Max Meade
Installing An Obd Ii Scanner For Iphone
Hey guys!
So I wanted to get your opinion on something I am thinking about do to my car, and any ideas that would make this more feasible.
I am looking into installing a wireless or Bluetooth OBD II scan tool that would give my live data to my phone/tablet/computer. I am seeing a couple apparent issues to an install already because of where the OBD II port is located. First of all, without taking a section out of the bottom of the piece that lifts from the center console, I don't see a way I could install this as a permanent option that wouldn't change any of the features of the interior of the car. I have been looking into what options I have and I wanted to get your opinion on them and see what might be my best bet. I could get a mini OBD II scanner like this one, being so small, it might work fine and sit flush, or I could get something like this, and wire a wireless OBD II scanner elsewhere in the car.
I guess I am just wondering if any of you have done this before and how you did it. Will the smaller OBD II scanners sit flush or will it extrude a bit rendering either the cup holder or the center console useless or a pain to use? Is there a better way to do this?
I would really like to hear your opinions!
Thanks so much,
Max
Any thing plugged into the OBDII port is going to interfere with closing the armrest. I use an OT-2 to scan data on my iPhone through Logworks. Be aware that only 4 channels of data will display, ISO-9141 is too slow to support more channels reliably, regardless of what any documentation may claim.
To prevent the plug raising the armrest, I moved the OBDII port inside the armrest. You can slot the removable retaining screw cover. Ignore the arrow, this pic was taken to illustrate the VAG-COM cable integrated with the OBDII wiring.
Why would you want to integrate an OBDII scanner into your car? Are you really pulling codes that often?
if you're doing it for 'data-logging' you do know that OBDII only does 2 samples a second, and that's when you're logging only 3 parameters.
No I don't throw codes that often but being able to clear them on the spot is nice...
I really want it because of the live performance information some of the apps you can get offer.
My friend recently hooked one up to his car and I was impressed on the information you could get.
The little tiny bluetooth obd scanners you can buy on ebay for cheap should be able to fit with the armrest closed. I'll double check on my car tomorrow but I think it'll work. I'm not sure they work with iphones though. Something about apple purposely crippling the bluetooth capability to only use devices they approve of.
This is really a unique device and now blackberry will also launch obd2 software for the Blackberry BB10 devices. Also on another note, I just read today on the Ian Hawkins’s forum that Torque will be finally ported on the BB10 OS. That means that will we enjoy one the best OBD2 app around on our z10, Q10 and BB playbook. These OBD2 scanners provide best performance gauges and average fuel economy.
FYI, there are no iPhone apps that can receive OBDII data via bluetooth. You will need an ELM327 wifi dongle. I bought mine on amazon: http://www.amazon.com/dp/B00AOIM2CC/ref=pe_385040_30332190_TE_3p_M3T1_ST1_dp_1
I use it with the Dash Command app (purchased when the app was on sale for 50% off -- it's overpriced at the full price IMO). I'm pretty sure there are other iPhone apps that will work, too. Regardless, you'll need the ELM wifi dongle to get any readings on your iPhone.
If you have an android device you can use an ELM327 bluetooth dongle.
If this isn't spam, fill out your sig :arob:
Yeah I think my best bet is going to be going with the extender and wiring the OBD II somewhere else so I can use the iPhone capable one. If the extender can fit without extruding past the hole for the OBD II, then I think I could rewire it in a way that would look really good and wouldn't show unless you were looking for it.
I guess my other option would be to move the OBD II port, I don't think that would be all that hard, I just don't know how to get to the actual OBD II port screws so I can take it out and rewire it somewhere else.
Thanks for your opinions guys!
Remove the center console.. The port isn't screwed in place, there is a detent and a slot. 10 minute job - ok, a little more on a 850 perhaps...
It is possible use Bluetooth with the Iphone but only if jailbreak your iphone like i have.
I am using a mini Bluetooth ELM327 OB2 dongle from ebay super cheap ($6) and dashcommand (dropped their prices alot more affordable).
The key enabler is the software which you have have to purchase after jailbreaking your iphone. Its called RoqyBT4 or RoqyBT7 for ios7 the cost is 5 Euros, you can only find the software via Cydia which is installed after you have jail broken your phone.
Click on the Cydia program>Manage>Sources>Edit and then add http://apt.modmyi.com
Then search and install either RoqyBT4 or RoqyBT7 ( ios7)
After that step you need to search in Cydia for RoqyOBD4 or RoqyOBD7 and install depending again on IOS.
Reboot/respring after install.
