Roberts0315 Posted July 4, 2019 Report Share Posted July 4, 2019 5 minutes ago, Turboforslund said: Good, I hope you know it is only pin b8 that needs +15V or so to be able to flash. All the other pins can keep the 12V supply. // Turboforslund So you suggesting to put all pins except B8 from battery voltage? Quote Link to comment Share on other sites More sharing options...
dirtzuk Posted July 5, 2019 Report Share Posted July 5, 2019 This may be a dumb question but im wondering if a M4.4 ecu from a 1996 volvo 960 (B6304S) is capable of being reflashed to run a B5234T I searched for a while through forums and cant find anything specific on this.. Im doing a 5cyl swap into an offroad buggy and Ive got a complete running 96 960 as a parts car, mainly for the bell housing, engine mounts and oil pan, but if I could use the m4.4 ecu along with the coil on plug setup that would be a bonus! Quote Link to comment Share on other sites More sharing options...
Dangerous Dave Posted July 5, 2019 Report Share Posted July 5, 2019 The B6304 ecu wont have the components fitted to run the turbo control valve, etc. Quote Link to comment Share on other sites More sharing options...
Turboforslund Posted July 5, 2019 Report Share Posted July 5, 2019 960 is motronic 1.8 i guess. Quote Link to comment Share on other sites More sharing options...
Chuck W Posted July 6, 2019 Report Share Posted July 6, 2019 On 7/4/2019 at 5:17 PM, Roberts0315 said: So you suggesting to put all pins except B8 from battery voltage? I use a 14V power supply to feed pins A12, A26, A27 and B8 as well as pin 16 on the OBD connector. Flashes just fine. Quote Link to comment Share on other sites More sharing options...
Roberts0315 Posted July 6, 2019 Report Share Posted July 6, 2019 1 minute ago, Chuck W said: I use a 14V power supply to feed pins A12, A26, A27 and B8 as well as pin 16 on the OBD connector. Flashes just fine. when you are powering pin b8? before all otherto be powered or all them together? Quote Link to comment Share on other sites More sharing options...
Chuck W Posted July 6, 2019 Report Share Posted July 6, 2019 4 hours ago, Roberts0315 said: when you are powering pin b8? before all otherto be powered or all them together? It is all just plugged in at once. Wired as the pic on the Wiki, including connecting OBD pin 4 to ground. I just made a special flashing harness from old ECU and OBD connectors. Plugs into the ECU and the OBD/USB cable. Quote Link to comment Share on other sites More sharing options...
Roberts0315 Posted July 6, 2019 Report Share Posted July 6, 2019 So I got cable wich one side is obd other is just wires. All wires tested everything is like in picture. Farest I can get is Erasing flash. So then tried if I can at all access ecu. So I can read DTC's with one program and can see live data with Motronic suite. So it seems cable is working. I have tried that on WinXP Win7 64bit and Win732bit. Everything same Quote Link to comment Share on other sites More sharing options...
Chuck W Posted July 6, 2019 Report Share Posted July 6, 2019 I started with an ECU connector and wires, so all I had to do was connect 3 wires to the OBD-side of the USB. The only time I had an failed flash was when one of the wires came loose. It would still flash if everything stayed in place. Once I grabbed the OBD connector from a car in the JY, I haven't had an issue with a bad connection. I've only flashed maybe 10 times, but it works. You say it's "like in picture", but your set-up isn't, seeing as you're connecting ground to #4 and not #5. Are you also positive that you are connected to the proper pins on the OBD for flashing? Quote Link to comment Share on other sites More sharing options...
Roberts0315 Posted July 6, 2019 Report Share Posted July 6, 2019 Its both negative connected 4# and 5# , positive to 16# and k-line to 7#, I believe if it would be wiring I wouldnt be able to connect to ecu at all, but ai can, only flashing is not possible Quote Link to comment Share on other sites More sharing options...
98s70t5mvt Posted July 7, 2019 Report Share Posted July 7, 2019 (edited) if launch control setting is stored in the xdf can you just set parameters with any bin file? Edited July 8, 2019 by 98s70t5mvt Quote Link to comment Share on other sites More sharing options...
Dangerous Dave Posted July 7, 2019 Report Share Posted July 7, 2019 The only way to read the eprom is to read the chip directly (with a special adapter or by removing the chip and reading separately). As I remember, the first half of the eprom can be read but the second half can't. Quote Link to comment Share on other sites More sharing options...
Avinitlarge Posted July 7, 2019 Report Share Posted July 7, 2019 I use a Willem to read the chips. I’ve got a stock 611 and 612 file also got a 611 Rica file Quote Link to comment Share on other sites More sharing options...
98s70t5mvt Posted July 8, 2019 Report Share Posted July 8, 2019 (edited) 612 Was in motronic suite. But that's cool, watched video Jimmy oakes where they read data on a stock m.4.2 bimmer ecu. Obviously raw data but they were using romraider xml's to interpret parameters. I'm sure that's how all this started as well you guys putting work in creating xdf's. Edited July 8, 2019 by 98s70t5mvt Quote Link to comment Share on other sites More sharing options...
dirtzuk Posted July 9, 2019 Report Share Posted July 9, 2019 so my 96' 960 has a 0 261 203 654 and according to the net it is infact a m4.4 .. it would be lacking hardware to run boost control? it would be very cool if i could use this ecu along with the 960 coil packs on a b5234t Quote Link to comment Share on other sites More sharing options...
