apeacock
Peacocks Wagon Build
37 minutes ago, Tightmopedman9 said:
Nice, that fitting looks very low profile. Are you going with the dual port wastegate and 4 port solenoid?
I replaced the CBV on mine with the turbo smart as well; it didn't do anything for performance but the stock CBV made this super annoying (I thought) whine at light throttle.
That's what i figured. Seemed really close to the turbo and I can even cut 3-4 threads off of it and get it tighter to the core.
Bens got to send me the 4 port still, I have the solenoid but I am going to run on waste gate pressure alone until hopefully September when I make the trip out to Rolling motors and have the pump installed and properly tuned. Interested in the part number for the CBV if possible.
33 minutes ago, Tightmopedman9 said:
Nice I saw this one today for about that on one or two site. Couldn't tell if it would fit as I didn't see any dimensions.
Also got my donor oil pan cleaned and ready for the bung to be welded in. Parts cleaner at first,  simple green bath after that. Rinsed very well after wards.
Waiting on the machine shop for the manifold. They had some trouble with the studs so they had to bring in a welder, not looking forward to what that will cost me.
I presume that much gunk is normal?
More pan shots. Going with the original pan and modding the stock drain tube. If that doesn't work I can go right to the pan with the 10AN in it.
New gasket is the one piece c30. Looks really beefy.
Feeling very lucky to have a garage where the wagon can sit and allow for this project to take a while.
While removing the old pan I ran into the one broken bolt from the manual swap. One of the 14mm Transmission too pan bolts broke during the install. It is a spot used on the p80 but not the p1. Shown below is the tool we used to fix the problem.
Great side by side of the two turbos.
Edited by apeacock
  • Upvote 3
Are you sure that one piece will fit? The RNC head has no water port to interfere.
You have to trim one end by the water pipe a bit but otherwise yes it works. I'm running one on my wagon :smile:
Edit: found a picture from when I installed mine. The top right corner of the gasket needs to be trimmed.
EE2C8978-8663-46CB-98DD-0747E4EBDDED_zps
Just did 5 on a friends are and it really really sucked. Now factor in maybe having to take some off to readjust the turbo etc and it would be even worse. Good to know on the trimming.
Spent some time on the manifold. Had it cut down then opened it up a bit myself. Some other people have shown removing way more then I did. But I wanted to keep as much material as possible. Still considering making a secondary support for the very heavy turbo.
I wish i hadn't let the tool jump and run that big line across the face of it but I can't really fix it now.
Bonus no door pic.
Many turbo things happening.
The heat shield needs some persuasion to allow the large IWG exhaust housing to fit. The space is tight But has hard as I could shake the engine forwards and back it didn't touch the firewall or is components. That is until I get my additional heat shielding material and PTP blanket in there. Then I'll be cutting it very very close.
Install notes:
It's heavy.
It fits right through the top if you go exhaust side first.
It's worth fitting the water lines before you place it all in there.
My water line kit sits lightly wedged between the core and the compressor housing, They both sort of run the opposite way that makes sense for fitment. However I believe if I switched them around I may run into further issues.
I used a pre made 18" line and an 8" line supplied with the Kinugawa 320-1201-007
The water lines just don't play nice with the turbo, they can both fit in there holes, but only with the rubber end loose. Hussein is modifying them for me so the elbows are much shorter.
The TCV bracket must come off the turbo. I didn't want to bend the 16 year old rear water pipe so a quick go with the die grinder saw it removed.
To get a good grip on the rear oil supply line I needed to remove the bearing carrier for the passenger side axle.
Edited by apeacock
  • Upvote 3
Love it, can't wait to see this all finished up!!
Nice! Do you have a blanket for that hotside? It would help keep your hoses from getting crispy ;)
Yes indeed!!
I went big and got the very form fitting blanket from PTP turbo blankets in Texas.
I also bought some stick on reflective material for the firewall. But I'm going to wait and measure how hot the turbo gets, the material say's it's only good up to a working temp of 400F though maybe that means the surface it's on can only get that hot.
Due to some poor planning I had the need to slice my rear exhaust open. At the time I got the EST down pipe I really didn't know V band or flanges were a thing.  They saw the clam shell was leaking and offered to just put a sleeve in place of it (kind of a mistake a everyone's part).
If you've never removed the carreir plate then you should know you need to unhook the rear portion of the exhaust to free it. The fit was tight without removing the 02 sensors on the front side and I just don't think it would have made it.
I did coat the top and bottom of the new piece with a few layers of Summit General Chassis Enamel, I'd been watching that guy on Youtube buildis V8 Miata and had to give it a try. The more protection the better right?
New bracket in place. Removal also makes mounting the prop shaft much much easier. You mount it loosely to the center plate. then lift it into place making sure the ends line up with the AWD system.
Edited by apeacock
  • Upvote 2
IT STARTS!
Turned into one of those hurry up and wait days. I thought I was going to be able to get the exhaust fabbed up today but ran out of time. After fitting the new intake parts I found that the the IWGA was a bit to close to the tube and needed to be clocked over about 10*
Que the 13mm combo wrench and I got to work. Intake and charge pipe are now on the car. I was told to get a 45 & 90 coupler for the new mini Snabb intake pipe. However I would contest that two 90* sections are the way to go as I was forced to leave the filter straight and not include my intake box (say what you will I like it)
However with this new found lack of fitment perhaps I can find a different intake setup. I'll need a different one to accommodate the incoming 3.5" maf housing. Any suggestions?
The coolant lines are also in and they do touch the intake tube, but there really isn't anyway around that with this turbo.
Enter a piece of dryer tube as a temp exhaust!
Shaky picture I know.
Patented Squiggle Diggles
  • Upvote 2
im not the one to read so thanks for all the pics...nice work !  thumbup.gif embeer.gif
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By lowbudgetracing
    • By andyb5
    • By cryptophilosopher
    • By cruzvolvo
      T-5R Wagon (1995), black, automatic transmission, mostly original with a few moderate suspension upgrades. Approximately 175k, with careful and regular service. This was a California car for most of its life, and is (from best estimates) one of fewer than 100 still on the road in the U.S. It comes with: IPD 3" cat-back exhaust; 4 steelies with snow tires mounted; trailer hitch; original parts no longer installed; and your choice of body panels and parts from a 1995 black 850 NA wagon (parts car). I am a motivated seller and will take $3,000, for the next two weeks. Contact me and I'll answer all questions, to the best of my knowledge, and send any additional pictures that you may want. The car can be seen in Delaware, near I-95.
