Midnight Caller Posted August 1, 2022 Report Share Posted August 1, 2022 (edited) There is another 2D map with boost reduction by gear which has to be set to 1 all across. It's in the XDF, just can't remember now the exact name. Later Edit - Set to "1" all values in the "Boost pressure reduction factor, manual transmission" map (FLDABMTN) and you should unleash full boost since 1st gear. Enjoy Edited August 4, 2022 by Midnight Caller Quote Link to comment Share on other sites More sharing options...
Dangerous Dave Posted August 13, 2022 Report Share Posted August 13, 2022 (edited) On 6/7/2022 at 1:24 PM, Chuck W said: Pretty sure that's what is done in my longer post above. At least that's based on the instructions I got from Aaron. The VE map was converted to the AFR map and the Alternate 1 VE Part Load map becomes the target AFR map. None of the signal grounds I have tried are supposed to have any offset in them, and I'm using the Tank Pressure sensor ADC for the input. There is something set-up or configured wrong, but I can't seem to find it. I just had a quick look at your binary. Noticed that the long term fuel trims have values in them. In other WB binaries those have been zeroed. Is this not the case with your binary (is it a newer version?) What I can also do is try your bin on my car (as I have COP and WB) see if I get the same results Edited August 13, 2022 by Dangerous Dave Quote Link to comment Share on other sites More sharing options...
Chuck W Posted August 14, 2022 Report Share Posted August 14, 2022 11 hours ago, Dangerous Dave said: I just had a quick look at your binary. Noticed that the long term fuel trims have values in them. In other WB binaries those have been zeroed. Is this not the case with your binary (is it a newer version?) What I can also do is try your bin on my car (as I have COP and WB) see if I get the same results Hi- I had to look back, but I haven't changed anything in the tune/bin since May. I'm a little confused, as I don't remember being able to zero out the LTFT in the binary at all. Are you talking about the limit and range settings? I hadn't heard that those needed to be changed/adjusted. I haven't had a chance to get another WBO2 sensor on there to verify that those offset values I'm seeing are real or not. As I mentioned before, the car drives fine (actually better than before I did this mod), but I'd like to sort this out before I start making any other changes to the tune. (Also, still trying to figure out the proper conversion factor for the MAP sensor, to get it in usable units.) Quote Link to comment Share on other sites More sharing options...
