor and 12 volt zenerdiode like this: Edited March 2, 2018 by Piet 1 Quote Link to comment Share on other sites More sharing options...
