gdog 161 Posted February 24, 2020 Report Share Posted February 24, 2020 On 2/22/2020 at 4:22 PM, ItalianT5 said: Hello, I am having troubles flashing my ECU. I am using the following OBD cable: https://www.ebay.de/itm/Diagnostischen-FTDI-OBD2-FT232RL-BMW-INPA-Ediabas-USB-fur-DCAN-Kabelwerkzeug-H/303324951331?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160727114228%26meid%3Db279ccc8bc4743859bd97ddc01231b2e%26pid%3D100290%26rk%3D2%26rkt%3D4%26sd%3D231461230279%26itm%3D303324951331%26pmt%3D0%26noa%3D1%26pg%3D2060778&_trksid=p2060778.c100290.m3507 I use 16.2 volts on B8 to go into bootmode, but all I get while trying to flash in Motronic Suite is "Erase failed". I also editet the config file and added my COM port, but nothing works. Do I use the wrong OBD cable or are there any more possible problems I have to check first for? Thanks in advance Can't tell if that's the right cable or not. I always look for some reference to Triumph motorcycles, like this: https://www.ebay.com/itm/USB-cable-for-Triumph-Motorcycles-TuneECU-FTDI-FT232RL-Chip-OBD-II-KTM-Tune-ECU-/122549303447 But assuming you do have the right cable, you need to make sure you have hooked up all the ecu power and ground wires, and no loose connections. Just hooking up one or two of them isn't going to do it. Use similar gauge wire that's in the car too. Quote Link to post Share on other sites
Tightmopedman9 1,020 Posted February 26, 2020 Author Report Share Posted February 26, 2020 That cable you linked is the incorrect cable. You need a VAG-COM cable, which is a 'dumb' cable which does nothing to the signal between the OBDII port and computer. Make sure that you get a VAG-COM cable with FTDI chip. Quote Link to post Share on other sites
O.R 3 Posted March 27, 2020 Report Share Posted March 27, 2020 Hi Can someone share settings for 100% E85 cold start, i have trouble to get engine running when engine and weather is cold, it need multiple short starts to get it running. Quote Link to post Share on other sites
jenksta 10 Posted April 1, 2020 Report Share Posted April 1, 2020 (edited) Been lurking here for a while, but would like to say a big thanks to everyone who has contributed/helped with this as I wouldn't got so interested in it otherwise Just thought i'd share my IDA database that I've been working on for the past couple of weeks (pretty new to all of this) in case it can be of use to anyone (based on custom/wiki 607 rev 5b). It isn't the best but has the upper/lower bank disassembled/segmented and sorted (mostly) so that the disassembly makes sense (as well as sorting alot of the duplicated upper/lower bank funcs) (upper bank stuff mostly has _UB suffix). Also using the DAMOS and some other sources traced and labelled most of the ROM (v_ prefix) vars (mostly lower bank for now, will duplicate to upper bank later), RAM (r_ prefix), XRAM (xr_ prefix) and SCL (scl_ prefix) addresses. For the disassembly constants I linked them to the applicable CODE/ROM, XRAM or SCL segment for ease of disassembly/cross referencing (using virtual segments for XRAM and SCL offsets). The function naming is mostly vague and poor but can give a rough idea to some of the disassembly (although some may be incorrect based on earlier guesses before I started looking at the functions properly). As it's based on the custom/wiki rev 5b I've also labelled the custom functions/vars that are part of that too (mostly labelled with CUSTOM_ prefix). As I say alot of it has been compiled from multiple sources/references scoured from pretty much everywhere so lost track of who and what, but not claiming as mine - just couldn't keep track of everything. Download: https://drive.google.com/file/d/1cUPIOqOU0KckyA52apXzQq5ZVJ_LkT4s/view?usp=drivesdk Edited April 2, 2020 by jenksta 1 1 Quote Link to post Share on other sites
Tightmopedman9 1,020 Posted April 3, 2020 Author Report Share Posted April 3, 2020 Thanks very much for that! I've spent a lot of time in IDA and I tried for a little while to import RAM variable names, but couldn't figure out an automated way to do it so I gave up on it. Did you write a script, or is there some easy way I'm totally missing? Quote Link to post Share on other sites