Dangerous Dave Posted August 14, 2022 Report Share Posted August 14, 2022 (edited) 11 hours ago, Chuck W said: Hi- I had to look back, but I haven't changed anything in the tune/bin since May. I'm a little confused, as I don't remember being able to zero out the LTFT in the binary at all. Are you talking about the limit and range settings? I hadn't heard that those needed to be changed/adjusted. I haven't had a chance to get another WBO2 sensor on there to verify that those offset values I'm seeing are real or not. As I mentioned before, the car drives fine (actually better than before I did this mod), but I'd like to sort this out before I start making any other changes to the tune. (Also, still trying to figure out the proper conversion factor for the MAP sensor, to get it in usable units.) Sorry, yes I meant zero the all limits of LTFT. It shouldn't matter anyway really as the code probably bypasses the fuel trims (I haven't dived into it yet). ̶I̶ ̶n̶o̶t̶i̶c̶e̶d̶ ̶t̶h̶e̶ ̶c̶o̶n̶v̶e̶r̶s̶i̶o̶n̶ ̶y̶o̶u̶ ̶u̶s̶e̶ ̶f̶o̶r̶ ̶y̶o̶u̶r̶ ̶S̶p̶a̶r̶t̶a̶n̶ ̶i̶n̶ ̶T̶P̶ ̶i̶s̶ ̶(̶(̶x̶+̶4̶0̶)̶*̶0̶.̶0̶4̶)̶+̶1̶0̶.̶ ̶ ̶I̶n̶ ̶m̶y̶ ̶T̶P̶ ̶s̶e̶t̶t̶i̶n̶g̶s̶ ̶I̶ ̶u̶s̶e̶ ̶ ̶(̶X̶*̶0̶.̶0̶3̶9̶2̶1̶5̶6̶8̶6̶)̶+̶1̶0̶ ̶w̶h̶i̶c̶h̶ ̶m̶a̶t̶c̶h̶e̶s̶ ̶m̶y̶ ̶S̶p̶a̶r̶t̶a̶n̶ ̶o̶u̶t̶p̶u̶t̶ ̶(̶h̶a̶v̶e̶ ̶a̶ ̶d̶i̶s̶p̶l̶a̶y̶ ̶o̶n̶ ̶t̶h̶e̶ ̶S̶p̶a̶r̶t̶a̶n̶ ̶c̶o̶n̶t̶r̶o̶l̶l̶e̶r̶)̶.̶ ̶ ̶I̶ ̶t̶r̶i̶e̶d̶ ̶y̶o̶u̶r̶ ̶m̶a̶p̶ ̶o̶n̶ ̶m̶y̶ ̶c̶a̶r̶ ̶a̶n̶d̶ ̶i̶t̶ ̶r̶a̶n̶ ̶f̶i̶n̶e̶ ̶h̶o̶v̶e̶r̶i̶n̶g̶ ̶a̶r̶o̶u̶n̶d̶ ̶1̶4̶.̶7̶ ̶A̶F̶R̶ ̶a̶t̶ ̶i̶d̶l̶e̶ ̶b̶u̶t̶ ̶t̶a̶r̶g̶e̶t̶ ̶A̶F̶R̶ ̶w̶a̶s̶ ̶h̶i̶g̶h̶e̶r̶.̶ ̶M̶a̶y̶b̶e̶ ̶i̶f̶ ̶y̶o̶u̶ ̶t̶r̶y̶ ̶t̶h̶e̶ ̶c̶o̶n̶v̶e̶r̶s̶i̶o̶n̶ ̶a̶b̶o̶v̶e̶ ̶t̶o̶ ̶g̶e̶t̶ ̶a̶ ̶d̶i̶f̶f̶e̶r̶e̶n̶t̶ ̶t̶r̶a̶n̶s̶l̶a̶t̶i̶o̶n̶ ̶t̶a̶b̶l̶e̶ ̶f̶o̶r̶ ̶t̶h̶e̶ ̶W̶i̶d̶e̶b̶a̶n̶d̶?̶ ̶ ̶A̶l̶s̶o̶ ̶w̶i̶t̶h̶ ̶t̶h̶e̶ ̶T̶a̶r̶g̶e̶t̶ ̶A̶F̶R̶ ̶m̶a̶p̶ ̶d̶i̶d̶ ̶y̶o̶u̶ ̶c̶h̶a̶n̶g̶e̶ ̶t̶h̶e̶ ̶c̶o̶n̶v̶e̶r̶s̶i̶o̶n̶ ̶f̶o̶r̶m̶u̶l̶a̶ ̶b̶e̶f̶o̶r̶e̶ ̶y̶o̶u̶ ̶p̶a̶s̶t̶e̶d̶ ̶t̶h̶e̶ ̶v̶a̶l̶u̶e̶s̶ ̶i̶n̶?̶ ̶I̶f̶ ̶y̶o̶u̶ ̶c̶h̶a̶n̶g̶e̶d̶ ̶t̶h̶e̶ ̶c̶o̶n̶v̶e̶r̶s̶i̶o̶n̶ ̶f̶o̶r̶m̶u̶l̶a̶ ̶a̶f̶t̶e̶r̶ ̶y̶o̶u̶ ̶p̶a̶s̶t̶e̶d̶ ̶t̶h̶e̶ ̶v̶a̶l̶u̶e̶s̶ ̶t̶h̶e̶n̶ ̶t̶h̶o̶s̶e̶ ̶v̶a̶l̶u̶e̶s̶ ̶w̶o̶u̶l̶d̶n̶'̶t̶ ̶w̶o̶r̶k̶ ̶a̶s̶ ̶t̶h̶e̶y̶ ̶w̶o̶n̶'̶t̶ ̶b̶e̶ ̶r̶i̶g̶h̶t̶ ̶f̶o̶r̶ ̶t̶h̶e̶ ̶S̶p̶a̶r̶t̶a̶n̶.̶ Ignore the above, just tested my conversion formula with your target AFR map and it dropped the actual AFR to 13.3 but Target AFR was at 15.9 so that is not right. Also for the MAP sensor I use the conversion formula ((((X/256) + 0.04) / 0.004) * 0.145)-14.5 which gets me pretty close (doesn't account for local atmospheric pressure changes/height above sea level but that is pretty negligible). Edited August 14, 2022 by Dangerous Dave Quote Link to comment Share on other sites More sharing options...
