Replacng Electric Door Lock
#1 Mase
Mase
  • 2 posts
Posted 14 February 2005 - 07:08 PM
I have a 1998 V70 GLT AWD that I'm having trouble with the left rear door lock. The lock will lock when I use the remote or driver door master lock but will not unlock by either means. Can any one ell me if this requires a lock replacement or is there some other potential problem. If I need to replace the door lock I'm sure I would use the procedure used to repair door locks in Bay 13.
Thanks in advance
Mase
'84 240 Turbo; 98 V70 GLT AWD and '00 V70XCSE
#2 jda2000
jda2000
  • 1,027 posts
Posted 14 February 2005 - 08:00 PM
you need to replace the electric lock mechanism, not cheap. $100+ at the dealer.
Since is the rear driver's side door, you might want to let it be for now tongue.gif
John, Sarasota, FL
'01 V70 T5, '07 S60 2.5T
#3 Mase
Mase
  • 2 posts
Posted 15 February 2005 - 03:17 PM
sad.gif Thanks for the reply. I will wait since I just replaced the struts and had the ABS Module repaired. I can reach back and unlock for awhile longer
Mase
84 240 Turbo; 98 V70 GLT AWD; 00 V70 XCSE
#4 Vitor
Vitor
  • 272 posts
Posted 15 February 2005 - 05:59 PM
A plastic lever is broken inside the door latch. Most of the time this is the problem.
Look in the maintenance section, I documented the process to repair the right front latch on my 98 V70.
On the right side the broken plastic lever is red.
I believe on the left side the plastic lever is yellow.
If you decide to replace the latch, the same instructions will help you.
Step childs 92 Chevy Suburban and '03 Mini Cooper S