jenksta 10 Posted April 4, 2020 Report Share Posted April 4, 2020 On 4/3/2020 at 4:33 PM, Tightmopedman9 said: Thanks very much for that! I've spent a lot of time in IDA and I tried for a little while to import RAM variable names, but couldn't figure out an automated way to do it so I gave up on it. Did you write a script, or is there some easy way I'm totally missing? No worries, hopefully someone can make use of it someday haha. The XRAM vars I did do with a script, however everything else was done manually (sounds really tedious but I'm used to it so wasn't too bad). For the ROM variables I mostly just referenced vars I'd found in a function or something and go around that address double checking the byte patterns to ensure it was the same and nothing was added/removed in the different versions, then naming them (could have been scripted but just easier for me to carry on manually). When i started with the ROM vars I was putting descs in from the damos, but got tedious so in the end I decided to just name them, and have since managed to mostly figure out the DAMOS text file format, so will write a script to insert all the translated descriptions, data types and sizes from there then duplicate any to the upper bank if needed. The offsets in the code were admittedly all done manually by searching for hex offsets in the mov DPTR instruction , figuring out what its referencing (ROM, SCL, XRAM, e.t.c.) then using ALT+R (set base for offset) to set it as a ROM/RAM/XRAM/SCL offset (again probably could have been done with a script but meh haha), makes it so much easier to understand the code with them set though. One of the other things too was creating a seperate code segment for the upper bank so that any references in instructions point correctly to the upper bank and not the lower bank (also helps when IDA does the automatic disassembly as it can understand them properly so does alot more for you). Would have been relatively easy to do it on the blank file but chose to do it after I'd already done alot of work so the only way was to use IDC/Python to manipulate the segments slightly as otherwise it would destroy everything I'd already done. Bit late to the party as I know you guys have worked on this for years, but as only recently got an 850/4.4 and never touched 8051 stuff before I've learnt alot and also picked up some IDA tricks on the way, but worth it in the end Quote Link to post Share on other sites
Tightmopedman9 1,020 Posted April 8, 2020 Author Report Share Posted April 8, 2020 (edited) I really appreciate the work, I've been working on a routine to log the cam angle, but haven't made much progress - this will really speed things up since cross referencing the DAMOS gets pretty tedious after only a few lookups. I'd like to monitor cam angle for VVT purposes. NVM on the following stuff, P1.6 is the external clock output. I'm assuming that the cam signal is tied to P1.6. In Reset_0 the status of P1.6 is moved into r_FLAG1.7 (camshaft level with status 'found_located' (PH_OLD)). In the crankshaft triggered interrupt, IEX3,there is a JB based on r_FLAGBM.4 (phase change not yet recognized. (ZDGVERB)), if this bit is set then the status of P1.6 is checked. Since P1.6 is tied to IEX6 and IEX6 isn't used, I assume you could write a bit of code that moves the crank angle to a spare XRAM when IEX6 is triggered. Based on the sab80c517a datasheet it looks like the interrupt would fire at the rising and falling edge, so you could poll the status of P1.6 and have a separate XRAM depending on which edge triggered the interrupt. This would allow you to see the relative motion of the cam angle when triggering the VVT solenoids. I'm having trouble finding the variable that contains the crank angle in .75º degree increments, if it even exists. Edited April 8, 2020 by Tightmopedman9 Quote Link to post Share on other sites
Dangerous Dave 23 Posted April 9, 2020 Report Share Posted April 9, 2020 Aaargh, I can't open the file. IDA says the database format is too old. What version are you using to view it? Quote Link to post Share on other sites
jenksta 10 Posted April 9, 2020 Report Share Posted April 9, 2020 24 minutes ago, bomb192uk said: Aaargh, I can't open the file. IDA says the database format is too old. What version are you using to view it? I use 6.8, if you're using the latest free/trial version you may need to either source the 6.8 one or get your black hat on if you know what i mean. 3 Quote Link to post Share on other sites
jenksta 10 Posted April 9, 2020 Report Share Posted April 9, 2020 On 4/8/2020 at 6:56 PM, Tightmopedman9 said: I really appreciate the work, I've been working on a routine to log the cam angle, but haven't made much progress - this will really speed things up since cross referencing the DAMOS gets pretty tedious after only a few lookups. I'd like to monitor cam angle for VVT purposes. NVM on the following stuff, P1.6 is the external clock output. I'm assuming that the cam signal is tied to P1.6. In Reset_0 the status of P1.6 is moved into r_FLAG1.7 (camshaft level with status 'found_located' (PH_OLD)). In the crankshaft triggered interrupt, IEX3,there is a JB based on r_FLAGBM.4 (phase change not yet recognized. (ZDGVERB)), if this bit is set then the status of P1.6 is checked. Since P1.6 is tied to IEX6 and IEX6 isn't used, I assume you could write a bit of code that moves the crank angle