apeacock
Peacocks Wagon Build
I'm running this https://www.amazon.com/AEM-21-2059BF-DryFlow-Air-Filter/dp/B004XH68PM
If I remember my math correctly it flows like 930cfm, @22psi on my 2.5 I think it requires something like 830cfm. Realistically you want to run the largest filter you can fit. You don't want your filter causing any restriction.
5 hours ago, Tightmopedman9 said:
When I had a 20G I used that same Jaguar box and fit the largest filter I could in there, and it was still quite a small filter. I wouldn't recommend it...
The filter I use is the AEM 21-3059DK which is 6.5" in diameter and 9" long. I think that filter is almost the same size as the Jag canister itself. Granted I don't have a pre-turbo pressure sensor, but I wouldn't want to use any smaller of an air filter.
3.5 or 4" MAF with this?  Currently going with 3.5 based on what's been recommended.
1300kg would be awesome, I want to say that's abput where Steve is at with his.
Edited by apeacock
Assuming he's on a 4" MAF as that part number pulls a 4" inlet filter, however they make that exact same filter with a 3.5" inlet. I'm currently running a 540i MAF (3.5") with no plans or need to upgrade, so this is probably the direction I will go.
4" MAF, I'm at 1700kg/hr which is 4.19V.
with what turbo is that ?
and headers? or r mani?
Dougy, why don't you just read my sig?
EFR7064, R manifold
lolol...ohk
Image result for crossed eyed blind symbol
you should have went bigger.
That's a massive amount of air holy cow. Have you had it on a dyno?
5 hours ago, lookforjoe said:
Thanks!
Got the exhaust bend made today. Only took about an hour and a half for the guy to make it. I like how It came out. 3" mandrel bend to a 2.5" ball at the bottom. Longer 3" run the the previous EST supplied piece.
Went to start it and it sounded the exact same. I guess I didn't have the manifold all the way down on the car. As a result the head is leaking like crazy. Tried to give it all another go an it only made a small difference. I think I'll need t free the turbo from the head and then try and torque it all down once more. I hopefully don't need to pull the whole turbo off but if it comes down to it, I can probably get it loose in 45 mins to an hour. The gasket would need to be flatter no?
How did you torque the manifold nuts down?
My sexy arms.
No spec just pretty tight with a 10" wrench. I think looking back at these pictures I can see the 3 layers are not flat against each other.
I think the turbo and the exhaust are pulling on it(which they should a bit) and so what feels tight isn't tight against the head. I hopefully have not ruined my gasket. However, if it isn't sealed then how could I have right?
Torque spec is 18 ft lbs for the manifold studs/nuts.
As I said via text, torque from the center out with the turbo removed to make sure the manifold is good and tight/flat to the head
Working on doing just that! Seem to be able to take apart and maneuver this turbo better then a stock one. I think the up in size and change in position helps accessibility a bit. Going to try and leave the turbo in place so I don't need to drain the coolant. The studs are not fixed in the manifold so I maybe able to fish it out and around the exhaust studs. Though they may still pose a problem.
Did you ck the flatness of the head and ex manifold mating surfaces before assembly?  Assuming so, but thought I'd ask..
Hope you figure it out..
Got it part way apart today. More work to follow.
The seal of both was great before hand. When I get it all apart I will triple check that.
  • Similar Content
    • By Shane E
    • By KMF
      i have a V70r 1999
    • By 05V70RGT
    • By Mustapha
      Hello,
      first time posting here not sure what to expect. So I have an 07 xc70 I recently purchased and have a few questions about some performance mods I would like to do. So this car has about 175k miles and I want to boost my horse power up to the high 200’s if not low 300’s it’s my daily and I want a bit more juice for fun but I don’t want to destroy it too bad I love the i5 sound and the entire car in general. What are some things I can do to increase the horsepower but keep it from killing itself. Also what are some good exhaust mufflers or kits I can buy that increase the sound at higher rpms but not as much at low rpms it just sounds so amazing at high revs and I want to emphasize that as I’m driving. Any feedback or suggestions would be great. Thanks!
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