Chuck W Posted August 14, 2022 Report Share Posted August 14, 2022 1 hour ago, Dangerous Dave said: Sorry, yes I meant zero the all limits of LTFT. It shouldn't matter anyway really as the code probably bypasses the fuel trims (I haven't dived into it yet). ̶I̶ ̶n̶o̶t̶i̶c̶e̶d̶ ̶t̶h̶e̶ ̶c̶o̶n̶v̶e̶r̶s̶i̶o̶n̶ ̶y̶o̶u̶ ̶u̶s̶e̶ ̶f̶o̶r̶ ̶y̶o̶u̶r̶ ̶S̶p̶a̶r̶t̶a̶n̶ ̶i̶n̶ ̶T̶P̶ ̶i̶s̶ ̶(̶(̶x̶+̶4̶0̶)̶*̶0̶.̶0̶4̶)̶+̶1̶0̶.̶ ̶ ̶I̶n̶ ̶m̶y̶ ̶T̶P̶ ̶s̶e̶t̶t̶i̶n̶g̶s̶ ̶I̶ ̶u̶s̶e̶ ̶ ̶(̶X̶*̶0̶.̶0̶3̶9̶2̶1̶5̶6̶8̶6̶)̶+̶1̶0̶ ̶w̶h̶i̶c̶h̶ ̶m̶a̶t̶c̶h̶e̶s̶ ̶m̶y̶ ̶S̶p̶a̶r̶t̶a̶n̶ ̶o̶u̶t̶p̶u̶t̶ ̶(̶h̶a̶v̶e̶ ̶a̶ ̶d̶i̶s̶p̶l̶a̶y̶ ̶o̶n̶ ̶t̶h̶e̶ ̶S̶p̶a̶r̶t̶a̶n̶ ̶c̶o̶n̶t̶r̶o̶l̶l̶e̶r̶)̶.̶ ̶ ̶I̶ ̶t̶r̶i̶e̶d̶ ̶y̶o̶u̶r̶ ̶m̶a̶p̶ ̶o̶n̶ ̶m̶y̶ ̶c̶a̶r̶ ̶a̶n̶d̶ ̶i̶t̶ ̶r̶a̶n̶ ̶f̶i̶n̶e̶ ̶h̶o̶v̶e̶r̶i̶n̶g̶ ̶a̶r̶o̶u̶n̶d̶ ̶1̶4̶.̶7̶ ̶A̶F̶R̶ ̶a̶t̶ ̶i̶d̶l̶e̶ ̶b̶u̶t̶ ̶t̶a̶r̶g̶e̶t̶ ̶A̶F̶R̶ ̶w̶a̶s̶ ̶h̶i̶g̶h̶e̶r̶.̶ ̶M̶a̶y̶b̶e̶ ̶i̶f̶ ̶y̶o̶u̶ ̶t̶r̶y̶ ̶t̶h̶e̶ ̶c̶o̶n̶v̶e̶r̶s̶i̶o̶n̶ ̶a̶b̶o̶v̶e̶ ̶t̶o̶ ̶g̶e̶t̶ ̶a̶ ̶d̶i̶f̶f̶e̶r̶e̶n̶t̶ ̶t̶r̶a̶n̶s̶l̶a̶t̶i̶o̶n̶ ̶t̶a̶b̶l̶e̶ ̶f̶o̶r̶ ̶t̶h̶e̶ ̶W̶i̶d̶e̶b̶a̶n̶d̶?̶ ̶ ̶A̶l̶s̶o̶ ̶w̶i̶t̶h̶ ̶t̶h̶e̶ ̶T̶a̶r̶g̶e̶t̶ ̶A̶F̶R̶ ̶m̶a̶p̶ ̶d̶i̶d̶ ̶y̶o̶u̶ ̶c̶h̶a̶n̶g̶e̶ ̶t̶h̶e̶ ̶c̶o̶n̶v̶e̶r̶s̶i̶o̶n̶ ̶f̶o̶r̶m̶u̶l̶a̶ ̶b̶e̶f̶o̶r̶e̶ ̶y̶o̶u̶ ̶p̶a̶s̶t̶e̶d̶ ̶t̶h̶e̶ ̶v̶a̶l̶u̶e̶s̶ ̶i̶n̶?̶ ̶I̶f̶ ̶y̶o̶u̶ ̶c̶h̶a̶n̶g̶e̶d̶ ̶t̶h̶e̶ ̶c̶o̶n̶v̶e̶r̶s̶i̶o̶n̶ ̶f̶o̶r̶m̶u̶l̶a̶ ̶a̶f̶t̶e̶r̶ ̶y̶o̶u̶ ̶p̶a̶s̶t̶e̶d̶ ̶t̶h̶e̶ ̶v̶a̶l̶u̶e̶s̶ ̶t̶h̶e̶n̶ ̶t̶h̶o̶s̶e̶ ̶v̶a̶l̶u̶e̶s̶ ̶w̶o̶u̶l̶d̶n̶'̶t̶ ̶w̶o̶r̶k̶ ̶a̶s̶ ̶t̶h̶e̶y̶ ̶w̶o̶n̶'̶t̶ ̶b̶e̶ ̶r̶i̶g̶h̶t̶ ̶f̶o̶r̶ ̶t̶h̶e̶ ̶S̶p̶a̶r̶t̶a̶n̶.̶ Ignore the above, just tested my conversion formula with your target AFR map and it dropped the actual AFR to 13.3 but Target AFR was at 15.9 so that is not right. Also for the MAP sensor I use the conversion formula ((((X/256) + 0.04) / 0.004) * 0.145)-14.5 which gets me pretty close (doesn't account for local atmospheric pressure changes/height above sea level but that is pretty negligible). OK, I looked at those after your previous post. There are some LTFT adjustments being made after the car has been driven for a bit. I've tried a couple conversion factors, and none really seem to be correct. That "(X+40)" is in there trying to adjust for that offset that I'm reading in TP. (Using the Output sequencer feature from the Spartan, that is the adjustment needed to align with the 2 sequencing voltages). It's been a couple months since I've messed with it, but that 0.7V/40 byte/1.5AFR offset is prevalent throughout the range. What are the units for that MAP conversion? (I had been trying to set mine for vac/boost in PSI) Quote Link to comment Share on other sites More sharing options...