to a spare XRAM when IEX6 is triggered. Based on the sab80c517a datasheet it looks like the interrupt would fire at the rising and falling edge, so you could poll the status of P1.6 and have a separate XRAM depending on which edge triggered the interrupt. This would allow you to see the relative motion of the cam angle when triggering the VVT solenoids. I'm having trouble finding the variable that contains the crank angle in .75º degree increments, if it even exists. R.E. the crank angle - correct me if i'm wrong but if it was me I'd work off of the ignition dwell time as that works in degrees of crankshaft rotation? Just had a quick look and there's some code around code1:BF9A (UB/1BF9A) to do with firing/dwell angle that might point in the right direction. Quote Link to post Share on other sites
SheaBae 0 Posted April 15, 2020 Report Share Posted April 15, 2020 Hey, got a question about the rev5b.bin, sorry in advance if im dropping this question in the wrong place, is the rev5b stock as in for orange injectors and a 15G/T? Im currently running a 608_rev5b flashed ECU calibrated for green injectors but am going back to orange to see if my MPG will improve. Just wondering if anyone has input on this because the bins 608_rev5b and 608_rev5b18PSI both have different injector calibration values from whats listed on the wiki. Don't know which to trust. I also have some red injectors from a v70, are those comparable to oranges? (not the insane 1Kcc reds lol) My car, for reference: 94 850 turbo, manual swapped, m4.4, 15T, no cat, straight pipe with a autozone muffler. Quote Link to post Share on other sites
jenksta 10 Posted April 15, 2020 Report Share Posted April 15, 2020 12 hours ago, SheaBae said: Hey, got a question about the rev5b.bin, sorry in advance if im dropping this question in the wrong place, is the rev5b stock as in for orange injectors and a 15G/T? Im currently running a 608_rev5b flashed ECU calibrated for green injectors but am going back to orange to see if my MPG will improve. Just wondering if anyone has input on this because the bins 608_rev5b and 608_rev5b18PSI both have different injector calibration values from whats listed on the wiki. Don't know which to trust. I also have some red injectors from a v70, are those comparable to oranges? (not the insane 1Kcc reds lol) My car, for reference: 94 850 turbo, manual swapped, m4.4, 15T, no cat, straight pipe with a autozone muffler. It's setup for these (https://www.injectorplanet.com/products/bosch-0280155766), they flow slightly more than the stock oranges (stock orange is 315cc, these flow 347cc). To set it up for oranges, in TunerPro copy the 3 values and 1 table under 'Injector Calibration' from the 18PSI bin as that's setup for oranges. Quote Link to post Share on other sites
Dangerous Dave 23 Posted April 18, 2020 Report Share Posted April 18, 2020 (edited) On 4/15/2020 at 3:48 AM, SheaBae said: Hey, got a question about the rev5b.bin, sorry in advance if im dropping this question in the wrong place, is the rev5b stock as in for orange injectors and a 15G/T? Im currently running a 608_rev5b flashed ECU calibrated for green injectors but am going back to orange to see if my MPG will improve. Just wondering if anyone has input on this because the bins 608_rev5b and 608_rev5b18PSI both have different injector calibration values from whats listed on the wiki. Don't know which to trust. I also have some red injectors from a v70, are those comparable to oranges? (not the insane 1Kcc reds lol) My car, for reference: 94 850 turbo, manual swapped, m4.4, 15T, no cat, straight pipe with a autozone muffler. I wouldn't bother going back to oranges. Just tune the injector constant and the dead times to the greens. Greens flow approx. 413cc at 3bar. The injector constant for this should be 0.7656250. Then you will have to tune the dead times but for this you'll need a wideband O2 sensor. Some people have posted their dead times for greens on this thread, but they all differ for various reasons so be wary of using them. More info on tuning injectors here https://m44.fandom.com/wiki/Tuning_the_Injector_constant_and_dead_times Definitely get this sorted as the wrong fuelling can cause issues especially when the engine is under load Edited April 18, 2020 by bomb192uk 2 Quote Link to post Share on other sites
ArMiGer 18 Posted April 18, 2020 Report Share Posted April 18, 2020 Better flow test the injectors first. I did test the greens i have and they was exactly 450cc at 3 bars. Quote Link to post Share on other sites
Dangerous Dave 23 Posted April 18, 2020 Report Share Posted April 18, 2020 According to the datasheets Greens should flow 453cc at 3 bar on N-Heptane but on petrol/gasoline they flow 413cc. How were yours tested? Quote Link to post Share on other sites
