21 hours ago, dirtzuk said:
so my 96' 960 has a 0 261 203 654 and according to the net it is infact a m4.4 ..  it would be lacking hardware to run boost control?  it would be very cool if i could use this ecu along with the 960 coil packs on a b5234t
There is already a mod available to run coil packs on a B5234T M4.4 ecu.  It involves a little hardware modification but is probably easier than trying to modify the 960 ecu to run boost control.
Have a look at Piet and Venderbroek's posts for more info
Edited by bomb192uk
OK, so I'm finally getting around to putting together a "base" tune on the hybrid -607/-936 bin for the wife's '97GLT. I'm taking the -607 that Piet put the -936 AC routines into as the start, and transferring some base values from the -936 bin to get us something to begin with.
@Turboforslund put together the XDF from the -936 chip that I sent him, which was awesome.
Looking over things, the first thing that stands out are a couple extra RPM axes in the -936.
RPMaxes.jpg[/img]
axiscompare.jpg[/img]
As you can see, the RPM value ranges are different, and he notes their possible usage in the first pic.
Comparing a couple of the charts for the affected maps
valuecompare.jpg[/img]
Should I worry about trying to add/change those axes in the bin I'm putting together, or just leave them as the fixed major RPMs?
The "start" point for the tune is an '01 LPT motor, Japanifold w/ 16T and exhaust, and blue injectors. (No COP or ExVVT yet)
Maybe leave the fixed Major RPMs and alter some of the values in the other RPM ranges on the -607 to match the -936 stuff?
Thoughts?
Links to the -936 bin and the XDF
XDF
936 BIN
Edited by Chuck W
On 7/10/2019 at 8:53 AM, Avinitlarge said:
On a x70 NA ecu, all you have to do to get boost control to work is remove one resistor and add 2 zero ohm resistors, I imagine it’s the same on a 960 ecu. I have a high res scan of a 960 ecu so will try and look at it later.
Nice and easy then
On 20.06.2019 at 09:09, Calvin Sonnik said:
Bang Bang? lub więcej trzeszczenia decel? Oto jedno, które zrobiłem ... Przepływa około 800-900 KG / h podczas huku bang. To musi być piekło dla zaworów wydechowych.
Mam XDF niedługo zakończony TM
Powinien mieć to i kilka innych gadżetów.
I want to get a pop bang effect when the turnover decreases. what you did is nls.
This is pop bangs
The logging needs to be enabled by sending a code to the ecu (as you may have read).
You say you are using a serial port? Is that as in old school 9 pin D connector serial port? Have you selected the port correctly in tunerpro?
Usually the code is sent from tunerpro to the ecu when you click connect.  Which ADX file are you using (what is the filename)?
To use realterm you need to make sure you have the correct com port selected and change the baud rate.
Yup, that's the old school DB9. I am using the rev5.ADX, does the XDF need to match because I am currently using the rev6.xdf.
These are my current settings, I matched what the wiki said.
It's funny, when I click the "Test for a Valid Interface" button in TunerPro It say's it's valid, then the next time I click it it gives me an error. Works, Doesn't, Works, Doesn't, Works. Alternates perfectly. Like I said I can flash just fine, have done so 4 times already. Just can't connect for logging.
Edited by WellThatsSurprising
Is it possible to get a clarification on this for the auto bin? (Sorry to dredge up the old post)
Should the addresses and changes be 3D69 and 3D6A (12 88 to 00 00) and 4113 and 4114 (7D AD to 7D AE)?
Thanks!
On 2/2/2016 at 6:28 AM, Avinitlarge said:
Or disable the pre-start listener, I think its 4 values that need changing, venderbroeck did mine for me
I believe these are the differences on a manual bin, not sure if auto is the same
On 2/2/2016 at 1:50 PM, Piet said:
Nope, they are not the same for an automatic bin!
For the automatic bin change:
@ 3C69  12 88 into 00 00
@4113  7C AD into 7D AE
The result of this however will be that:
-With the engine not running there will always be normal OBD functionality and no logging functionality.
-With the engine running there will be always logging functionality and no OBD functionality
3 hours ago, bomb192uk said:
What does the 'Test for Valid Interface Settings' bring back?
This is what I get when it doesn't work. Alternatively it will give me a success message but still won't start datalogging. It seems to switch between working and not working at random. Tring to connect through Realterm@125000baud results in a parameter is incorrect error.
What operating system are you running?
 Share
