TIZIO AKA 1 HND MEC
Cxracing Coilover Kit Install
*FIRST OF ALL I AM NOT TRYING TO PROMOTE COMPARE OR SELL ANY PRODUCT, I DO NOT HAVE ANY CONNECTION WITH THE MANUFACTURER*
*** TREAD UPDATED***
So after the harsh winter and a few trip to the pothole-land NYC I pull the "trigger" on the CXRacing set on e-bay, delivery was very fast and the whole package was quite heavy.
post-34369-0-32376200-1409018740_thumb.j
So I bring the whole deal to the NEU BB-Q"R" in Vienna in order to have other people opinion.
post-34369-0-44717200-1409018894_thumb.j
After a complete check-up I bring them back home to install them.
post-34369-0-55643200-1409019037_thumb.j
Word of advise: spray with dw40 or similar all the suspension bolts/nuts on front/rear lift the car and drop'it ON JACK-STANDS ( DO NOT WORK WITH THE CAR ON THE HYDRAULIC JACK)
get a beer/soda and wait or clean the rims for a while :D
post-34369-0-50844500-1409019435_thumb.j
I start with the sway link ,
then the ABS sensor in order to avoid any unwanted damages,
get loose the two big bolts (LEAVE ONE IN TO HOLD THE WHOLE SPINDLE)
post-34369-0-12521300-1409019705_thumb.j
support from underneath the spindle(disk/axle bearing ) in order to prevent from falling forward and damage the axle/brake hose.
now you can take the top 3 nuts off, slide out the big side bolt and carefully take out the heavy and rusty part.
THE NEW COILS. FRONT
Out of the box the front's are way shorter than stock shock/ipd black combination, only weight is almost the same.
post-34369-0-63497000-1409020071_thumb.j do not get tricked by the length,out of box set up is very high.
I insert (screw in) the main cylinder until the bottom edge of the bracket holder, see pic
post-34369-0-95080700-1409020553_thumb.j the silver circle is the bottom of the coil (still have apr 1 to 2 inch to get lower)
the coil is nicely painted/welded and for the biggest relax the sway link tab is positioned perfectly and welded professionally ,in short is STRONG!
post-34369-0-64309300-1409021073_thumb.jpost-34369-0-35761400-1409021161_thumb.jpost-34369-0-99312800-1409021852_thumb.jpost-34369-0-04394400-1409025126_thumb.j
after you choose your height tighten well the aluminium big nuts with the special keys that came with the set.
post-34369-0-78691500-1409021367_thumb.j
the coils fit perfectly in with no problems whatsoever, you crank up the jack/spindle until the links reach the tab
post-34369-0-62340400-1409021553_thumb.j
insert back the ABS sensor connector, tighten well the two big bolts, crank the jack a bit in order to install the 3 top nuts.
post-34369-0-12799400-1409021707_thumb.jpost-34369-0-98180600-1409025169_thumb.j
With the wheel on air or on to the ground (under full load) the gap in between the rim and strut/coil assembly still the same apr 1 inch with the Midir's 18x8 and 225/40 tires and 3/4 of inch with the OZ's 18x8 and same tires ALL this with the spindle assembly fully puled outward from top.
post-34369-0-96791400-1409023213_thumb.jpost-34369-0-52469200-1409023248_thumb.j
THE NEW COILS REAR
Take out FIRST the 18 mm on the bottom of the rear shock,
now take out the top 12 mm nut and have a pliers handy to hold the top.
take the 15 mm nut from under the spring seat, push downward with your foot the whole assembly brake/disk/hub and with a pry bar push out the old spring (do not put your bare hand down there, spring might still under load) IF YOU DO ITS UP TO YOU or your skin
post-34369-0-36728700-1409022625_thumb.jpost-34369-0-24179500-1409022755_thumb.j on the CXRacing rear coilover the adjustable spring perch stay on TOP!
Shock is adjustable too ( I choose a bit higher set up do to running a temporary set of wheels )
post-34369-0-97242100-1409023616_thumb.jpost-34369-0-44472000-1409023760_thumb.jpost-34369-0-95893900-1409023852_thumb.j
Install on revers like the stock ones, perch with big washer and 17mm bolt/nut go on the bottom install this one FIRST on the spring area!
post-34369-0-08331500-1409024057_thumb.jpost-34369-0-13966100-1409024097_thumb.jpost-34369-0-29248700-1409024245_thumb.j
My car set-up:
front IPD track sway bar connected on the street load, IPD sway links, IPD cherry strut tower bar.
rims OEM 2013"MIDIR" 18 x 8 ET60? with 225/40 ventus tires.
