So I removed the old exhaust tip from my 855 (rusted through...ugh) and replaced it with a $8 pencil rolled extension tip. It looks better, but it's too small.. It just doesn't fit in the bumper cutout. I tried attaching this larger (but shorter) tip to the extension, but the extension has too large of a diameter. The only larger tips that will fit are resonators. Will these make my car sound like rice? Or are they mostly stuff? Thanks.
"resonator" Exhaust Tips
Started by 855T, Feb 13 2005 08:40 AM
6 replies to this topic
Posted 13 February 2005 - 08:40 AM
2010 WRX (2.5k) - stock, until the warranty's gone
1995 855T (160k) - deer dents, various mechanical failures, voluminous trunk
Posted 13 February 2005 - 09:26 AM
Resonators are called resonators because they do just that: sound like shaz. You may have seen an otherwise stock exhaust setup that sounds like a swarm of mild-tempered bees coming towards you, behold the 1-1/2" fury!
Try something like Magnaflow, it's a full muffler and ask around here for how they sound: lots of folks are running these!
Posted 13 February 2005 - 02:12 PM
QUOTE(BeachRat @ Feb 13 2005, 04:26 AM)
I agree, you can get a resonated tip for proably $15-40 or you could just go get the magnaflow muffler for maybe $75 and actually have your engine produced that sound not just some additional holes drilled into a muffler tip.
Posted 13 February 2005 - 04:14 PM
i don't see how just a tip could effect the exhaust note so much?
Posted 13 February 2005 - 05:01 PM
When I get a volvo and the rolled edge on the stock square tubing is rusted I take it off the exhaust and mod it. I start with at straight edge of masking tape right to the initial portion of rust and run this "straight edge" all the way around the tip. Cut with a dremel or other form of cutting wheel and then clean off all surface rust with a da or hand sand. Then prep and paint the tip a semi-flat black and replace just a hair back so the tip is flush with the rear clip. The straight out look looks meaner than the rolled edge in my opinion. But if sound is what you are going for, cut the suitcase out and replace with a magna or comparable brand muffler. m2c.
'05 VW GOLF GLS TDI (Running Bio)
'99.5 FORD F250 7.3 D (Running Bio)
'01 HONDA 929RR "streetfighter"
'05 YAMAHA ZUMA (100mpg!)
Posted 13 February 2005 - 09:13 PM
Eh, there are so many things I'd rather buy than a new muffler. I was just wondering if resonator tips sound like crap, and, since they do, guess I'm gonna have to figure something else out. Thanks guys.
Edited by 855T, 13 February 2005 - 09:13 PM.
Posted 13 February 2005 - 11:13 PM
QUOTE(855T @ Feb 13 2005, 04:13 PM)
Just go for a nice stainless tip.