In your Dashcommand or similar OBD2 logging program go to settings and select>ELM and configure OB2 port as below:
For details on Jailbreaking iphones/ipads search google for "RedSn0w"
OBD server:
roqyOBD creates a tcp server with those parameters:
Address: 127.0.0.1
port: 35000
Configure your OBD favorite application to connect to this server
Starting from iPhone 4s, iphone supports bluetooth low energy. Which means that they can receive OBDII data via bluetooth without jailbreak.
I have been using a bluetooth low energy adapter found at ebay with my ipod, it is pure white and mini size, it should fit. you should see it if Search lelink on ebay. Hope it helps.
  • Similar Content
    • By hcaznacnud
      Hey volvospeed!
      I have just recently installed a 20T turbo, 7 cm2 turbo exhaust housing, NA intake and exhaust cams, NA throttle body and air intake, BOSCH EV14 550 cc/min injectors, and an ARD tune. I did this about two days ago now and when I finished putting everything on the car started up fine. I let the car idle for about 5 minutes, and then took the  car for a test drive. As a side note I have swapped the automatic transmission for a manual M56H transmission, this was many months ago. But, I took the car for a test drive and when I would accelerate the car would not respond to the throttle then would backfire a few times, and would then repeat a few more times before the car lost all form of power and stalled itself out. I tried turning the car over but it would only crank not start. The next day I went over a few things to see what could be causing the issue. I pulled the spark plugs out and there was not a single hint of too much fuel. I next checked the shredder valve to be sure I was getting fuel and yes I did have fuel pressure. When I installed the cams which are both from an NA car I retarded the exhaust cam to -4 degrees and the intake cam to -6 degrees. ARD recommended, -4 exhaust and -8 intake, but I thought this a bit much. Does anyone know if the cams are the problem? The only other thing I can think of is that the tune is goofed in some way. The car did start and the car idled down to a beautiful purr but after driving it, which I only did 1/4 to 1/2 throttle (hard to remember but i know the car had to adjust parameters before I really lay into it so I did not go heavy), the car backfired then stalled and will not start again. If anyone has any info they would like to share please do.
    • By Okam12
      Hey guys,
      Recently my car has been shooting me with "reduced engine performance" and "engine system service required" Error codes. Yesterday I tried to replace the throttle body on the car thinking that was the problem. Once I tried driving it the acceleration was still the same very slow, and didn't go past 60 mph. So now I'm taking the other throttle body back since that obviously wasn't the problem. I'm wondering if its and issue with the turbo instead or even the air intake. Has anyone else had these issues? Please let me know.
    • By JasonVonIrsik
      I have owned this amazing vehicle and as I started researching, I found that these cars make great sleeper cars.   No one wants to be taken by a grocery getter.
      I am starting the build and want to get educated on my car. Vehicle: Grey 92 Volvo 240 Wagon. Engine 2.3L (That's all I know currently)  I have began tearing into the engine as it died on me and has been sitting for about a year now.  Shop said timing belt was busted and wanted 1,800.  I decided to do it myself.  I am mechanically inclined but far from a master mechanic.  Anyways, I welcome any and all advice.  I am going for sleeper, and will update any mods done.  I want it running first.  As you can see the belt is not busted and since the shop wouldn't return my car for almost 8 months, (Whole other story). I hope more issues have not raised.  At almost 200,000 but prior to dying it was running very well.  While I am tearing into it I want to fit it with a turbo.
      Again I can work on stuff, but tricking out, yeah not my thing so first question would be.....Is this motor able to handle a turbo and will I have to get forged guts?  Can I keep the same fuel rail?  Cam suggestions.......So on.  Thanks and I am new to the group.............
    • By 4eva's Dad
      No longer for sale
    • By dpsubzero
      Hello,
      I am new to this forum and would like to ask a few questions to my fellow Volvo enthusiasts.
      I am the proud owner of my Volvo S60 T5 from 2002. Over the last year i have done a few modifications to the suspension and engine. A little while ago I've replaced the 16t turbo with a new 19t turbo for more power. The car runs fine with the new turbo but it has only seen a few miles and low rpm only as the car's ecu is not tuned yet. Before tuning I want to install the green ''r'' injectors from bosch. Only thing that is holding me back is not knowing how to ecu will respond to bigger injectors. Will it cause problems? The car obviously has to be driven to the tuner for 40 miles(tuning at rica engineering). Do I need to let the ecu self-learn to use the bigger injectors before tuning or will it be necessary to have the car towed there?
      I thank everyone in advance for replying