Dangerous Dave Posted August 14, 2022 Report Share Posted August 14, 2022 (edited) 3 hours ago, Chuck W said: OK, I looked at those after your previous post. There are some LTFT adjustments being made after the car has been driven for a bit. I've tried a couple conversion factors, and none really seem to be correct. That "(X+40)" is in there trying to adjust for that offset that I'm reading in TP. (Using the Output sequencer feature from the Spartan, that is the adjustment needed to align with the 2 sequencing voltages). It's been a couple months since I've messed with it, but that 0.7V/40 byte/1.5AFR offset is prevalent throughout the range. What are the units for that MAP conversion? (I had been trying to set mine for vac/boost in PSI) Ah ok, I get it now. So you're using the Intake Air Temp ADC channel to input the Spartan Sequencer voltage to try and check the AFR is correct. The issue is probably due to the different output impedance of the Spartan controller. It is known for causing issues on other ADC Channels, I had the same problem when I tried to use the accelerometer ADC input for my Spartan WB, it had a 0.7V difference. In the end I just used the tank pressure input (which you are already using for yours). If the voltage output from the sequencer matches what you are getting AFR wise then I wouldn't bother trying to get the other input working. The only other way is to get another WB Controller brand and try that but why bother if you know yours is working? And yes the units for the MAP conversion are in PSI with that formula Edited August 14, 2022 by Dangerous Dave Quote Link to comment Share on other sites More sharing options...
Chuck W Posted August 14, 2022 Report Share Posted August 14, 2022 2 hours ago, Dangerous Dave said: Ah ok, I get it now. So you're using the Intake Air Temp ADC channel to input the Spartan Sequencer voltage to try and check the AFR is correct. The issue is probably due to the different output impedance of the Spartan controller. It is known for causing issues on other ADC Channels, I had the same problem when I tried to use the accelerometer ADC input for my Spartan WB, it had a 0.7V difference. In the end I just used the tank pressure input (which you are already using for yours). If the voltage output from the sequencer matches what you are getting AFR wise then I wouldn't bother trying to get the other input working. The only other way is to get another WB Controller brand and try that but why bother if you know yours is working? And yes the units for the MAP conversion are in PSI with that formula Well, this is where I'm confused. The input from the sequencer matches, but then when running, the output in TP lags by that roughly 1.5 AFR. At least that's what is being reported in TP. I haven't been able to verify it yet with a second source (I'm not using a gauge or anything), so I don't know for sure. I do know that it no longer smells rich at idle, which it used to do with the old non-WBO2-emulated tune. It "appears" to follow the AFR Target map, with that offset. I'll try again with the MAP conversion. It seemed to be giving me weird values when I used it. Quote Link to comment Share on other sites More sharing options...
