lookforjoe 2,689 Posted June 21, 2014 Report Share Posted June 21, 2014 Nice work! Was your battery leaking? Odd that the subframe has rust over on the driver's side. Link to post Share on other sites
boxpin 1,045 Posted June 21, 2014 Author Report Share Posted June 21, 2014 Looks like it had at one time. The charcoal canister was actually eaten through on the top, very odd being plastic. Painted the subframe before installing it. Link to post Share on other sites
boxpin 1,045 Posted June 24, 2014 Author Report Share Posted June 24, 2014 Car is running great. I like the new clutch combo. Transmission is still clattering more than I would like at idle. Ran across this...looks like I get to live with it. http://www.uucmotorwerks.com/flywheel/gear_rattle.htm Link to post Share on other sites
boxpin 1,045 Posted July 2, 2014 Author Report Share Posted July 2, 2014 Dual exhaust time Link to post Share on other sites
Tightmopedman9 1,020 Posted July 2, 2014 Report Share Posted July 2, 2014 Car is running great. I like the new clutch combo. Transmission is still clattering more than I would like at idle. Ran across this...looks like I get to live with it. http://www.uucmotorwerks.com/flywheel/gear_rattle.htm That article talks about using a unsprung clutch with a single mass flywheel. I thought you had switched back to the stock 850R disc? Link to post Share on other sites
boxpin 1,045 Posted July 2, 2014 Author Report Share Posted July 2, 2014 Since I read that its been determined that my trans is toast. Searching for a new one. I am still running a ClutchNet product just not the 6 button. Link to post Share on other sites
laird 259 Posted July 3, 2014 Report Share Posted July 3, 2014 Glad you're back in the road. Looking forward to more feedback on the clutch setup as you spend some time with it. Link to post Share on other sites
fattmatt805 24 Posted July 9, 2014 Report Share Posted July 9, 2014 Trans is in. double intercoolers for double the cooling pleasure Link to post Share on other sites
boxpin 1,045 Posted July 10, 2014 Author Report Share Posted July 10, 2014 double intercoolers for double the cooling pleasure Ha, havent switched over yet. Link to post Share on other sites
B Mac 956 Posted July 14, 2014 Report Share Posted July 14, 2014 Looks great John! You were using the P80 m56 or a P2 m56? Reason I ask...my m66 in the s60 rattles like a mofo after installing the quaife/bearings and running the Kalmar Union flywheel. Sorry for going off topic Link to post Share on other sites
boxpin 1,045 Posted July 14, 2014 Author Report Share Posted July 14, 2014 Ben, your not off topic, really you need to hear it. It went from no noise to scary. Link to post Share on other sites
fwdGTP 139 Posted July 15, 2014 Report Share Posted July 15, 2014 Does it sound this good? Volvo 850R M56H Toasted: Link to post Share on other sites
boxpin 1,045 Posted July 15, 2014 Author Report Share Posted July 15, 2014 Does it sound this good? uhhh, no. Took the FMIC out today and piped the DO88. Link to post Share on other sites
fwdGTP 139 Posted July 15, 2014 Report Share Posted July 15, 2014 Yee, nice Link to post Share on other sites
boxpin 1,045 Posted July 15, 2014 Author Report Share Posted July 15, 2014 CRAP!!!! Oil like wont go off. I made a couple wot runs in 3rd gear. Everything was fine. Drove back to work, shut it off. Fired it back up after lunch and the light stayed on longer than normal then shut off. Hmmm, didnt like that so I shut it off and started it again. Light went off. Went out to listen to the engine and when I got back in the light was on. Rev'ed a little bit and it went off but back at idle it came back on again. Now it stays on all the time. Engine still sounds fine but I am not driving it like that. Thoughts???? Link to post Share on other sites