First thing you will notice is that when you sit on the car the body of the car will not move/lower at all!!!
After the first test drive I can tell you the car is flat on the corners at any "legal" street speed, traction is way better than previous set-up and you will feel almost any road imperfection if you choose the extremely rigid bounce set-up!!!
I DO NOT HAVE any rubbing front or rear with the actual set-up high wise, with two people on the car and the trunk heavily loaded.
Working on the other pictures at the moment, hope this help others to understand better the safety/performance upgrade that a set of coilover bring to our cars!!!
Please keep the comments strictly related to the topic, if you can will excuse my grammar/language and length of this post !!! Ciao Tizio.
*UPDATE AFTER 800 Miles*
*I HIGHLY SUGGEST A ALIGNMENT BEFORE ANY JUDGEMENT*
In order to avoid any fears and confusion you might want to get rid of all the loose stuff ,coins/tools/bolts and what not you have in your door pocket, coins holder, trunk THAT WILL RATTLE.
You will find out the following : your dash its a mess , your wheels are far from round, your tires/rims need urgent balancing, rear OEM strut mount bushing are on the way out .
After a mix of city and highway driving I check all the new parts that I install for loose ends, missing bolts etc. I came out with empty hands, Is all there in place the way I install'it.
City and hills: half soft/front and full hard/back (current set-up), the car drives impressive on the tight turns
Highway: I turn toward SOFT 5 clicks/front and half way/back before a 200 miles trip and the car is smooth and ride close to the koni s.t.r.e.t.
Today I try the set with 235/40/18 and I have no rub at full lock front ( no liners) and a bit of rub over big bums AKA speed bums on the rear ( no liners as well).
I still can lower the front at least 2" and 1/2 to 1" on the rear.
Depending on the rims offset and mfct/model of tires with the 235 I suggest rolling the rear fenders.
EDIT: here are the pics, thanks.
Front is at 24 1/2", rears are at 23 1/8" even, with half tank and empty trunk:
post-34369-0-73835500-1410047376_thumb.jpost-34369-0-78409700-1410047438_thumb.j
post-34369-0-27260800-1410047476_thumb.jpost-34369-0-12220600-1410047510_thumb.jpost-34369-0-54067500-1410047618_thumb.j
post-34369-0-10641900-1409021125_thumb.j
Hat's off for a thorough write up. You may have spent more time putting this together than the actual install.
You nail'it!!!
Very nice write up Tizio! Even better pix! :P Do you know what the spring rate is on these compared to the D2?
One thing everyone noticed was that the enlink tabs are really beefy compared to the older D2 design. I'd pull the trigger on a set if the rear was a "coil over" set up and make them work with the AWD. :(
Hmmm been waiting to see how this turned out.. May have to consider these. You mentioned fit and finish is pretty good. Im guessing you would buy the setup again if doing it over??
Great write-up Tizio, and thanks for sharing all the pictures with us :)
smallest pictures ever ...
The DW40 only matters if you live in the land of rust. :)
You may still have issues with the end link tab. It isn't that it is weak; it is the fact the end links themselves will contact the frame on full lock. If you start to notice worn off the frame directly behind the coils, it is contacting. If you break anything, it won't be in the next few months, and it won't be the tab. It will be a snapped end link bolt, but it would probably be years down the road. :)
If you went from stock suspension to these, then yes they are stiffer than what you had, but you should still be able to deal with the rough roads relatively well.
I see 2 hands...
Well one is fake my friend, is helpful when you hug people !!!
Front are 5K and rears are 4 k (was standard setup) you can choose from a wide selection from them or other sellers, end links are indeed very beefy!!!
You mentioned fit and finish is REALLY good. Im guessing you would buy the setup again if doing it over??
I would buy'it again for sure Scott!
You Welcome Andy!!!
They came like that from my small phone, I bet you can fit a Canon D3 with a wide lens under a lowered car and take a better pic, just saying Justin ....
I checked under the car today, no sign of rubbing (maybe yet), thanks for the head-up Zappo, my previous set-up was stiff to, the roads are the problem after 5 mth of snow.
My D2's are twice the spring rate of those, but the roads I drive on are relatively smooth.
The contact point will be the closest point from the frame to the coilovers. On my car the repeated contact has hammered a dent in the frame, but it also destroyed the end link on that side of the car. Of course, I was racing the car so it will be different for you.
I would give it a few weeks of driving before you may notice anything though, and hopefully you find no contact at all. :)
No, they are actually in the same position as the D2s.
Would this kit work for an 850? I'm not well versed in the differences between the 850 and S70 in terms of suspension setups.