Dangerous Dave Posted August 14, 2022 Report Share Posted August 14, 2022 (edited) 20 minutes ago, Chuck W said: Well, this is where I'm confused. The input from the sequencer matches, but then when running, the output in TP lags by that roughly 1.5 AFR. At least that's what is being reported in TP. I haven't been able to verify it yet with a second source (I'm not using a gauge or anything), so I don't know for sure. I do know that it no longer smells rich at idle, which it used to do with the old non-WBO2-emulated tune. It "appears" to follow the AFR Target map, with that offset. I'll try again with the MAP conversion. It seemed to be giving me weird values when I used it. I just retested with your original file and I'm getting the 1.5 AFR difference again. My spartan is reporting 14.7 and the ecu is spitting out 13.2 It must be the 1E400 (target AFR) table as that is called for the conversion Just thought, I've got an ostrich so can live edit that map and see if anything changes. Will have to be tomorrow now though as it's late here Edited August 14, 2022 by Dangerous Dave Quote Link to comment Share on other sites More sharing options...
Chuck W Posted August 14, 2022 Report Share Posted August 14, 2022 22 minutes ago, Dangerous Dave said: I just retested with your original file and I'm getting the 1.5 AFR difference again. My spartan is reporting 14.7 and the ecu is spitting out 13.2 It must be the 1E400 (target AFR) table as that is called for the conversion Just thought, I've got an ostrich so can live edit that map and see if anything changes. Will have to be tomorrow now though as it's late here That would be awesome if you have the time. Quote Link to comment Share on other sites More sharing options...
Chuck W Posted August 22, 2022 Report Share Posted August 22, 2022 Well, after getting back with Aaron, this seems to be sorted. I had inadvertently mucked up the conversion factors for the ADCs turn-on setbits in activating the channels for logging. (Guess I really didn't need to do anything, other than connect the sensors to the proper inputs) That coupled with a small correction in the code and we were in business with things working as they should. I did need to readjust my WBO2 conversion factor to dial the Spartan Output Sequencer back in, but the offset was MUCH smaller than before. Glad to have that sorted out! 1 Quote Link to comment Share on other sites More sharing options...
SwedenSpeedin Posted October 17, 2022 Report Share Posted October 17, 2022 Hello Everyone, I am hoping this is an easy answer to an issue I have having trying to flash the ECU. After choosing the created flashing tool, the program times our and fails to erase. I have been able to datalog with two different tablets and two different cables, but can't flash. This is a VAST ecu, the car acts like it goes into bootleg mode (fan runs, check engine flashes a couple times, etc.) I run tunerpro as an administrator. With datalogging working I think the cable/computer communication would be fine for flashing...and that the problem is in the flasher setup, but I don't see. I could use a fresh set of eyes. Thank you for your time. Quote Link to comment Share on other sites More sharing options...
Turboforslund Posted October 17, 2022 Report Share Posted October 17, 2022 Hi, How did you manipulate the system voltage? Are you sure it is above 15V when flashing? // Turboforslund Quote Link to comment Share on other sites More sharing options...
SwedenSpeedin Posted October 17, 2022 Report Share Posted October 17, 2022 (edited) The ECU should be modified to not need a battery voltage above 11.8V. That being said my battery charger with raise the system to 15V (read from a plx wideband gauge) and I will get an error for voltage out of range. Added: I took off the cover so I could get a direct voltage reading from pin B8. Without battery charger-pin was at 11.7v (I would've thought this would be too low but is the only voltage that I didn't get a voltage error on) Tried again at 13.4V and 15V on pin B8 also but received a voltage out of range error. Edited October 18, 2022 by SwedenSpeedin Quote Link to comment Share on other sites More sharing options...
InfamousFlow Posted November 5, 2022 Report Share Posted November 5, 2022 (edited) Does anyone know why i cannot change the injector opening time above 4.973, i have green bosch injectors and want to set correct values. I set the injection basic to 0.7188 and constant for consumption to 7.19944, but when i set the opening time above 4.973 they automaticly go back to 4.973. Maybe someone have similar problem and know how to solve this. One more question, is there a way to control VVT with M4.4? Edited November 5, 2022 by InfamousFlow Quote Link to comment Share on other sites More sharing options...
Chuck W Posted November 6, 2022 Report Share Posted November 6, 2022 6 hours ago, InfamousFlow said: Does anyone know why i cannot change the injector opening time above 4.973, i have green bosch injectors and want to set correct values. I set the injection basic to 0.7188 and constant for consumption to 7.19944, but when i set the opening time above 4.973 they automaticly go back to 4.973. Maybe someone have similar problem and know how to solve this. One more question, is there a way to control VVT with M4.4? I ran into that as well. If I remember correctly, 5ms is the max value allowed and the values at that low of a voltage really aren't any concern. Aaron at VAST has programming to control VVT with the M4.4. 1 Quote Link to comment Share on other sites More sharing options...