Mine have worked very well, I installed them with the eBay pillow ball mounts also, and I ended up swapping the front springs out for a set of 300lb 8in Afco springs from jegs because the stock TA springs were far to stiff for daily driving, in my opinion. Other than the springs for my uses, the only thing I haven't liked about them is that they have rotted out like crazy. Seriously, it's terrible. And I rust checked them like mad before I installed them. Very disappointing in that regard
  • Similar Content
    • By PLANT
      So the left front side, when turning slowly, was making a noise.....
      Mechanic has replaced the left strut mount of the suspension with another aftermarket version........it was only replace 1 and 1/2 years ago?
      Then says that the OEM is double the price but does not have the noise problem that has appeared?
      Anyone had this issue with aftermarket version strut mount covers?
      Also how many kms between wheel alignments?
      I rotate ever 10K Kms
      Just went for a drive on flat road and swerving at under 10kmh had the noise still there..... Sounds horizontal source not vertical
      Planned rotation and wheel alignment but going to check with mechanic again before......
    • By T4SPANISH
      Hola a todos, actualmente tengo un turbo T19, tubo de descarga de 3 "bsr y escape completo de 2'5" bsr, sobredimensionado marca kl intercooler, inyectores Bosch ev14 de 630cc, actuador de forja y válvula de recirculación de forja, pistón y filtro cónico bsr, tengo Un ajuste en la ECU hecho en España por trl y tengo 300 HP. Mi pregunta es, tengo otro ecu que me gustaría ajustar para exprimir la máxima potencia del automóvil, ¿sabes dónde podría enviarlo? Gracias
    • By 78-shaved245
      Ok so I have shaved the door handles and cut springs to lower more 245s than I can remember.  Last week I got a bit more modern and picked up a 01 s60 2.4 turbo at auction for dirt cheap.   The only thing I don't love about this car is the ride height (it's like four miles off the ground).  I want to go low, at least two inches.  Can I get away with cutting these springs?
    • By TheOtherWhiteMeat
      A truly unique and one of a kind Volvo S80. One of only a handful in the world to be taken to the next level. The car has been shown in WA and OR at numerous events and featured online a number of times. I am the second owner of the car, and have owned it since 2009. It has been meticulously cared for its whole life, never smoked in and has always been serviced at Sandberg Northwest Volvo in Lynnwood, WA where it was purchased new for $47k. The engine and drivetrain are in perfect working order with no leaks, grime or strange noises. You could eat off of the top and the bottom of the engine. Amsoil 10W40 motor oil and Volvo OE oil filters have been used since I've owned the car. The engine was compression tested recently and tested perfectly with even and strong pressure in all cylinders. New transmission, rear main seal, cam tray and cam seals, new timing belt, new transaxles, new oxygen sensors (all 4), recently new OEM Volvo coil packs (all 6), new steering rack and tie rod ends, recently new radiator and hoses, recent ceramic brake pads, Powerstop slotted rotors with black Brembo caliper covers. 20x10 TSW Zolder wheels wrapped in Nitto Neo-Gen tires with 80% tread life remaining. (Awesome rain performance)
      This is the Volvo flagship luxury sedan and has every option available including dual climate control, 8 way power heated seats and mirrors, safety lighting, 4-speed automatic Geartronic transmission w/OD, traction control, power moonroof, tilt/telescopic steering wheel, security system and 9 speaker AM/FM/CD Dynaudio sound system.
      Many unique upgrades and detailed features throughout the car including:
      Painted and body matched engine top cover and intake manifold
      Body color matched moldings and skirting
      Fenders and quarters rolled to provide a wider stanced appearance
      Custom poly front lip spoiler
      Custom fiberglass eyebrows
      15% Suntek carbon-dyed window film
      5000K 55W HID lighting in 2006 S80 headlight housings with LED city lights
      5000K 55W HID lighting in custom OEM fog light housings
      Brushed aluminum vinyl wrapped interior trim
      Aluminum gauge cluster trim rings imported from Sweden
      Custom 2.5" dual exhaust with Magnaflow muffler and polished tips
      K&N high flow air filter
      KW V2 adjustable coilovers with new strut mounts and Eibach rear coil springs
      iPd poly upper engine mount
      iPd heavy duty sway bar endlinks
      iPd poly subframe bushing stabilizer inserts
      Car is located in Seattle.
      $6,500 obo
    • By Adam Franke
      New, in box, never used.  Only opened the box to look at the parts, never even took them out.  For reference, they are SKU 15267007: http://www.kwsuspensions.com/kw-suspensions-kw-coilover-kit-v2-volvo-s60-h-r-2wd-s80-2wd-15267007.html
      Looking for $1800 shipped, OBO.
